Question about Compaq Presario 5000 PC Desktop
Unable to defragment
Need help it is and old computer
I couldn't get mine to work and had plenty of free space. I went to download.com and got a disk defragmenter. It works!
Posted on Mar 11, 2009
If you are running XP, while using the built in tool, make sure that no other program runs to interrupt its task,otherwise it may hang or restart. ( run it in safe mode) you need atleast 15% free space For this you can uninstall programs that you dont need, burn music, movies pics etc onto DVDs ets, run a diskcleanup(get rid of temp files, recycle bin files, older restore points) and you should be able to get some space free. Run a diskcleanup and chkdsk if needed.Go to Start>Accessories>Systemtools>Diskdefrag...Analyze the drive do as the report suggests. Just ensure there is no power cut during the process.
If you are running Windows Vista, its designed to defrag on its own and doesnt show a graphic or fragmentation visuals.
Alternatively to save yourself time and the frustration that sometimes arises from defrags that hang or restart, check out better a better defrag program like Diskeeper, which is automatic and once installed do the job in the background without needing any manual intervention. You can go about your normal PC work without any hassles even when it works.
Posted on Nov 20, 2008
    President:
  • 2,992 Answers
If defrag won't run at all and says you don't have enough room on the drive, you may need to delete some unused files. Defrag needs some empty space while it's working.
Defragging the drive is best done in safe mode so that nothing else will be running to interfere with the process. Turn your computer on, then after the Compaq logo screen comes up, press the F8 a few times (you're only supposed to have to press it once, but sometimes it doesn't seem to work). You should then get a startup menu. Choose "safe mode." Once Windows is running (the screen may look funny because of color and resolution settings) you can start defragmenting. Start this before you go to bed and let it run overnight. When it's all done you can shutdown and then restart normally.
Hope this is helpful.
Posted on Nov 19, 2008
Well, my ASUS X71SL-B2 17-Inch Laptop is running very slow, and I find myself unable to play any games AT ALL due to massive amounts of lagg. Now, this has been going on for a while, and its been bugging...
What it sounds like is that you may have a virus. Computers will tend to slow down after being infected with a virus. Not knowing what software you have installed you may want to try running anti-virus software. There are several available these programs can detect viruses and clean your computer. There are also several online programs available that will also clean and repair your computer if it is infected. You may first want to try some basic system maintance for instance,
In windows XP under system tools "Disk Clean up" and then run "Disk Defragment" both of these should be done on a regular intervals.
I hope this helps
Dec 14, 2010 | ASUS X71SL-B2 Laptop
My computer won't defragment what can i do about it?
if the computer refuse to defragment a partition it means that you do not have enough free space on that partition for the action ...so you need at least 15% free space ..the action to do is to delete some useless files or old ones you do not need anymore..and perform the action ..
Oct 01, 2010 | Gateway GT5692 Desktop Computer
During gamplay halo will slow down after 2 to 5 minutes it will go back to normal
awigle
In regards to your game slowing down most likely you are running into a resource/preformance issue on your computer.
First thing I would do is clear all your temp files. Your can do this by right clicking on my computer and then selecting properties.
Next click on Disk Cleanup. In Disk Cleanup make sure that all the check box are check except "Compress old file" (You can do this later if you want. Plus it can take as long as a defrag). Next click on OK, now all the temp files are getting removed.
Next go to the Tools tab and click on Defragment now and left click on Defragment button to defrag you computer. Note if you get an alert that you have less than 15% of free space on your drive this may point to the fact you do not have enough free space on the have drive for the virual memory to run properly. This too could be causing the game slow downs. If this is the case you will want to look at deleting unused games and programs from your system to free up some space.
After the defrag runs then you can go back and run "Compress old file" in disk cleanup. Note if you did uninstall any programs it will be a good idea to go back and rerun the defrag again to cleanup an fragmented files on the system.
Now at this point if you still have trouble you will want to look at your memory. If you have Windows XP you will need atleast 1gig of ram and if you have Vista or 7 you will need 2gigs of ram.
Hope this helps
Issken
Dec 17, 2009 | Microsoft Halo: Combat Evolved for Windows
My defrag program says it is unable to gain access to selected drive. It says another process may have the drive locked???
you need to close all open programs and reboot before you defrag
if you want a clean reboot go to start remove all programs from the startup file so nothing is in the background, if McAfee is in your start up file, it will prevent you from a complete defrag
start/all programs/startup click and drag each file in the startup back to all programs and then do a new reboot
May 11, 2009 | Computers & Internet
Unable to run disk fragmenter
It seems the chkdsk is not completing hence the problem. What version of Windows are you running? Do u have the installation cd with u?
Mar 11, 2009 | Dell Pentium 4, 2.26 GHz (1W391)
Unable to play missile command
Have you defragged the computer within 30 days?
if not, do so.
Does your "C" drive (HDD) have more than 15% of disc space left? if not, get it back to a minimun of 15%.
Do not use the computer while defragging.
Mastersage......................
Feb 15, 2009 | Hasbro Interactive Missile Command for...
Computer running slow
Have a look for an application called Ccleaner. Will get rid of all your old unwanted files. Also try a defrag.
Jan 12, 2009 | Computers & Internet
Cannot defrag my hard drive..
Go to Control Panel, Select System and select the Advance Tab. Now Select Settings Under Performance and again select the advance tab. Under Virtual Memory select Change. Make sure that the Paging File Size for selected Drive for the Drive partition you want to Defrag has either a custom at least 2 times the amount of installed RAM if the space is available or is set to System Managed Size.
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Dell Latitude D600 Notebook
Hey i need help whit warhammeronline
Have you defragged the hard drive, usually "C"? if not do so.... at least once a month.
Go to START>ACCESSORIES>SYSTEM TOOLS>**DEFRAGMENT**. Run it while you are not using the computer.
Nov 27, 2008 | Video Game Consoles & Games
Unable to defragement the system
xp will not allow defrag on disk requiring error checking. run error checking utility first.
Sep 03, 2007 | Intel Thread Checker 2.1 (ITC021WSGB001)...
Compaq Presario 5000 PC Desktop Logo
73 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
