Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Side/Side Frig Model 57765791 Water dispenser quit.
I have a Kennmore side by side Frig Model 57765791 and the water dispenser just suddenly quit. I assume it is a switch or valve. What is the best way to test and how do I get to them ? Thanks
  • 3 Answers
  1. listen for click of the switch when you try and get water,
  2. make sure you have water to valve on back of refrigerator, turn off water and take line loose place in a bucket and turn water on, you should have a strong flow of water, it is common for people to have a self piercing saddle valve on the water line. these valves plug easily
Posted on Nov 23, 2008
Water dispenser not working on Kenmore refrigerator
Is it making any noise when you press the flapper if no then change water inlet valve
Dec 17, 2014 | Kenmore Side by Side Refrigerator
I can get water to the water dispenser in my side by side. but it will not make water. It's a Kenmore 22 side by side. I believe the model number is 9522611. We switched the wires on the solenoid and it...
the inlet water valve has a screen on the inlet in the valve which is probably clogged - replace the inlet water valve with a new one, install a ice maker water filter in the water line feeding the ice maker!
Jan 15, 2018 | Kenmore 56562 / 56564 / 565 / 6656569 Side...
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
Apr 24, 2009 | Kenmore 54662 / 54664 / 54669 Side by Side...
Remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Water dispenser not working on my Kenmore fridge
NO,YOUR RIGHT YOU NEED TO REPLACE THE WATER INLET VALVE ON THE LOWER BACK OF FRIG.-MIKE
Mar 01, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser in the door is dispensing water very very slow.
check and see if the ice is fully formed or look hollow / if hollow then run you a new water line to frig / if cubes are full then replace water valve.
Nov 24, 2008 | Kenmore 53642 / 53644 Side by Side...
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
234 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
