Question about Honeywell Maxon SL25 Two-Way Radio Battery Made by
Maxon SL25 How do you program the maxon SL25-U2-6 for frequences between 430 and 470 MHz.
  • 47 Answers
If the band assigned to the radio doesn't cover the frequencies you want then it will not happen. you need to get the software and the right programming lead. make sure the mic socket is good and clean
Posted on Nov 27, 2008
How do I change channels on my Maxon 49-sx
  • The "Maxon 49-SX" is a single channel transceiver that only operates on 49 MHz FM. The Maxon "49-FX" and "49-HX" operate on 5 adjustable adjustable frequencies. That radio has no channel/frequency options.
  • Hope this helps.
Nov 18, 2011 | Maxon 49-SX (1 Channel) 2-Way Radio
LOST MY MANUAL TO MY UNIDEN BEARCAT BC142XL CAN I GET A FREE REPLACEMENT
The manual isn't online to my knowledge however I did find a guide on how to program it.
"Turn it on. Push the "MANUAL" button to stop it from scanning.
Push number 1, then push "MANUAL" again. This should leave you on
channel one.
Using the keypad enter the frequency you want to monitor, then push
"E." Press "REVIEW" at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the LED readout
display, you might be entering an invalid frequency. Refer to the list
of acceptable frequencies in the Frequency Range Bands below.
Push "MANUAL" to step to channel number two. Enter the frequency. Push
"E." Push "MANUAL" to step to channel three. Repeat this process until
all the (10) channels are full, or you've run out of frequencies to
enter.
Push "SCAN" to start automatically scanning the frequencies. The
radio will stop when it hears someone talking, and resume scanning two
seconds after the conversation has stopped.
Frequency Range Bands:
20 to 29.7 MHz (10 Meter "Ham" Band)
29.7 to 50 MHz (VHF Low Band)
50 to 54 MHz (6 Meter Amateur Band)
136 to 144 MHz (Military Land Mobile)
144 to 148 MHz (2 Meter "Ham" Band)
406 to 420 MHz (Federal Government Land Mobile)
420 to 450 MHz (70cm "Ham" Band)
450 to 470 MHz (UHF Standard Band)
470 to 512 MHz (UHF "T" Band)"
http://newsgroups.derkeiler.com/Archive/Rec/rec.radio.scanner/2006-01/msg00174.html
Hope this helps.
Apr 22, 2011 | Office Equipment & Supplies
MCB 30, frequency
40 chanel CB operate from 26.9650 to 27.4050 mHz.
That is an AM rig
Mar 25, 2010 | Maxon MCB-30 40-Channels Base CB Radio
What frequency do these run?? am or fm??
CB or citizen's band is in the 27 MHZ band. Its 40 channels long, AM typically, and on some models side band, or SSB.
It is only legal in the US to have a radio that operates in the 27 MHZ band on the designated 40 channels using AM or single side band only.
The MCB-30 is an AM only radio.
I have a maxon sl55-u2 frequency radio only channels 1 to 4 work. why is this?
Only 4 channels have been programmed, you will need a programming cable to plug it into a computer and use the maxon software to programme the other channels to whatever frequency you need.
Nov 15, 2009 | Maxon Radio SL55, SP130, SP140, SP150...
PROGRAM FREQ IN BC142XL
Its so easy to use you really don't need a manual for the Uniden BC
142XL scanner.
Turn it on. Push the MANUAL button to stop it from scanning.
Push number 1, then push MANUAL again. This should leave you on
channel one.
E. Press REVIEW at anytime to see what frequency is programmed
there. If the review button flashes 000.0000 on the display, you might be entering an invalid frequency. Refer to the frequency coverage list below.
Push MANUAL to step to channel number two. Enter the frequency. Push E. Push MANUAL to step to channel three. Repeat this process until all ten channels are programmed, or you've run out of frequencies to enter.
Frequency Coverage:
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
Nov 07, 2009 | Uniden BC248CLT Base Scanner
Cant get weather on hand held scanner
The 92 does not have a separate/dedicated weather band feature, but you can program individual NOAA frequencies into it. Weather broadcast frequencies are: 162.400 MHz : 162.425 MHz : 162.450 MHz : 162.475 MHz : 162.500 MHz : 162.525 MHz : 162.550 MHz.
Apr 10, 2009 | Uniden Nascar BC-92T Scanner
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Jun 04, 2008 | Maxon SP-100G (4 Channels) 2-Way Radio
Maxon sl100
Hello baba_zam,
The Maxon SL100 can be programmed but doing so requires a programming kit including software and a specialized cable. Unless you are going to be reprogramming a lot of units regularly, you are going to be best served by taking the unit into your local Maxon dealer and paying them to reprogram it for you.
Best Regards,
Ken
"Go Ahead. Use Us."
May 31, 2008 | Radio Communications
Radio Communications Logo
1,082 people viewed this question
Top Honeywell Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Are you a Honeywell Radio Communication Expert? Answer questions, earn points and help others
