Question about Cameras
My Nikon D70 DSLR was fine when last used but after around three weeks when brought out to use again, the LED which signifies writing to the card is flashing - whether the power is on or off. Removing the CF card and reinserting it makes no difference. While this light is flashing the camera will not switch on or show any information in the LCD. It is about three years old and has been faultless until now. Any suggestions?
likha
  • 790 Answers
SOURCE: DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Posted on Nov 02, 2007
  • 1894 Answers
SOURCE: Nikon D300 constant flashing of
did u do a hard reset?
Posted on Jun 08, 2008
  • 18 Answers
SOURCE: Nikon d70 digital camera wont come on when switched on
I had the same problem. Camera had to be sent back to Nikon repair depot.
Posted on Jun 11, 2009
  • 164 Answers
SOURCE: canon EOS 400D dslr will not work various CF
Using a flashlight, check thru the CF memory card reader if there are some pins that are bent, missing (broken) or damaged.
If this is the case, it is necessary to have serviced the camera to replace such pins, and inspectd for the broken pin pieces that may be stuck inside the camera, and cause later a short circuit.
If all the pins are in good conditions, may be the internal memory reader circuitry is failing, which requires also a professional camera repair service.
If it's under warranty, I do recommend you to send it back to make valid the warranty.
If not, then you have the options of pay for its repair, or do it yourself if you are willing to open it and perform the steps to repair it.
If so, You will need tools to do it, which includes the usage of a soldering iron, microscope (since requires micro soldering), and buy the CF memory card reader connector..
Best regards,
Posted on Jul 23, 2009
  • 291 Answers
SOURCE: Do the Nikon D100 and the D70 share the same in
I understand what your're looking for.
The D100 is basically an N80 with digital guts. It doesn't share the same chassis as the D70, although it does share the same excellent battery.
Other than that, the D70 was a new design, so it doesn't seem too likely that they would have the same CF sockets.
That being said, unless I had them both stripped apart on the table in front of me, I wouldn't make any bets. It just seems like there would be slight differences in mounting holes and configuration.
Posted on Oct 02, 2009
Testimonial: "Thanks for your input and probably right about incompatibility between the two. Anyone stripped these two down able to offer a definitive answer? "
I bought a Nikon D70 on ebay for a good price. It has a 28-80 lens. I can read the menu on the monitor, but it is black when I want to take a photograph. I can use the viewfinder, and take a picture, but I...
No, you shouldn't. The D70 works as SLRs have worked for half a century, allowing you to compose your photos through the viewfinder. The ability to use a dSLR as a point-n-shoot camera, wobbling at the end of your arms, is a relatively recent development. Nikon introduced it into their lineup with the D3 and D300, released years after the D70.
Apr 05, 2011 | Nikon D70s Digital Camera
D200 SHUTTER WILL NOT FIRE AUTUFOCUS DOES NOT Work
The manual says what f ee means, do you have the manual? Il get the manual now and check.
Jul 22, 2008 | Nikon D200 Body Only Digital Camera
Hi!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
CHA flashing on readout screen. Battery is fully charged. What does CHA mean?
If there are brackets around the CHR, it means the card is locked. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If there are no brackets around the CHR, it means the camera cannot read your memory card. Try a different card.
Dec 12, 2010 | Nikon D70 Digital Camera with 18-50mm Lens
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
Which digital cameras can the sigma dl 75-300 lens be used on
nikon dslr cameras.ie,d70,d80.full frame and aps sensors,dl macro super lens good for post d70
May 20, 2010 | Sigma 75-300mm f/4-5.6 DL Lens for Nikon...
Self timer in nikon d70
Hello. I have a Nikon and it is a great camera. here is the owner manual for your D70. Go to page 105 and 106 to use the self timer.
http://www.nikonusa.com/pdf/manuals/dslr/D70_en.pdf
please rate my answer as very helpful. thanks, Joe
Apr 26, 2010 | Nikon D70s Digital Camera
Nikon D70 (new 2004) Shutter release will not take picture
I've got a D70 and never had this issue. I bought mine around the same time frame. Thanks for the info!
Aug 16, 2009 | Nikon D70s Digital Camera
Nikon D70
Greetings,
It is actually an error message generated by your compact flash and means that the card is no longer readable. A lot of D70 owners have reported this error without being able to find another solution other than reinserting the card or changing the card to a different brand. In my D70s I use Sandisk Extreme III memory and, knock on wood, have not yet had this error. You could also try cleaning out the memory card slot and check to see that all pins are aligned and not bent.
Good Luck,
-WN
May 12, 2008 | Nikon D70s Digital Camera
Nikon D70 flash doenot fire
According to my information, the camera may need a new flash PCB (printed circuit board). Check the repair service search on this site for someone in your area. The part number for the circuit board is: 1S014-020-1 and runs about 50$
Sep 21, 2007 | Nikon D70 Digital Camera
Cameras Logo
50 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
