SOURCE: Can I download a user manual for Tadpole 23 tent?
I wasn't able to find a manual, but after looking at the website, the tent looks fairly easy to set up.
Lay the tent out flat and peg down four corners. Then take the longest two poles and put them diagonally through the tent sleeves. Then, put the third pole (for the doorway) through it's sleeves.
Next, you'll have to put the pole point into the hole at either end. Then, go to the other end and bend the pole until you can get the other end in the corresponding hole. Do this for the other diagonal and the tent should be standing. The last one is the door pole
Last, lay the rain cover over the tent. There should be some hooks to strap the hood down near the poles. Don't worry about any strings, etc. Those are for high winds and almost never needed. Good luck
