Question about Sony KP-53V75 53" Rear Projection Television
Speaker Off/On When trying to turn the speaker function on nothing happens. I can use the speaker through the center channel & SAVA SP setting from my receiver so I know the speaker does work. It appears that the switching works from OFF back to Center ( I hear it "click") and from ON to SAVA SP (I also hear a "click") but between OFF and ON there is no "click". It seems to treat ON and OFF as OFF.
  • Jay Finlan Jan 11, 2007
    In addition I'd like to clarify: The speaker on the television works as a center channel only when I run speaker wire from my receiver to the speaker connector behind the tv. The speaker does not work on any internal setting when using ANY video/audio input. The settings I spoke of are all accessed via the setup menu on the tv.
If I am reading your symptoms correctly, it sounds like you are getting audio to your surround sound receiver, but not your TV speakers? If that is the case, I would be checking for a defective audio output IC and possibly an IC Protector fuse connected to it.
Posted on Jan 11, 2007
Front speakers 5.1
Turn up the volume on the left or right speakers or turn down the center channel volume to meet your preferences. There should be a setting for that in most receivers.
Jan 17, 2014 | Pioneer VSX-454 Receiver
Yamaha rx 530 center channel cuts out
Thanks for all the suggestions guys.
I've tried using the balance for left and right speakers, and when the receiver is acting up with the right speaker having a low volume, I tried moving the balance all the way over to the right speaker. The right speaker volume will not increase in volume but the left speaker will decrease in volume.
Just to clarify, the center and the rear speakers are balanced. The issue only happens sometimes when I first power on the receiver I will have no center channel. If I leave everything alone for a few mins, the center channel will come on.
So it seems to me that something one the receiver is going. The question is, can anyone suggest a physical repair for the receiver for these symptoms?
Thanks
Jul 20, 2012 | Yamaha RX-V530 Receiver
Ihave a sava-500 home theater speaker system i dont have the cord to connect the 2 tower speakers will this affect the sound from the main speaker using the av input
With not all the speakers hooked up, it will definitly effect the sound. The unit is designed to channel different sounds to certain speakers. That's what makes you feel like "you are there" If you have lost the cords to the tower speakers, you can buy replacements. Go to where you bought the unit, a Radio Shack, or other store that sells home theater systems. Enjoy your system like it was designed .
Apr 16, 2010 | Sony SA-VAD900 System
Rx-v1800 with check sp wires problem,narrowed it down to the center channell speaker which is 8ohms the rest of the speakers are 4ohms center speaker checks out fine on other receivers,could the ohm...
So are you saying the error goes away when you disconnect the center speaker and its cables? Sounds like you have one more step to isolate the exact external component: try a different speaker as the center and/or try a different speaker cable.
Did you set the speaker impedance (Page 33 and 117) to 6-ohm min. AND - the manual does actually say "the impedance of each speaker must be 6-ohms or higher" for all BUT the Front speakers.
Mar 23, 2010 | Yamaha RX-V1800
B speaker setup problem
Why don't you set it Zone 2 then you could listen to the radio outside and still watch tv inside. You can turn it on and off just like a and b speakers.
Jul 07, 2009 | Yamaha RX-V663 Receiver
Receiver is shutting down.....
First, I have to compliment you on a thorough and comprehensive problem description and an apparent sense of how to troubleshoot. We're halfway there already.
Your Blu-Ray / PS 3 statement is intriguing but with the E-1 code that absolves it as the problem.
You have two opposing symptoms: the live failure says you have a short while the test mode implies an open circuit. We have to isolate everything and see if it moves to another channel.
Let's run with the "E-1: NO FRONT SP" error. I think it's trying to tell us we have an intermittent sensation of an open wire in one of the Front speaker channels. * Unfortunately, the manual doesn't break out Left and Right (but I'm sure the receiver knows) to help us isolate. You say it doesn't get past the Left test. I need you to decide by listening to the Left Front Speaker setup routine if it's really working or not, and if it seems to be working, maybe the receiver is really failing at the point it advances to the Right Speaker, assuming Right follows left in the sequence.
Verify for me: You swapped the two front speakers Left to Right and replaced both speaker wires with NEW wires and had no improvement.
I'm wary of a failcode that doesn't identify which of a pair is failing, so I 'd like to see ALL NEW speaker hardware and connections in place to avoid the pitfall of swapping the L & R with each other and having one of them be the problem without changing the symptom.
We can accomplish this easily: Try temporarily running the rear speakers as the Fronts just to see if the test can pass. If so, test the Fronts as if they're the Rears speakers. You should be able to just swing the receiver-ends of the cables among the speaker posts.
Something should change or else the problem is internal to the receiver. Good luck.
Apr 28, 2009 | Yamaha RX-V663 Receiver
Center channel audio distortion and noise
I have similar problem with my Onkyo Tx-SR600. It only happens when it's in surround mode. When switch to Stereo or Direct, the scratchiness go away. Still trying to find a solution to this problem.
Apr 27, 2009 | Onkyo TX-SR606 Receiver
Center speaker channel
audio amplifier is the main problem,check some resistors in audio out.
Oct 21, 2008 | Sony STR-DE475 Receiver
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Speakers being bypassed
I would get a copy of the manual first. Check the speaker settings in the menu or front panel to deterimune if the "A" channel for the front are turned on. Center speaker will work under Pro logic settings(all). A stero source is required for at least Pro Logic processing. I looked unit up on e-coustics and found some speaker set-up problems related to input level.
Apr 29, 2007 | Audiovox 150W DVD Home Theater System -...
Sony KP-53V75 53" Rear Projection Television Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
