Question about SuperMicro (370DLEO) Motherboard
My supermicro mother board can not pick this type of SDRAM PC133U-333-542, meanwhile the memory slot is SDRAM
    Champion:
  • 261 Answers
You are using the wrong memory.
A SuperMicro 370DLE only supports registered memory.
The U in the code shows that the memory you have installed is unregistered.
It will not work.
Exchange the memory for registered memory ,and the system should work fine.
Posted on Jul 03, 2015
2 Suggested Answers
  • 10406 Answers
SOURCE: The mother board will not post nor will the
Is the on/off button on the front of the computer-casing broken?
Take a volt-meter, and run a continuity-test.
Are the two wires from that button both properly connected to a pair of pins on the motherboard? If you disconnect the wires from those pins, and use a metal screwdriver to very briefly "short" the two pins, to simulate the pushing of the ON/OFF button, does the motherboard post? Do fans start to spin, or at least "twitch" a few degrees?
Have you tried a different power-supply?
Is there any lamp on the motherboard that lights-up anytime that
the power-supply is connected to AC power? Is that lamp on?
Posted on Nov 19, 2009
What is the max size of ddr400 memory you can fit into ddr1 & ddr2 dimm slots on a p4vm8 mother board
1) Total maximum amount for motherboard is 2GB.
2) There are 2 Ram Memory slots.
3) Maximum amount for EACH ram memory slot is 1GB.
Either DDR Sdram at 266MegaHertz, or 333MHz, or 400MHz.
PC2100, PC2700, and PC3200, respectively.
http://www.asrock.com/mb/VIA/P4VM8/
There is no DDR1 and DDR2 slots, in a manner of speaking.
May be marked on your motherboard that way, but stating it that way on a computer product support website = No.
You're going to make someone think, you don't know what you are talking about.
They may think you are referring to DDR Sdram, and DDR2 Sdram, and they know the motherboard only uses DDR Sdram ram memory.
Suggest state Slot 1 and Slot 2; or DIMM 1 and DIMM 2.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 18, 2013 | VIA ASRock P4VM8 P4(S478)/...
Supermicro x8sax memory bank issues
The X8SAX motherboard has 6 memory slots. Try booting with one memory stick in each slot to identify which memory bank (dimm slot) is giving you issues. If you are able to boot off of a good slot, check the BIOS version to make sure you have the latest installed (R 2.0b). It can be downloaded here: Super Micro Computer Inc Products Motherboards Xeon Boards X8SAX
If you are unable to get into the BIOS at all, check the warranty status and submit an RMA request to Supermicro:
http://www.supermicro.com/support/rma/
Mar 01, 2012 | SuperMicro Desktop Board - X8SAX...
Can i use DDR2 RAM instead of DDR1
YES, if your motherboard accepts DDR Sdram, and DDR2 Sdram ram memory. If your motherboard has both types of ram memory slots.
BUT, you can ONLY use DDR Sdram, OR, DDR2 Sdram.
You Cannot use both types of ram memory in the motherboard, at the same time.
(BIOS will only recognize one type at a time)
NO, if your motherboard does not have ram slots for both DDR Sdram, and DDR2 Sdram ram memory.
Double Data Rate Sdram ram memory modules, have 184 gold plated contact pins on the bottom.
92 on Each side,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can click on the above photo to enlarge)
DDR2 Sdram ram memory modules have 240 contact pins.
120 on Each side.
Sep 04, 2010 | HP Computers & Internet
I have 2 slots, currently only one is in use, it has 512 DDR 400 MHz PC 3200U. Can I use both slots and how much RAM will my SiS 963Lua support? Thanks. Richard
Hey Richard, your board has 2 x 184 DIMM slots, that are both usable, with a maximum capacity of 2GB, supported RAM types are 333MHz, and 266MHz..
Hope this is what you are looking for,
Cheers,
Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 333 MHz • 266 MHz Max Supported RAM 2 GB
Apr 09, 2010 | Foxconn K7S741MG-6L Motherboard
I need to know the correct ram speed for the Asus P4B533 board, thanks.I have 3 slots. I want to install the maximum possible.
here you go mate:
Memory Memory Type DDR SDRAM Number of Memory Slots 2 x 184 Pin DIMMs Supported RAM speeds 266 MHz Max Supported RAM 2 GB
Dec 01, 2009 | ASUS P4B533-VM Motherboard
I went and bought new ram for my computer. it's an IBM desktop. type 6792. a pc133 512MB sdram. my computer will not pick it up. how do i get the computer to pick up the ram? it is the right kind of ram?
I checked at http://www.buffalotech.com/products/memory/select/select-dimm/ and according the the memory configurator there your IBM Netvista 6792 takes this type of memory which can be ordered from them PC-133mhz SDRAM DIMM 168 pin, it indicated that your pc has 3 slots for memory and the maximum size you can put in each slot is 512 MB which would give you the maximum memory of 1536 MB. I have had problems in the past when replacing memory in IBM PC's some modules won't work because IBM uses different memory than other Manufacturers. But give Buffalo a try, their memory is guaranteed.
Apr 05, 2009 | IBM NetVista PC Desktop
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
New Motherboard for Sony VAIO-RX550
I just bought the same box, mostly for the case, power supply, etc, to use as a small server.
Three ARE 2 ram slots, but this motherborad IS limited to 512mb total. And it uses SDRAMM PC133 or 100, not SO DIMM - incompatible. PC133 SDRAM 512 is $9 (btw, installing in pairs not required on DDR SDRAM) and even if your existing is 256 & an empty slot, buying another 256 may not work, sometimes brands are incompatible. Just get the 512.
However, replacing the motherboard is your ONE chance to change lots of things at once which may be the best choice at this point. Physical size ("form factor"), CPU socket, memory type & price, graphics connections (AGP, PCIe, or built in) are key factors.
1\ the case fits a "Mini ATX" mother board (mATX). The majority of accessories use PCI lots - sound, LAN, etc. and every mother board will have 3 or more PCI slots. Probably don't need modem anymore.
2\ what CPU does it support. The original P4 1.5GHz cpu is normally a primary expense, but today your P4 Socket 478 is worth $8 (pricewatch.com) brand new. This means buying a motherboard-cpu combo may make sense. While you're at it, get more & faster memory and you'll think it's a new PC for less the $100 unless you go all out.
3\ what type & how much memory it handles & how much you have. Existing PC133 SDRAM is old & slow, about 8x faster SDRAM ddr2-800 pc2-6400 2GB is only $24 and 2GB is about the minimum today. (btw, DDR2 - notice the 2 - IS installed as a pair.) DDR is far from current, but plenty fast and very cheap, just need to balance the memory-motherboard-cpu combo.
4\ if not playing games, the video card is old but ok. It connects via the largely discarded AGP slot. So in looking at a motherboard combo, either with an AGP slot or on-board video is desirable.
Mar 11, 2008 | Sony VAIO Digital Studio PCV-RX550 PC...
SuperMicro (370DLEO) Motherboard Logo
102 people viewed this question
Top SuperMicro Computers & Internet Experts
Tony
David
David
Victorman
Victorman
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
