Question about Dell InspironTM 1501 Notebook
My mouse moves but I can't click on anything.
I start my computer in normal mode and it loads just fine. Then when it gets to the desktop after putting in my password it doesn't allow me to click on anything. It just shows the circular blue loading symbol. How can I fix this?
  • 458 Answers
Reboot, and press F8 choose to boot in Safe Mode
Once at the desktop Click on Start and Type : MSCONFIG in the search box
in the System Configuration Utility PopUp Window, Choose the Start Up Tab...
Remove by unchecking all Unnecessary and not needed Programs From Running Then Reboot in Normal Mode
Posted on Nov 19, 2008
Replace the mouse, if thesame proplem persist then the operating system has catch virus, re-instal your operating system
Black screen on HP Touchsmart 310, any ideas?
i guess your computer is suffering from Software Driver Conflict.
because in safe mode, windows does not load any third party drivers, but its own. so your computer turns ON.
it it NOT AT ALL any hardware related issue, so you dont need to buy/replace anything.
tell me more about your operating system and your computer details, so i can help you properly
Mar 04, 2015 | HP TouchSmart BV551AA 310-1125f Desktop PC...
Cannot get beyond Desktop screen frozen
make sure its your computer. sign in with your password. if it is yours
May 08, 2013 | Sylvania Synet7wid - 7" Netbook - Internet...
Sony vaio all in one touchscreen stopped working
XP and Vista Normal Mode Start your computer as you normally would. Click the "My Computer" icon on your desktop. Go to "C:\ Program Files\Sony\Setting Utility Series." Find and choose the "VCCPointingDevice" folder in the "Setting Utilities Series folder" to open the "Built-in Pointing Device" dialog box. Locate the "Enable" box on the "Built-in Pointing Device" dialog box. Check the box to enable the Vaio touchpad if you wish to use this device. Disable the touchpad if it is interfering with the external mouse. Uncheck the "Enable" box if you have a USB (PS/2) mouse connecting to your Vaio and wish to use that instead of the built-in touchpad. Pick "Yes, I'm Sure" when prompted to activate your choice, then close all the windows. Windows 7 Normal Mode Launch Windows as usual. Go to "Start" > "Control Panel" > "Mouse" > "Pointing Device" to open the Vaio touchpad control center. Uncheck the "Enable" box on the "Pointing Device" window when you wish to use your external mouse. Check the "Enable" box on the "Pointing Device" window when you want to use the Sony Vaio touchpad. Make sure the external mouse is not interfering with the touchpad if you have one connected. If so, unplug the mouse from your computer. Click the "OK" button at the bottom of the "Pointing Device" window. Close all other windows. XP and Vista Safe Mode Restart your computer. Press the F8 key before the Windows welcome screen appears to enter Safe Mode. Click "Start" > "Control Panel" > "Add/Remove Programs." Find and delete all software for mice and pointing devices. Restart your computer in normal Windows mode. Proceed to next step if the problem persists. Restart your computer in Safe Mode. Right click the "My Computer" icon on the desktop. Choose "Properties" on the drop-down list. Pick the "Device Manager" tab in the Properties window. Select the "Other Devices" folder and click on the "+" sign besides it. Delete all the devices under this "+" sign by clicking on the "Remove" button next to each of the items. Restart Windows in Normal Mode. Once Windows is operating, there will be a "New Hardware Wizard" pop-up that will load all the necessary drivers for the touchpad, mouse and other pointing devices. This should fix the corrupt driver for your Vaio touchpad. Windows 7 Safe Mode Reboot your computer and press the F8 key before the Windows welcome screen appears to enter Safe Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Click the touchpad icon. Choose the "Driver" tab and press the "Uninstall" button. Press the "OK" button to confirm. Restart Windows in Normal Mode. Go to "Start" > "Control Panel" > "Device Manager" > "Mice and other pointing devices." Choose the "Driver" tab and press the "Update" button. Press the "OK" button to fix the touchpad software.
http://esupport.sony.com/perl/swu-list.pl?mdl=PCGFRV26
Feb 08, 2013 | Sony VAIO Computers & Internet
Sony vaio touch screen stopped working
Feb 08, 2013 | Sony VAIO VGC-LV180J 24-Inch All-in-One PC...
My desktop worked normally yesterday. XP SP3 on Foxconn N152535 (not sure where to read the series name), SATA 80GB IDE mode, 512MB RAM. Today when I turned it on, the CPU fan rotate normally but it wont...
restart your computer tapping the F8 key repeatedly to enter safe mode where the only things that will be working are keyboard and mouse allowing you an attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred then you will no what the error was and you might be able to work your through it or
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
hope this helps
Aug 05, 2011 | Foxconn N570SM2AA-8EKRS2H (0683562100618)...
My laptop starts properly with the normal starting procedures when when started (with windows vista home premium 1) The mouse gets hanged and keep circling 2) The internet display that is network when...
Good Moring,
I have seen this behaviour in computers with virus (maleware) you can try the following
1)start your antivirus while log in safe mode and run a full scan
if virus is found remove it and start windows normally run a full scan afterwards
2) if no antivirus is install, i would recomend you to reinstall the OS
Nov 15, 2010 | Dell Inspiron 1525 Notebook
Touch pad does not work
  1. Shut Windows down.
  2. Power the unit on, and start tapping the F8 key. Keep tapping the key until you get the Windows Startup Menu.
  3. Choose Safe Mode from the list.
  4. Once in Safe Mode test, the device to see if it is working.
  5. If the device works in Safe Mode, but not in normal Windows mode, it may be a software issue.
  6. If this is the case, open up my computer and go into control panel.
  7. Open Add/Remove programs, and remove any mouse related software listed here.
  8. Reboot the computer.
  9. If it still does not work, right click on My Computer, and choose Properties.
  10. Click on the Device Manager tab, and make sure View Devices By Type is selected at the top. (NOTE: If you are running Windows 2000, Device Manager can be reached by clicking on the Hardware tab.)
  11. Look for a category named Other Devices. If it is there, click the plus next to it, and remove all devices listed under it. Remove the device by clicking on it once to highlight it, then click on the remove button at the bottom.
  12. Now Look down through the list and find the Mouse category.
  13. Remove any devices listed below it by highlighting the device, and choosing remove at the bottom.
  14. Reboot the computer.
  15. If the two pointing devices stop working after removing the mouse driver. Just use the Windows key on the keyboard to bring up the start menu. Now use the arrow keys to highlight Shutdown on the menu. Press the Enter key to select Shutdown from the list.
  16. Power the unit back on, and let it boot up to Windows normally.
  17. When it gets back to Windows, the New Hardware Wizard should appear and load the required drivers for the mouse.
  18. Test the device now.
  19. If the device still does not work, call WinBook Tech Support for further assistance.
  20. Or if the device doesn't work in Safe Mode or normal Windows mode, then it is most likely a hardware issue. At that point call WinBook Tech Support for further assistance.
Nov 03, 2010 | Acer Aspire T690 (AST690UP820A) PC...
I HAVE A HP COMPAQ dx2400 NORMAL START UP PROBLEM. AFTER SWITCHING BACK TO MY SECOND PROFILE FROM THE ADMIN, A LITTLE WHILE LATER IT RESTARTS THE COMPUTER AND ASKS FOR WHICH KIND OF STARTUP: SAFE MODE,...
probably best if you back up your hardisk and then format the PC. could be a DLL problem or try repairing your present OS by popping back the installation CD.
May 24, 2010 | HP Hewlett Packard Compaq dx2400...
My laptop screen goes blank
Hi!
Can you go in safe mode? The screen it is working?
In case you don't know how to go in safe mode:
Turn on the computer and after the boot screen press the F8 key.
Windows will ask which mode you like to go:
First try safe mode.
You can also try:
Last know good configuration
VGA mode.
Let me know
Jan 19, 2009 | HP Pavilion dv2000t Notebook
Mouse troubles with my Compaq Presario 5000 PC
looks like to me that you have generic drivers loaded if you get to my computer right click on it and go down to properties then click on it click on hardware and than look for your mouse and right click on it and look for remove than click on it to remove the mouse from the computer say yes than close out of it and restart the computer once the computer starts up the new hardware found should pop up and continue installation from here ok good luck !!!!!
Jul 29, 2008 | Compaq Presario 5000 PC Desktop
Dell InspironTM 1501 Notebook Logo
2,189 people viewed this question
Alun Cox
