Fatal Error Code 173 - OKI 5100 copier
I recently installed a new fuser. It ran copies fine for a while then I got this error. Not sure if it is connected. Can you help?
  • tcs6 Feb 25, 2009
    I also just installed a new fuser. First copy was to be cardstock and a graphic. Can't even find the paper! How can I fix this?
  • 146 Answers
173 is a fuser upper roller low heat error.
Posted on Nov 26, 2008
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Hello i'm french, i have an oki c 8800 with : service call 173 fatal error. i don't understand what is this error and i want to know how to repare
Error code: 173
This error code means that the fuser temperature is low. You need to replace either the fuser or the thermistor inside the fuser.
May 27, 2011 | OKI C8800dn Led Printer
Code 173 for oki c5500
Service call 172:Error & 173:Error
Both errors mean -
Abnormal temperature detected by fuser thermistor (high-temp or low temp.)
Does error reoccur?
YES -
Turn power ON again. Replace fuser unit.
Jan 19, 2011 | OKI C5500n Printer
CAN ANYONE TELL ME WHAT 173:FATAL ERROR 2A14 MEANS?
Your Fuser is not getting to temperature. Make sure the printer is plugged directly into a wall outlet. If it is then you need to replace the fuser.
Jan 11, 2011 | OKI Electric Industry B4600 Laser Printer
Oki c5650, fatal error
tengo una impresora oki y me muestra error fatal en la pantalla que debo hacer para quitarle ese error de mi impresora
Apr 26, 2010 | OKI C5650n LED Laser Printer
Fatal error 173?
It points to an internal error. It may be from the fuser unit. Make sure all the wires are connected praoperly and that you didn't disconnect anything when you repalced the fuser. If the problempersists, you'll have to take it in for service.
Aug 20, 2009 | OKI C5150n Led Printer
Hi I have a Oki c6100dn Printer with fatal error message 173, How can I fix that
unfortunately, a 173 error is a fatal error which requires service, or technical skill on your part. It usually involves replacing the power supply board and fan.
Jan 27, 2009 | OKI C5100n Laser Printer
Service Call: 173: Fatal Error
That is a fuser erron code. Abnormal temperature. You will need to replace the fuser. Sometimes I have sen a buildup of toner on the thermistor. If you can get to it. You can try to clean the toner off. Be careful. Very hot.
Aug 10, 2007 | OKI C5150n Led Printer
474 people viewed this question
jasbo
jasbo
