Question about Canon EOS Rebel G-II 35mm SLR Camera
FILM WON'T LOAD
MY CAMERA WON'T LOAD FILM SO I CAN START TAKING PICTURES. WHAT DO I NEED TO DO OR TELL ME WHAT IS WRONG WITH IT.
    Top Expert:
  • Canon Master
  • 14,162 Answers
Posted on Jul 18, 2016
SOURCE: Rebel EOS Rebel SLR film camera-pictures develop like film was exposed
The shutter is most likely damaged.
Posted on Dec 07, 2007
SOURCE: nikon n75 problem loading film
I have (had) the same problem. I came onto this site to find out what I can do to fix it. It didn't help. I got pissed and almost threw the camera away. So I decided to get a little rough with the camera, (i normally wouldn't do this but i was going to throw it away).
I loaded the film like normal but before I closed the back I manually wound the film around the opposite spool. I guess I fooled the camera into thinking it had already wound the film.
When I closed the back of the camera everything worked fine.
I then snapped off the pics the camera said were left.
After this first role, I loaded the next role like normal. The camera worked like a charm!
By the way...the mirror dropped back down when I manually wound the film around the spool.
I hope this works...if it doesn't make any sense feel free to email me with any questions..
GOOD LUCK.
andy
amasseur at gmail dot com
Posted on Feb 09, 2008
  • 14 Answers
SOURCE: LOADING FILM INTO MY CAMERA
Camera will not fire with dead battery so you will not be able to advance film to #1.......ck out www.flcamerarepair.com for help
Posted on Jun 29, 2008
  • 185 Answers
SOURCE: Vivitar PS:35 camera
Try putting a little pressure on the back door right of the finder. If the counter worked, then when film is finished and removed with the back door open you can see a metal lever in the slot that the door fits into. It should be straight vertical if not straighten with a needle or pin to vertical.. No parts are avail. for this model.
Posted on Dec 07, 2008
  • 148 Answers
SOURCE: film wound on wrong side of camera
It sounds like you have a jam.  When you have finished taking shots and have used all the film, you must press the film-rewind button on the underside of the camera; this does not rewind the film, but allows you to commence the next step.  Once you have done this, flip up the rewind-crank on the top left hand side of the camera. It is situated on top of the film speed dial. turn this clockwise until all the film is back in its cartridge.  You should now be able to open the back of the camera.
I hope you have fun with your t50!
Posted on Dec 11, 2008
The film wont roll out as i take pictures
Are you sure the film is attached to the take-up spool ?
Sep 13, 2017 | Pentax K1000 35mm SLR Camera
I just bought a Minolta maxxum QTsi from a lady and it had no manual with it, I can't figure out how to load the film. Can you take me step by step on how to load the film and how the camera works when...
Hi, I've found the instruction manual online for you, http://www.mediacollege.com/equipment/manual/konica-minolta/camera/maxxum-qtsi.pdf that way you have it for future reference. For loading film you open up the back of the camera and make sure that the end of the roll of film is aligned with a red mark and then you close the back. For taking pictures you press the shutter button half way in order for it to focus, when the image you want is framed you press the shutter button the entire way and it'll take the photo.
May 13, 2011 | Minolta Maxxum QTsi 35mm SLR Camera
Developed film pictures have black around the edges
My guess would be that whatever lens your using is causing that. The black edges are basically caused because the lens may not be fit the camera correctly, causing the camera to "see" part of the lens itself when taking a photo.
May 03, 2010 | Pentax Photography
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Feb 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
Loaded film blank
Chances are the film had quite a bit of curl to it (often a sign of old film) and it was not pulled over quite far enough during auto loading, or perhaps too far and it had too much slack that the take up reel never grabbed it to advance it thru. You're not the first one this has happened to as the auto load is not as reliable as the older style where you had to load the film leader through a slot in the take up reel.
Dec 19, 2008 | Nikon F65 35mm SLR Camera
Film wound on wrong side of camera
Dec 11, 2008 | Canon EOS-AE-1 35mm SLR Camera
Jun 27, 2008 | Photography
i went to the public library and got a copy of the manual
Apr 05, 2008 | Konica Minolta Maxxum 5 Date with 28-80...
Developing pictures
depending on the type of film you are using and where you are taking it could be the problem. if you are using professional film and taking it to a pharmacy to get developed, the chemicals used at these places will erase the images off the film and appear as if the film is blank.
Nov 11, 2007 | Nikon N75 35mm SLR Camera
Pictures didn't develope
Looks like you are not loading the film onto the take-up spool correctly.
Go back to the development store and ask them if they can give you a spool of waste film (e.g. one that got exposed to the light or something). Otherwise buy the cheapest film you can find.
Load the film in the camera. Take a few frames. Open the camera back up a bit, the film should have advanced. You will be able to tell this because there is more film on the takeup spool. The frames are also numbered nearby.
It might take you a few goes to get the film to load correctly. If no luck, maybe the file wind-on is broken and the camera needs repair.
Nov 05, 2007 | Nikon N65 35mm SLR Camera
Canon EOS Rebel G-II 35mm SLR Camera Logo
99 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
