Question about Toshiba Satellite M105 Notebook
Can't Connect to internet with wireless connection
It says to change switch from off to on. I can't figure it out is the switch a manual switch or a sofware switch ?
Well, Im not the orginal poster but im having the same problem,It has a new mobo, the driver is installed correctly, fresh install of windows, new atheros wireless card. I do not even get the orange or blue light that is beside the switch on the front. Could i have bought a faulty mobo?
Posted on Sep 27, 2011
  • mike davis Sep 27, 2011
    l305-s5875 is my model number
Its a manual switch check it on you computer
icon looks like this ((p))
can i have the brand and model of your computer so i can help check the manual
Posted on Nov 19, 2008
How to turn on wireless capability on a dell latitude e5420
Richard Herfurth,
To turn the wireless on you can switch the wifi catcher switch on, The switch is located on the front edge of the computer next to the display release latch.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 07, 2015 | Dell Computers & Internet
CAN'T CONNECT WIRELESS INTERNET ON MY RCA RTB10220
I have this same model and I connected to the internet via Ethernet cable. I couldn't figure out how to connect wireless. I hope this helps. Good Luck!
Jan 03, 2013 | Computers & Internet
Can't connect to wifi. There is no switch on the computer to enable it. My internet provider could not figure it out either and told me to take it back to the store.
try Fn+F1 after that go to network and sharing centar >> change adapter settings >>choose wireless adapret and connect ...Regards!!!
May 19, 2011 | Samsung N145-JP01US Netbook
I was able to connect to my router but I have to manually turn on the wireless internet switch to "On" each time I restart the computer. Then I have to select the router and connect. Is there...
1. switch to "On" each time is need
2.automatically connect to your router need somesetting in your computer
3.you can chang the QUNE in wireless list then select auto,then del other wireless AP name.
Dec 29, 2010 | Sylvania G-Netbook
Router communication with cable modem
If you change service providers, connection type and hardware, then all your previous connection settings will not work, and they'll have to all be reconfigured.
Have you been given a new modem/router (combo unit)?
Did you previously have a separate modem and a separate router?
Do you connect your xbox via WiFi?
Go back to basics now. If your computers connect fine, then connect the xbox using an ethernet cable and see if it works. Then try wireless.
Feb 27, 2010 | Belkin (F5D7230-4) Router (587009)
Can't connect to the internet...
One tip for you is make sure you are using one software to run your wireless card, either remove the software for the wireless card and let windows configure it, or tell windows you have a excisiting software that will control your card, it sounds like software conflicts one is turning on other is tunring off and so on.
Nov 30, 2009 | Toshiba Satellite A100-S8111TD Notebook
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link DP-311P Wireless print server reseting
Hi Luis,
Sorry, it had been my mistake, did not realise your model does not have ethernet port at the back.
On D-Link printer servers that do not have cable connections it requires a couple more operations, you must do the following to connect safely to the server and open configuration:
  • On the rear panel of the DP-311P you fiind a switch to set server to Config mode. Set the switch to
  • Now go to the computer that is connecting wirelessly to the D-Link, go to wireless adapter properties, for example using control panel, and set the adapter to Ad-Hoc mode.
  • Change manually the wireless adapter IP Address so that it is in the same IP Address range
  • as the DP-311P, set the wireless adapter to a static IP address comprised within 192.168.0.2 and 192.168.0.255 excluding 192.160.0.10.
  • Always in wireless adapter settings >> IP configuration, set subnet mask to 255.255.255.0.
  • Ensure you click OK, or Apply in network settings Window, and restart the computer to apply new network settings.
  • Open Internet Explorer and type the IP Address of your wireless print server in the address bar. The default IP Address is 192.168.0.10.
You also find procedure explained at page 7 of the user manual here : D-Link DP-311P
Then follow instructions at page 15 to reset the server.
After you have finished configuring the DP-311P, to save the changes, you must toggle the mode switch on the rear panel of the print server back to “Normal” mode.
Oct 25, 2008 | Office Equipment & Supplies
Wireless-g
Hello, You can reset the router to default. On the back of router push in the reset button/hole for 10-15 seconds. The defaults will be: IP address 192.168.1.1 User name admin. You shouldn't need a password. From there you can change username, password, SSID and enable WEP or WPA security. Hope this helps.
Mar 25, 2008 | Linksys Wireless-G WRT54G Router
Wi-Fi
You will not believe me but I have a similar problem. I have also Belkin router at home and wireless connection with my e800 works perfect. A few days ago I have tried to connect my PDA to wireless router of my best friend. His wireless network is protected like mine and after configuration of all settings I had no success. The funny thing is that PDA show me the status CONNECTED but I can not use the internet explorer. Like I said, at home with my Belkin it works properly. I can really not explain what the problem is.
Sep 08, 2005 | Toshiba e740 Pocket PC
Toshiba Satellite M105 Notebook Logo
170 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
