Question about Garland H283 Gas Kitchen Range
Gaffers & Sattler stove
Oven won't turn on, used it once and now it doesn't heat up...but smell gas, where is the pilot?
  • 125 Answers
The pilot is under the bottom oven deck, usually you can lift the front edge, and slide it out, smelling gas without a pilot would be bad, that means either A : your safety is bad, and allowing gas to flow anyway, which requires replacement, and you may as well replace the thermocouple, and clean the pilot. or B : it is old enough it does not have a protected pilot, and you have to manually light it, usually indicated by an open hole in the front middle of the oven deck plate when you open the door, with a tube going to the burner. or C : your oven burner is bad or misaligned with the burner, and is shooting gas away from the pilot area, it would light via an open pilot eventually, but you don't want that. Please let us know, or have a qualified servicer look at it. Happy New Year, and thank you.
Posted on Dec 31, 2008
My gaffers sattler gas oven stopped turning on. can not smell any gas when i turn it on.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
Jul 25, 2011 | Microwave Ovens
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
our 1985 gaffers and sattlers oven would not turn off tonight. Any idea? Its Propane oven
Dec 22, 2009 | Ovens
Have a Gaffers and Sattler furnace mod # 85 FDF ser # PV 09020. Pilot is lit, when I call for heat nothing happens. T-stat is okay, thermo couple okay/new. Fan will run when manually turned on at unit with...
When it call for heat you need a voltmeter to see if you have voltage at your gas valve. Check that first. You could jumper your stat between w and r to see if you have a bad stat. Rus
Nov 28, 2009 | Heating & Cooling
Hello I have a Gaffers and Sattler HVAC System the wind has blown out my pilot and I cant seem to locate were to relite
If you can see the gas valve there is a thin hard wire called a thermocouple that comes from the gas valve and ends uo in front of the pilot light and this is where you would relight the pilot if the pilot wont stay lit then you need to replace the thermocouple you can get one from any hard ware store
Nov 27, 2009 | Heating & Cooling
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Can't find the oven pilot on an old Gaffers and Sattler "Energy Saver Range with Uni Burners"
With the help from your site I was able to hold a match under the bar under the oven shelf toward the back and light the pilot. I am SO grateful. I hadn't been able to see it but just held a match toward the back, and it lit.
Feb 27, 2009 | Garland H283 Gas Kitchen Range
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Gaffers and Sattler vintage stove oven pilot 1956 W54 series similar problem
My mother had the same problem with her Gaffers-Sattler range. No one could figure out what was wrong with it. Her local new appliance repair people said to contact J.E.S. Enterprises, Inc at Whew; thank God for that tip. They knew exactly what the problem was and repaired the unit for her. The stove is running again like a workhorse! Here is their number - 805-643-3532.
Bob Allen
May 07, 2008 | Garland H283 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
1,613 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
