Question about MSI K8MM-V Motherboard
Motherboard MS 7005 v.1
Hi, my motherboard is written the following details in it: BIOS ROM checksum error when I turn on my pc. and it does not boot
  • gelosh Apr 15, 2009
    USB DEVICE NOT RECOGNIZED
Hi, i dont have the sound drivers for MS7005V1 and i dont find themany, one can help me.
Thanks
Posted on Apr 11, 2009
  • 781 Answers
Remove the small Motherboard battery for 5 minutes then replace and try again
Posted on Nov 20, 2008
I used jumper bios reset and now gettin bad checksum error. on the mother board writen that K8N rev 1.01 i downloaded k8n motherboard rom file and renamed as k8n.rom and copied to disket. its deleting and...
Hi.
The most probable reason you are getting the bad checksum error is you have to set the date and time because you have cleared the CMOS and reset the BIOS.
You should also get a message that says press F1 to load defaults or press a certain key to access setup. Access setup (BIOS) and set the date and time. That should take care of the bad checksum error.
Another good idea is make sure the motherboard battery is not dead either.
Regards.
Jun 17, 2011 | ASUS Computers & Internet
Can you please help me how to fix the BIOS ROM CHECKSUM ERROR. TO MY MOTHERBOARD (TRINITY 400 S1854 AGPX4-PCI-ISA) i reformat the windows NT version 4, and after i restart, the message come bios rom...
turn the computer off
now turn on and hold down the delete key until the bios screen appears
in the boot tab select first boot as the cd disk, install the cd for win nt in that drive
close down the cd and then restart and it will boot from the cd
BY reformatting the hard drive win nt you have wiped the win nt operating system from the hard drive
Feb 17, 2018 | Tyan Trinity 400 S1854 Motherboard
Computer will not boot. Beep error code is 2-2-3. Problem? Motherboard is micro star MS-9121 in an ibm intellistation
Hello the download site is here:
http://www.msi.com/product/server/E7505-Master-L-Series.html#/?div=Driver&os=XP%2032
Here you find the manual:
http://www.msi.com/product/server/E7505-Master-L-Series.html#/?div=Manual
Please select your windows system.
And unzip the file before you can use it:
A 1-2-2-3 beep code pattern means that there has been a BIOS ROM checksum error. Literally, this would indicate an issue with the BIOS chip on the motherboard. Since replacing a BIOS chip is often not possible, this Phoenix BIOS issue is usually corrected by replacing the entire motherboard.
More codes here:
http://www.computerhope.com/beep.htm
Good luck
Dec 20, 2010 | MSI E7505 Master-LS2 (MS-9121) Motherboard
sounds like your bios is corrupted, try going to the motherboard site and update your bios software. It could also be bad memory modules.
Nov 01, 2009 | HP Computers & Internet
My computer can not boot -BIOS ROM checksum error
to be honest if you have tried to re-flash your bios, and it did not work you still either have hte wrong version or the disc drive your using to flash it from is faulty. try another floppy drive/disc and try again. if that dont work. to be honest it's not worth getting it repaired just go out and spend £30-40 on a new mobo. sorry i'm not more helpfull but i dont believe it's worth spending that much time and effort on an old system like that with this kind of problem. good luck to you. let me know how you get on ok.
Jun 15, 2009 | EliteGroup K7VTA3 V5.0 Motherboard
Bios failure, or what?
Hi there.
Try clearing the cmos
d015d7b.jpg<<<<< you will see in the picture a plastic jumper (in this case coloured green), move it to the other position and hit the on/off button, then put it back in its original position and power up the machine again. Hopefully the issue will have been sorted. If there is no jumper remove the battery for an hour and make sure the power cord is removed from the back before you clear the cmos
Good luck and thanks for using Fixya!!
Feb 19, 2009 | DFI AK74-SC Motherboard
Checksum error
Hi Oliver, the most common error related to the message,
(Bios Rom Checksum Error). Someone has left a floppy disk in the floppy drive. Once the floppy disk has been removed press the reset button on the PC, your windows will start normally. Next place to look is in your bios.
Open your manual to page 27.
Enter your bios & go to the title Advanced BIOS Features. Check First, Second & Third boot devices they should be as follows. Floppy disk drive, CD-ROM drive & primary hard disk drive. If both of the above are ok than try clearing the cmos/bios by resetting the cmos jumper (JP1) location on page 5. Descriptions of page five on page 6. CMOS settings on page 9.
When your system restarts re-enter your cmos & reset up your bios settings. Lastly if none of the above has fixed the error message, than remove the cmos battery & check its voltage. It should maintain 3volts. If yours' is lower than 3volts replace the cmos battery. There is one other possible fix. It’s an option not given lightly. Flashing a cmos/bios is not recommended unless all other options have failed.
Bios link for the EliteGroup P4VMM2 V8.1
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=436&DetailName=Bios&DetailDesc=P4VMM2%20%20(V8.1)&CategoryID=1&MenuID=82&LanID=0
Main web site;
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=52&LanID=0
Good luck Oliver!
Mike
Aug 23, 2008 | EliteGroup P4VMM2 V8.1 Motherboard
Bad BIOS checksum.... CMOS bad checksum errors
BOOT BLOCK COMPATIBLE VERSION VER .005
BAD BIOS CHECKSUM
CHECKING FOR CD ROM
READING FILE "P5SD2VM.ROM"
NO CD-ROM FOUND
CHECKING FOR FLOPPY DISK
NO FLOPPY DISK FOUND
Does someone already fix this problem??????
Nov 15, 2007 | ASUS M2N-MX Motherboard
MSI K8MM-V Motherboard Logo
2,668 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
