Question about NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111)
Cant connect wirelessly
I have a netgear Dg834N wirless router which works fine when conectedwith an ethernet cable, however when i try to use the dongle supplied to me withthe router a netgear wg111t it cannot find any wireless signal, even though the router is not far away and i have no other wireless devices in the house. i can pick up a neighbours wirless signal so i know the system works, but it will not pick up the signal from my router. is there a problem because the router is an N model and the dongle is a G model, is isthere something else? do i need to by an N dongle? and if so which ones will workd with windows XP?
    Problem Solver:
  • 10 Answers
GET INTO THE ROUTER SETTINGS USING WWW.ROUTERLOGIN.COM OR HTTP://192.168.0.1 changed CHANNEL TO 11, mode: G&B
and under
Wireless Access Point
Enable Wireless Access Point and Allow Broadcast of Name (SSID) should be checked
Wireless Isolation should be unchecked
it would work..
Posted on Aug 30, 2009
  • 854 Answers
Wireless Adapter Installation
A. Install the software.
Note: Firewall and anti-spyware need to be disabled. They sometimes treat software installation as a behavior of a spyware and therefore will prevent installation.
Windows XP:
1. Please power on your computer. Allow the operating system to boot up completely and log in as needed.
2. Insert the NETGEAR adapter Resource CD into your CD-ROM drive. The CD main page shown at the right will then load.
3. Click the Install Driver & Utility.
4. Please make sure that you follow the Install Shield Wizard steps. Click Finish when done and turn off your computer.
Windows 2000/ME/Win98SE:
Note: Windows 2000 may require you to be logged on with administrator rights.
2. Insert the NETGEAR adapter resource CD into your CD-ROM drive. The setup page will then load.
3. Afterwards, click on the Install Driver & Utility link.
4. Make sure to follow the Install Shield Wizard steps, and click Finish when done to restart your computer.
B. Install the adapter.
Windows XP:
1. Please make sure that you shut down the PC first and then remove the power cord.
2. Please insert the NETGEAR adapter into the available expansion slot.
Note: If you have PCI adapter, connect the antenna to the adapter, making sure the antenna is in the upright position.
3. Reconnect the power cord and reboot the computer.
4. When the Found New Hardware Wizard displays, please click on Next and then follow the prompt. If you are prompted with a Windows XP Logo testing message, just click on Continue Anyway.
5. After the installation completes, click Finish to close the wizard.
2. Insert the NETGEAR adapter into the available expansion slot.
4. On the Found New Hardware Wizard, click on Next, then follow the prompt to proceed.
5. After the installation completes, click Finish to close the wizard. Please make sure that you can see the NETGEAR icon located at the lower right portion of your computer screen.
Note: If Windows displays Digital Signature Not Found warning, click Yes to continue.
C. Configure the NETGEAR adapter.
1. Please Double click on the NETGEAR icon on the right lower end portion of your computer.
Note: If you do not see the icon, click on Start and go to Programs. Locate the NETGEAR Utility and click on the NETGEAR Smart Configuration Utility.
2. Click on the Networks tab.
3. Click on the Scan button.
4. Select the Network Name or SSID of your wireless network.
5. Click on the Connect button.
6. You will be directed to the Settings tab.
7. Type a name for the Profile.
8. The Network Name (SSID) will be the same with your wireless network.
9. Make sure that the Network Type is set to Access Point (Infrastructure).
10. Select the Security that you are using on your wireless router.
11. Click on Save Profile.
12. Click on the Apply button.
Posted on Aug 13, 2009
    Scholar:
  • 124 Answers
Yes u have to buy a netgear N dongle ...
Because N works on 5 ghz and G works on 2.4 Ghz
You can buy netgear WN111v3
Posted on Jul 13, 2009
My netgear wireless-N 300 modem router dgn2200
IF YOU WANT TO USE NETGEAR AS A ROUTER YOU PLUG THE ETH-CABLE TO IT AND START LOOK IN THE PC FOR WIRELESS NETWORK.ON THE OTHER YOU CAN CONNECT YOU DSL CABLE DIRECTLY TO YOUR PC.
Apr 11, 2012 | NetGear Computers & Internet
After firmware upgrade the no wireless signal and the router is not recognized by my laptop even if I connect it thru lan cable
You may have taken a bad update try factory default if you get in try to download from verified site new firmware
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
Apr 01, 2012 | NetGear DG834N Router (DG834N-100AUS)
I cant get my netgear N300 wireless router to work with Netflix on Playstation 3. says ethernet not found on tv
ethernet not found means there is no connection via the cable to the router.
have you configured the wireless settings on the ps3?
Feb 27, 2011 | NetGear Computers & Internet
Connection problem. shows limited connectivity and disconnects
limited connectivity means you didn't get an IP address. Is the router set to give addresses via DHCP, or is another PC doing that? Most common cause of this problem is wrong authentication (normally "open") or encryption type (WEP, WPA or WPA2). Pklease note that encryption keys can be set as HEX or ASCII, if they are HEX it will be only numbers 0 to 9 and letters A-F. ASCII can be anything.
Jun 01, 2009 | NetGear DG834N Router (DG834N-100AUS)
Motorola Surfboard 4220 not working with my Netgear WGT624 router
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please rate.
Mar 23, 2009 | Arris SURFboard SB4220 Modem
I have a Netgear WGR614v6 , cant get wireless to work with modem
you might of entered the wrong WEP password to asess it wirlessly.
Jan 01, 2009 | NetGear WGR614 Wireless Router
NetGear WGR614 Wireless Router Problem
dear leetheone,
your network wireless is not properly set up. you have to properly set this, try using the windows wireless wizard and follow the prompts.
sid
Dec 02, 2007 | NetGear WGR614 Wireless Router
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
NetGear : WG111 54 Mbps Wireless USB 2.0 Adapter, RETAIL (DSNGWG111) Logo
234 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
