Question about Neon GREEN PC POWER SUPPLY KIT Power Supply
NEON SIGN WON'T WORK
I PICKED UP A NEON SIGN THAT WON'T LIGHT. THIS LIGHT HAS A POWER CORD AND THEN ANOTHER CORD OF WHICH I DON'T KNOW WHERE IT GOES. IS THERE A SUPPLEMENTAL POWER SOURCE THAT I NEED TO MAKE THE LIGHT WORK?
  • 56 Answers
If It is actual Neon Tubing. It Takes a High Voltage Transformer to light the tube.
I work in a sign shop and we commonly use 8000, 12000, & 15000 volt transformers.
These types of transformers are like "Lightning In A Box". Unless you know what you are doing It could kill you! Any reputable sign shop should be able to give you a idea what you have for FREE, and the safest and cheapest way to get it working...
Posted on Nov 23, 2008
Which is advanced or better : Neon or LED illumination?
LED lighting is more advanced. Neon has a long history, having been used for nearly a century.Though Neon has the brightest lighting capacity, it requires maintenance. Neon emits more energy than LED lights. LED works in any climate. This makes LED a very reliable optionfor illuminated channel letters. They require much less maintenance and are more energy efficient than neon. Neon signs are easily broken. Being made of glass, they leak. LED does not have this problem . Once you get a neon sign, there's no changing it. Custom LED signs can be updated as often as you like, with whatever messages you like. Custom LED Signs Toronto Single Double Sided New Style Signs
Jul 31, 2015 | Neon Sign Inc Old Style New Orleans...
My neon sign gets half way through light and stops, but it will follow the touch of the glass
Sounds like that neon sign might be lacking the proper amount of the gas inside of it. By touching a segment and then it will light you are increasing the capacity around that segment. An old trick is to place a piece of aluminum foil in back of the segment that does not light and see if that works. Other then that you may want to try a larger transformer but you shouldn't leave the light on for prolonged times because the electrodes at each end will get very hot possibly causing the glass to melt. Good luck.
Mar 24, 2014 | Neon GREEN PC POWER SUPPLY KIT Power...
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
The battery on my laptop stopped charging, but was working for a over a week, then it was acting funny and slow.. I shut down moved to another room and it won't boot up! The light doesn't come on...
I think your power cord is bad. It probably was not charging the battery at all and so now all your battery power has drained since you were running on it. Once the battery power is drained and if the AC Adapter Power Cord is not working the computer will not boot because it has no power source.
Some AC Adapter & Power Cords have lights on them to let you know when it is plugged in if it is working. Normally when you plug the power cord in the laptop somewhere on the laptop lights up to let you know it is receiving power. Sometimes the light is where you plug it in, sometimes at the front of the laptop or right above the keyboard area.
I thing you need a power cord. And don't settle for one of the one size fits all (with a removable tip designed to fit any laptop) that the big box stores will sell you.
If your power cord is good and the laptop is not receiving power then the problem could be your DC Power Jack where the power cord plugs into the computer.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Apr 03, 2012 | Acer Computers & Internet
Sony laptop dead problem
Could be many things. Let start with a couple of easy ones.1) Unplug charger from computer and outlet, take battery out press power for at least 30 sec. Plug every thing back power on. 2) charger bad won't turn on or charge battery, try diferent charger if don' know how to use a voltmeter. 3) power jack loose or broken. 4) last and worst mother board circuits transitors etc... btw processor, video card or input devices fried. Buy new board from ebay. Don,t fix it. Not worth it. This is Only if laptop gives completely sign of not turning at all. No lights, no hardrive or no working or fan. No signal of life. If couple of lights do turn on it can be the ram or video card, play with ram a bit. Good luck.
Dec 09, 2011 | Computers & Internet
Brake light dodge neon 2002
Check the brake fuse in your dash's fusebox. Since the turns work, you know the bulbs are good, unless your Neon has separate brake lights. If the fuse is good, bulbs are good, then check for power at the brake light switch on the upper portion of the brake pedal. Should have 12 volts there all the time. Use a testlight or voltmeter to check. Good luck.
Nov 19, 2011 | 2002 Dodge Neon
I have an Acer Aspire 5251-1513. I'm not sure, but I think that the fan isn't working. It usually makes some noise, not enough to be bothersome, but enough that I know it's running...yeah. it hasn't been...
Common fault is the little socket where you plug the power supply into goes intermittent, annoying, works sometimes then stops. It's likely you need to get that repaired, the laptop will work with a poor battery but not a poor power lead..
before you go down this road just make sure the little plug on the power lead is not broken inside due to being pulled in and out of the socket thousands of times. Try it on another laptop..!
good luck !
Mar 30, 2017 | Acer Computers & Internet
Vizio 32 no power
http://www.encompassparts.com/models/?VIZVW32LHDTV10A justmanuals.com
do some research, pick out a weekend, and then replace that power board! save yourself some $$$ but make sure you order the right part and know what you are doing before you start.
Jul 17, 2009 | Vizio L32 32 in. LCD HDTV
1998 neon wont start it has power toanew starter but doesntcrank
go to a auto parts store and pick up a repair manual it will help
Jan 30, 2009 | 1998 Dodge Neon
Neon sign lights up inconsistently
If you are a trained person that knows how to measure electricity and switches, I would use a multimeter with the power off, and check the switch. Other than that it actually sounds like your ballast(transformer) is going out. They can be picked up pretty cheap at Lowes or Home depot. Good luck.
May 21, 2017 | Neon GREEN PC POWER SUPPLY KIT Power...
Open Questions:
See all Neon GREEN PC POWER SUPPLY KIT Power Supply Questions
Neon GREEN PC POWER SUPPLY KIT Power Supply Logo
933 people viewed this question
Top Neon Computers & Internet Experts
David Payne
David Payne
Are you a Neon Computer and Internet Expert? Answer questions, earn points and help others
