Question about Car Audio & Video
AUTO START WORKS ONCE EVERY 10 TIMES IF LUCKY
WONT START DONT KNOW WHO I CAN CONTACT, EVERYTHING ELSE WORKS FIND, I HAVE A 2005 NISSAN PATHFINDER.
  • Anonymous Jan 26, 2009
    I have the same problem. Autostart worked great on my 2004 Ford Focus for two years. Then stopped working well. Took it in to get batteries, connections checked, they gave me the no problems line. I can't start it from far away anymore, and most often it won; twork until I am right next to the car. A little chilly right now in Alaska.
    Scholar:
  • 71 Answers
What model of autostart do you have? have you checked connections. who installed it, can you call them?
Posted on Nov 27, 2008
2005 pathfinder crank over wont start
You have to test vehicles to find problems
You could have codes
Just need professional tools & the
knowledge to work on a vehicle
Aug 21, 2014 | 2005 Nissan Pathfinder
2005 Nissan Pathfinder, transmission solenoids and the TCM.
I would try orealys auto parts or dealership. not shure if pepboys would cary those or not, if they do they will charge you more than the dealerships, do to shiping and handling and processing . good luck
Dec 07, 2013 | 2005 Nissan Pathfinder
How do i correctly time a 2005 nissan pathfinder? having trouble with the secondary chains
where r the timing marks on the r51 harmonica balance cog can't see them anywhere
Apr 10, 2013 | 2005 Nissan Pathfinder
How long can I go on without fixing the timing chain on my 06 pathfinder??
tell it gos out all togetere .but if you dont wont to walk while you get a new motor . you should get it replaced now !
Nov 16, 2012 | 2005 Nissan Pathfinder
My 2005 Pathfinder is either Squeaking from the front of the truck. it sounds like the belt or pulley. In reading some articles about the 05 Pathfinder it appears this is a common problem. It seems the...
there was no recall for this but nissan did issue a tech. service bulletin for this complaint.essentially it instructed to check all pulleys for any misalignment.if they were ok then you were to install a countermeasure tensioner assembly and belt.contact nissan parts dept. they will know what you need.please let me know how it works out.
Feb 12, 2011 | 2005 Nissan Pathfinder
My 2005 nissan pathfinder wont start the theft sign is on and it wont go the chip key is good what coud it be?
IGNITION SWITCH SENSOR OR FAULTY IMMOBILIZER CONTROL MODULE.SCAN VECHICLE FOR A THEFT SECURITY FAULT CODE TO SEE WHATS MALFUNCTION.
Jan 25, 2011 | 2005 Nissan Pathfinder
Passenger door wont unlock, key turns in the lock but door wont unlock. Electric locks dont work. Driver door works fine 1991 Nissan pathfinder XE 4door
2006 Nissan Pathfinder rear passanger doors don't open unless opened from insinde handle first. Then will open all the time until central locking is used then same problem occurs
Apr 03, 2010 | 2001 Nissan Pathfinder
Changed battery on 05 nissan pathfinder. vdc
try and disconnect the pos battery cable for a bout 10 minutes and see if this resets it make sure you have radio code in case ur radio locks
Feb 21, 2010 | 2005 Nissan Pathfinder
Car won't shift from P to R auto trans in Nissan Pathfinder 2008
With the ac, sounds like you definitely have a short with the ac electrical wires. Have a mechanic check that out. 2. The wiring for the dashboard gauges may have tears or something is causing high resistance in them or you may need a new dashboard itself. Have that checked too.
As far as the brakes when you trying to change gears, what do you mean brake lock wont open? Finally with the RPM, I dont think your dashboard gauge is working correctly so you may need that replaced also.
Jun 18, 2009 | 2005 Nissan Pathfinder
Car Audio & Video Logo
198 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
