Question about Zanussi WJS1397W Front Load Washer / Dryer
Notched washer? Please can anybody suggest how to stop the notched washer which fits onto the motor from falling off? When it has fallen off, the machine just wizz's through the programs without stopping. Superglue was tried but did not last very long. Would it be a reasonable cost to replace this washer, or does that mean a new motor? Is it falling off because it is worn? Thanks, Jenjen
    Champion:
  • 249 Answers
USE A PRODUCT CALLED JB WELD, IT WON,T COME OFF AGAIN
Posted on Nov 28, 2007
How to change the battery in a jaguar XF smart key
1) Carefully remove the plastic silver sleeves on each side of the remote.
2) Carefully open the remote to expose the battery -- try to keep the circuit board and valet release pin from falling out.
3) Replace battery -- plus (+) side down
4) Before closing body of remote, take note of valet key release pin & spring. Be sure the spring and pin are in the correct position (see pic).
5) Carefully close body of remote.
6) Before attaching sleeves to remote body, be sure the notched end of the sleeve is aligned with the valet key.
7) Carefully slide silver sleeves onto each side
8) Test
Apr 24, 2014 | 2009 Jaguar XF
Car Door Diagram
Check that the spring on the notched plate is not broken and fallen out.. It may be possible to get a new spring and place it back in It may be difficult to do but with some thought it can be done.
May 25, 2013 | 1998 Holden VT Commodore
Memory card is locked
what kind of Memory card is that SD/Micro SD? or what so ever, normally all MMC have lock option on it, try following these steps:
  • take out the memory card look on the left hand side of it and it might say in little letters lock and there's a little thing that moves up and down and then move it up.
  • The switch / notch works in same way as the notches on compact audio cassettes and videotape cassette tapes or floppy disks. A closed or covered notch is writable, while an open notch (or removed tab) is protected.If the switch becomes broken or falls off then the card will become a write-protected ROM card and no longer be writable. A possible troubleshooting solution would be to apply tape over the notched area (avoiding the connectors and the other notch) to configure the card in a permanent writable state."
Pleasenerdierob.jpg see attach picture for your reference
May 30, 2011 | Cameras
How do you tighten the chain on a signle sided swingarm?
There is a bolt (17mm I believe) in back of the axle and to the right of the chain. Loosen this bolt and using a hook spanner on the notched ring which is on an eccentric, turn forward to reduce chain slack. If you have the Triumph tool kit there should a spanner with an extension handle included. Otherwise buy or borrow an adjustable spanner that will fit the notched ring. (About six inches in diameter.) The torque on the clamp bolt is about 40.6 lbs. (55 Nm)
Jul 25, 2010 | 2000 Triumph Sprint ST
Memory card loked
"The switch / notch works in same way as the notches on compact audio cassettes and videotape cassette tapes or floppy disks. A closed or covered notch is writable, while an open notch (or removed tab) is protected.
Jul 09, 2010 | SanDisk 1GB microSD Memory Card
The plastic notched tray of the ice cube maker is broken
Those parts are available and require disassembly of the IM to replace.
Eric
Oct 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Saw motor runs but blade stops when try to cut
is the nut holding the blade tight and check that the notched spacer is aligned properly
Jul 10, 2009 | Saws
How do i remove the brake rotor from a 2003 toyota corolla? it seems that there is a special nut holding it on. i have looked for a socket but nothing seem to fit. Please help!!!!!
Have you removed the locking pin around the nut? There should be a metal ring with a dent notched into the nut you need to take out that notch in order to remove the nut.
Jul 07, 2009 | 2003 Toyota Corolla
Won't Spin
CHECK TO SEE IF SMALL CLIP ON BOTTOM OF PULLEY HAS FALLEN OFF. IF CLIP FELL OFF, THE PULLEY MIGHT OF SLIDE DOWN AND MOTOR SHAFT IF SPINNING. PUSH PULLEY UP AND ON END OF SHAFT ARE NOTCHES WHERE CLIP SLIDES ON. GE RECOMMENDS YOU REPLACE IT. MACHINE NOT LEVEL OR CLOTHES NOT BALANCED PROPERLY CAN CAUSE CLIP TO FALL OFF. HOPEFULLY THIS INFO HELPS.
Mar 17, 2009 | GE Profile WPRE6100G Top Load Washer
How to remove drum from any washing machine?
with the agitator out look near the bottom for a large flat nut with notches in it. a correct spanner wrench will engage this notched nut so you can unscrew it and the tub should come right out.
Aug 20, 2007 | GE WHRE5260E Top Load Washer
Zanussi WJS1397W Front Load Washer / Dryer Logo
52 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
