posted by Claud on Dec 12, 2006
My Asko DW rips the circuit breaker at the end of the cycle. This happens with the heat turned off i.e. the heated fan dry is off. I cycled the selector switch through manually and the breaker tripped at the same point (just prior to 6 on the switch).
1 Other User Has The Same Problem
Comment by Guest, posted on Aug 12, 2008
Circuit breaker trips at timer position approx. 5.75
Solution #1
posted on Dec 15, 2006
I have seen a lot of these older dishwasher break the wires running up to the timer. the break right near the bottom of the door where they flex when you open and close it. I would turn of the power, remove all the torx screws along the inside edges of the door, as well as the 2 on the bottom edge of the door facing up (you cant see them, just gotta feel around for them) and loosen the 2 on the top of the door near the latch ( so you can tilt the control panel out to remove the outer door) follow the wires from the timer down to the bottom of the door and see if any are broken or missing insulation. If not, take the bottom panel of the dishwasher as well and locate the 2 terminals hooked to the heater and check them with an ohmeter to see if they are grounded to the frame of the dishwasher. the dishwasher may be doing a heated rinse just before the dry cycle even though you have low temperature and no heated dry selected, so the problem may still be the heater. Good Luck!
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Asko 1385 Dishwasher
Email this problem
Email this problem
This Problem Also Relates To:
Asko 24 in. D3350 Dishwasher
Asko D1706 Built-in Dishwasher
Asko D1876 Dishwasher
Asko D1996SS Built-in Dishwasher
Asko 1996FI Dishwasher
Asko 24 in. D3450 Dishwasher
Asko D3152XL Built-in Dishwasher
Can you Help with these Dishwashers problems?
Asko DW 95.4 dishwasher in New...
Hi, our machine has no power... Answer This...
error 6 asko dishwasher 1875...
Hi guys we get error 6 near the... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
