Question about Canon Office Equipment & Supplies
Canon imageclass 5770 Just got it back from the field and got a Red flashing alarm light and led display read: Suppy Rec Paper What's up with that?
Fixya is a waste of time... 1000's of questions and not one answer!
Posted on Feb 02, 2010
Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
Canon imageclass mf8180c alarm reset
I have a canon MF8180C with the display on at all the time but I can see nothing on it, only the COPY and SCAN light are on with the alarm red light on also, any ideas please??? thanks.
Dec 28, 2009 | Canon imageCLASS MF8180C All-In-One Laser...
Red alarm keep coming to my (Canon imageCLASS MF5770 Multifunction Printer) and display message: CHECK PAPER SIZE AND CHANGE PAPER SIZE CASSETTEL LTR. please guid me through steps. thanks!!
Chances are the paper size in the cassette doesn't match the paper size (or alignment) that you've tried to print. Verify the paper and alignment of the paper match what you're trying to print, and that the paper guides in the cassette are locked into position for the size and alignment you're working with.
Aug 05, 2009 | Canon imageCLASS MF5770 All-In-One Laser...
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
Canon Imageclass D320 supply rec. paper malfunction
My problem was that I was trying to print from a PDF file. I found out that the file was legal size and that the setting for the printer to "choose paper source by PDF size" was checked. I unchecked it so that it would print on letter size paper. Hope this helps
Jun 05, 2008 | Canon imageCLASS D320 Digital Copier
Canon 5770 adj paper jam
Hi
check the paper settings on the printer and also on your computer they must match e.g A4 on both
Feb 01, 2008 | Canon imageCLASS MF5770 All-In-One Laser...
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Won't feed the paper
the problem with your machine maybe that the default paper size programmed into your machine. My guess is that it is set to legal size{ 81/2x14} Get your owners manual out and see how to program the paper size in the user settings sections.
Jan 18, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
108 people viewed this question
old marine
old marine
