Question about GE 30 in. JGP320EV Gas Cooktop
I bought a ge oven gallery to go under an electrolux gas cooktop. 3 different stores were willing to sell me this. my cabinet guy and contractor are thinking this isn't going to work?? can you help me?
    Sergeant:
    Champion:
  • 338 Answers
The cabinet and contractor know best. it has to deal with dimensions. a store will sell you anything
Posted on Nov 26, 2008
Do you know the BTUs for the five burners on this cooktop?
WEIGHTS & DIMENSIONS Approximate Shipping Weight 38 lb Cabinet Width 36 in Cutout Dimensions (Width x Depth) (In.) 33-7/8 x 19-1/16 Net Weight 33 lb Overall Depth 21 in Overall Height 3 1/16 in Overall Width 36 in Space Required Below Cooktop 0 7/16 in
  • POWER / RATINGS POWER / RATINGS Burner BTU Ratings (000's/BTU) - LP Gas (1) 9.4; (2) 7.0; (2) 4.0 Burner BTU Ratings (000's/BTU) - Natural Gas (1) 12.0; (2) 9.5; (2) 5.0 Volts/Hertz/Amps 120V; 60Hz; 5A
  • ACCESSORIES ACCESSORIES LP Conversion Kit Included
  • WARRANTY WARRANTY Parts Warranty Limited 1-year entire appliance Labor Warranty Limited 1-year entire appliance
  • GE 36 Built In Gas Cooktop JGP636WEDWW GE Appliances
    Oct 27, 2015 | GE Profile JGP636 Gas Cooktop
    Where are the inline fuses on the Electrolux Frigidaire double ovens?
    I appreciate your post, Richard Balzer!
    I see that you would like to know the location of your inline fuses on your Electrolux wall oven. I have located the wiring diagram and the parts manual for your wall oven. I do not see the location of an inline fuse. I hope this is helpful information. -Matt
    Frigidaire Manual Search Results
    Jan 18, 2015 | Electrolux Frigidaire Gallery 30" Double...
    Sensor pad has short according to the message on the G.E. sensor Microwave Oven
    call service or bring oven back to store where u bought it if under one year old...to get it fixed free
    Sep 23, 2013 | GE 30" 2.0 cu. ft. Sensor Microwave Oven
    Ignitor does not click
    there is no "ignitor" as you would find in an oven or dryer. There is a sparkmodule that many times goes bad after 5 to 8 years. It is a plastic box about 4 to 6 " x 2" wide and wil have 3 to 5 wires or 3 to 5 terminal connector points on it. remember to unplug the range top fromwall electric. these units are not difficult to replace; they are not repairable, you have to buy a new one.
    Apr 28, 2010 | GE Profile JGP636 Gas Cooktop
    I have a frigidaire gallery series, electrolux oven, we used self cleaning mode, worked great. Problem is the oven doesn't work know, broiler works, just the oven wont turn on.
    often the bake ignitor will burn out during or right after a self clean cycle.You can confirm this by either measuring voltage at ignitor while oven is on.Alternate method remove ignitor ,check continuity, If the ignitor is coming on but no gas,replace ignitor it is weak.Hope this helps ,please take the time to rate my response :)
    Feb 03, 2010 | Cooktops
    I have a GE Profile gas cooktop. The small black pads (feet) under the grates are deteriorating. Where may I purchase new pads?
    Hello. Any store that carries the GE Profile appliances, like Home Depot, can order them for you. Regards, Joe
    Dec 09, 2009 | GE Profile JGP636 Gas Cooktop
    All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
    It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
    Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
    Stained gas range burner grates
    Hey y'all. I have the same lame GE profile gas cooktop with the gray grates and burner covers. I know this is the expensive way to go, but I use Easy-Off "self-cleaning oven" oven cleaning spray. For about $5, you get 3 cleanings. It is a pain to do, but I have better things to do than scrub these grates all the time. I don't know why, but the baked on crud just drives me crazy. I tried everything to clean them completely. I even tried to scrub the darn things with a kitchen pumice stone(sold at walmart)but it is impossible to get the curvy areas clean. Now the paint has started to wear off on the burner covers.
    I do not use the oven cleaner on the cooktop itself. I use soft-scrub with baking soda, then cover the cooktop with a sheet of heavy duty aluminum foil and cut out holes for the burners. This keeps most of the spills contained, and helps with cleanup.
    I visited to the GE parts web page, and they only sell gray grates and covers. I am going to buy black BBQ grill paint(spray can)from Home Depot and try it on the burner covers first. They are the least expensive to replace if it fails, and if it works, I will paint the grates with this high temperature paint. I will keep you posted on the results.
    Regards,
    Laura D.
    Feb 14, 2009 | GE 30 in. JGP337 Gas Cooktop
    Poor gas flow to GE cooktop
    Try a bigger inlet pipe sounds like pipe too small for load .
    Apr 11, 2017 | GE 36 in.JGP970 Gas Cooktop
    Granite installation didn't get flush with slide-in range
    suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
    Sep 04, 2008 | Cooktops
    GE 30 in. JGP320EV Gas Cooktop Logo
    128 people viewed this question
    Top GE Cooktops Experts
    Dan Webster
    Dan Webster
    Dave Harrison
    Are you a GE Cooktop Expert? Answer questions, earn points and help others
