Question about Sony Mavica MVC-CD250 Digital Camera
No disc my screen on my camera reads no disc even after i load a disc
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
This is a system problem with the camera, and isn't anything you can correct. It needs to be serviced.
Posted on Dec 13, 2006
SOURCE:
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Sony boom cd/radio/cassette player says no disc and does not play even though the disc is spinning. The radio and cassette do work. We used a Dynex cd/dvd laser lens cleaner and it played for a short...
The laser diode is usually the first component to fail in optical disc players.
If you can, open the casing to expose the CD mechanism.
Point a cell-phone camera at the laser lens, which hides under a flat bridge.
Without a disc inserted, press play or eject / load the CD tray.
Via the camera, you should see the laser diode briefly flash as it tries to read data from where disc should be.
No flash means IR laser diode has probably burnt out.
Don't stare directly into laser beam for long periods with the ***** eye - rather use the camera as an interface.
The beam's visual color is red, but the CDS sensor of a digital camera sees the IR radiation as white on mobile's screen.
Dec 05, 2017 | Sony CD Radio Cassette Boombox, CFD-E90...
Screen reads no disc after loading even though a disc is in. Also sounds like there is rubbing when the disc rotates.
Hi. From what you describe it sounds like the spindle, the part you clip your disc onto, has been pushed down too far and needs to be pulled back up a touch, 2mm approx. images?q=tbn:and9gcsk5rvhv599ebybl98lpb6yljx3-4i0e_7adbhvdacrx2wbx_vs-w Image for clarification only.
Feb 19, 2011 | Mintek MDP-1760 Portable DVD Player
Xbox wont read brand new beyonetta disc
Possibly a bad disc? Check the back. Clean it with a soft damp cloth and then dry it with a soft cloth. If it doesn't work still, then return it.
Jan 28, 2010 | Microsoft Xbox 360 Console
DVD player locks up, won't read discs
its about time you get a new DVD Player...What type is it??? if it is a expensive one it is probably worth getting repaired but if it is a cheapy..then throw it away coz its not even worth looking at...there are the biggest pain to fix!! Best solution is to buy a new one!
Aug 11, 2009 | Televison & Video
Screen says loading dvd- movie never begins
Sounds to me like the laser has gone bad. What you are seeing is video that is the start screen. The unit is trying to read the disc to play. You could try to tap the unit on the side to jolt the pickup assembly as maybe its stuck in a spot but don't hit too hard and use a disc that you don't mind if it gets scratched. It probably won't scratch the disc but just in case. The Laser can go out even thou its only a year old they are made very cheaply now.
Hope this helps some.
May 07, 2009 | Televison & Video
Dvd is not reading
After loading a dvd screen prompts "loading" then "no disc." Even with a brand new disc.
Qaung
Dec 08, 2008 | Philips DVP5140 DVD Player
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
Jul 11, 2007 | Samsung VP-DC161 DVD Camcorder
Disc error
Try using a lens cleaning disc (any brand). You'll find them at Wal-Mart in the electronics section, or even in your grocery store, probably near the cameras.
Feb 07, 2007 | Sony RDR-GX300 DVD Recorder
Sony Mavica MVC-CD250 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
