Question about Whirlpool GH8155XJ Microwave Oven
No power to microwave, Whirlpool MH3185
My husband was changing the bulb under the microwave. It was stuck, and at one point there was a spark. Now we have no power to the microwave. Outlet is good. Is there some kind of reset button somewhere in the microwave? It is a Whirlpool over the stove kind, MH3185XPB. I really hope he didnt fry it!
  • 1 more comment
  • amyteller Nov 19, 2008
    I do not know where the fuse is on the microwave. The circuit breaker on the house is fine. The outlet that we plug the microwave in works fine.
    I would like to try and change the fuse ourselves. If someone could just tell me where to find it!
    We are in the process of trying to get a manual online, but if you could just tell me where to find the fuse, it would help!
    Genius:
  • 2,920 Answers
The fuse in near the back panel of the microwave where the cord runs into the back. it is inside the back of the microwave.
Posted on Nov 20, 2008
    Sergeant:
    Champion:
  • 200 Answers
Hi
Fuse/circuit breaker Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
Range/oven wiring There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Thank you
Posted on Nov 19, 2008
  • Thafa Nov 19, 2008
    Hi
    U can download ur user manual from the company site itself
    Thank you
    Brigadier General:
  • 6,966 Answers
Design wise, there would only be two locations for the fuse:
  • at the rear near the rubber grommet where the AC cord comes out inside a fuse holder; or
  • internally on the PCB (printed circuit board) right at the back of the LCD display/timer/button panel.
Just a thought, this would be the same fuse that powers the onboard electronics (not the heavy electrical) and therefore the unit would appear dead.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
    President:
  • 1,952 Answers
  1. No power to outlet (blown fuse or tripped breaker or GFCI).
  2. Blown main fuse - likely due to other problems.
  3. Open thermal protector or thermal fuse.
  4. Defective controller or its power supply.
  5. Clock needs to be set before other functions will operate (some models)
  1. Cabinet screws replaced in incorrect location (safety interlock not engaged).
  2. Any number of screwups.
  1. Defective triac (doesn't turn off properly).
  2. Defective relay.
  3. Shorting wires.
: Oven heats on high setting regardless of power setting.
  1. Faulty primary relay or triac or HV relay (not commonly used).
  2. Faulty controller.
  • 2,326 Answers
The fuse can be found just about where the AC power cord enters the microwave.
Click here to see how the fuse looks like and can be seen easily. The ratings should be 15 amps 250 volts, maybe you can try radioshack to see if they have them.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
replaced the fuse
unscrew it first and then locate the fuse
the fuse is located in the power supply
  • 541 Answers
I would buy a new one just for your safety
  • 101 Answers
Possibly the fuse is blown, its most likely a thermal fuse and you would need a professional to check out the microwave and replace it if everything is OK.
    Genius:
  • 1,550 Answers
Just check for fuse and circuit breaker .
How do I fix a blown microwave fuse?
How to Fix a Microwave Oven - Simple Fuse Replacement ...
? 18:04
https://www.youtube.com/watch?v=IN0BqiVX5ds
May 21, 2013 - Uploaded by GuruBrew
How to Fix a Microwave Oven - Simple Fuse Replacement. GuruBrew .... I'm hoping it's just a blown fuse ...
Whirlpool Microwave Keeps Blowing Fuses - YouTube
? 2:35
https://www.youtube.com/watch?v=KGQgendKTR0
May 7, 2013 - Uploaded by AdamDIY
Whirlpool Microwave Keeps Blowing Fuses ... MicrowaveThermal Fuse Replacement - GE Microwave ...
Microwave Oven Repair 101 ' DoItYourself.com
Dec 06, 2015 | In Microwave Ovens
GE OVER THE RANGE MICROWAVE OVEN (JNM1731DM1WW) HAS NO POWER
At this point from a practical and safety point of view best to have a shop look at this and see if it can be fixed for a reasonable price.
Dec 12, 2012 | Microwave Ovens
My whirlpool microwave model gh4184xsb needed a new cooktop light bulb so I removed the cover to replace it. I didn't unplug it (BAD!) and there were sparks and the microwave lost power. We repla
there are short. go to www.repairclinic.com for to get the parts.
2) test the switch door for short and replace see the diagram
3) test the high voltage capacitor+ high voltage diode
see the diagram
7_15_2012_12_42_08_pm.gif7_15_2012_12_42_27_pm.gif7_15_2012_12_42_40_pm.gif7_15_2012_12_43_03_pm.gif7_15_2012_12_43_25_pm.jpg
Jul 15, 2012 | Microwave Ovens
Changed light bulbs and now they won't go off when you hit the button
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
Dec 17, 2010 | Whirlpool MH1150XMQ Microwave Oven
Changed bulb in whirlpool microwave model mh1150xm know it wont work, i have clock and can set timer and cooking power but when i hit start it wont come on
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too, as well as other functions.
Jan 31, 2010 | LG Over-the-Range Microwave
Whirlpool microwave model #MH1140XMQ-1. I needed to change the light bulb on the bottom of the microwave that shines on the stove below. I started to turn the light bulb and the bulb seperated from the...
Or if you prefer, you can order a new control circuit board for it here for $140.10 plus shipping. (Just enter the model number as MH1140XMQ-1 without the dash).
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 04, 2009 | Whirlpool MH7140XF Microwave Oven
Short circuited Whirlpool MH1150XM while changing the bulb underneath. Need help to fix it, thanks :)
We replaced the board behind the control panel. $130.00. If you do this make sure you can put the wires back the right way. My husband finally got it and our micro is working like brand newThanks to all who tried to help.
Sep 29, 2008 | Whirlpool MH1150XM Convection/Microwave...
Broken bulb
From what others have said, it will come out, but you have to use some strong good needle nose pliers to turn the base in the socket.
Jan 12, 2008 | Whirlpool MH2155XP Microwave Oven
Microwave went completely dead after changing bulb-
Nom...you probably blew the internal fuse. This time...turn off the power. Remove the button panel and search for the blown fuse. It might be ceramic or of some other type. If on a circuit board, there will be a xxxA with xxx indicating the amperage. Use a multitester available at Ace or Radio Shack to test. Replace with the same kind of unit. Your local auto store, appliance parts guy, Radio Shack or Sears parts can get you the part you need. Show them the old one.
Dec 17, 2007 | Whirlpool MH3185XP Microwave Oven
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool GH8155XJ Microwave Oven Logo
201 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
