Question about iLO MP3 Player
No files found
After downloading music to my player my ilo shows no files found. I tryed to load more music but Windows Media Player shows that my player is full. I went and checked to see if they were loaded and Media shows that they were. Is there a way I can clear my ilo and start over?
Ok I have same player, same problem. Turns out Windows Media player copied the files into the FM subfolder on the device. FIX: connect device to computer. Do not open WIndows media player, instead open windows explorer, in there you should see the ilo as a new drive. Click the drive and go into the FM folder, now select all files and drag them directly to the drive. The secret is the files have to be outside of the FM folder loose in the device (not in any folder) After that I safley removed the device from the system tray icon and powered it on and the songs were all there. It runs an index process that creates the lists, this takes a second.
Posted on Dec 27, 2006
SOURCE:
Idk how to download music to my sylvania mp3 player from limewire......
well u can drag ur file from limewire onto the desk top and open up ur window for ur mp3 player and drag it to ur music file on ur mp3....ore u can transfer your files to another player such as windows media player and syc it with your mp3 player to auto transfer your music files into your mp3 player. but make sure its in mp3 format or it will not play the music file, the file will show up hidden.
May 22, 2010 | iLO MP3 Player
Can't download music to MP# player
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable.
2. Open Windows Media Player.
3. Go to the Sync or Devices tab and delete all content from the player.
4. Go to the Tools menu and select Options.
5. Select the Devices tab, highlight the ILO or Siren player and click on Properties.
6. Uncheck the box "Create Folder Hierarchy on Device"
Dec 14, 2008 | iLO Audio Players & Recorders
Won't read music
Check and make sure that the format you are trying to play is compatible with the player. For instance, iTunes files won't work with this player.
Also, you could be trying to load DRM-protected files from a service like Bearshare. Yuur screen will tell you the files are transferring, but they are really not transferring b/c they have DRM protection. There is not currently a free way that I know of to remove this DRM-encryption, although you can probably buy download rights from your music service.
Unfortunately, the ILo site is down, so their is no way to get a firmware upgrade in case this model is another victim of the Windows Media Player upgrade - WMP 11 messed up a lot of mp3 players regardless of manufacturer.
Mar 14, 2008 | iLO (2 GB) MP3 Player
Downloading music trouble
After you've downloaded the music files you want from Lime wire put them in your music folder on your computer ,then you need to sync your MP3 player through windows media player. plug in your mp3 player then open windows media player, on the top right there is tab says sync. click on refresh devices and your mp3 player should show up on the right window pane in windows media player. From there you can drag all your music onto it and press sync!
Hope this works
Dan
Feb 22, 2008 | iLO MP3 Player
Disk error!
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 08, 2008 | iLO (2 GB) MP3 Player
Can somebody help me?
-Plug in your mp3 player
-Go into your downloading program, select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open "iLo" and drag the songs from where your songs are located [My Music] to the 'Music' folder in your iLo folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/iLo] Music.
Dec 27, 2007 | iLO (2 GB) MP3 Player
I download music on my MP3 player and it shows Empty Disk
i think you should format your mp3 player to Fat32!! that is the best solution, NTFS doesn't support both mp3 & mp4 players
Nov 18, 2007 | iLO (2 GB) MP3 Player
Cannot download music to ilo mp3 player
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Sep 01, 2007 | iLO (2 GB) MP3 Player
Will not download music files from my computer.
Rip the songs in mp3 format, and then reload
Aug 17, 2007 | iLO (2 GB) MP3 Player
Ilo mp3 player issue
Your ilo should've come with a disc. That disc should install windows media for you. You can't put music onto it without windows media.
May 05, 2007 | iLO MP3 Player
100 people viewed this question
Top iLO Audio Players & Recorders Experts
Siul Oyaratgam
Rick
Rick
Inky Fingers
Inky Fingers
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
