Question about Dell Dimension 9200 PC Desktop
Rebooting on Dell D600 Latitude
My laptop, a Dell D600 Latitude with 3 1/2 years, started rebooting itself every few minutes when I'm directly working on it, either through battery or grid power.
That doesn't happen when I have it connected to the docking station or when I use it to watch a movie on the TV (basicly, when I don't touch it...).
Does someone have an idea of the possible solution to this problem?
Thanks!
    Genius:
  • 1,124 Answers
This issue could be caused by any of the below possibilities.
Software issue or error.
Hardware issue or error.
Heat related issue.
Computer virus.
Issue with operating system.
Errors generated by software programs can cause a computer to reboot unexpectedly or without warning. If you are running Windows XP see the below section "For Windows XP users" before continuing.
If you are not running Windows XP or following the below steps still cause your computer to reboot without warning. Boot your computer into Safe Mode, and let the computer run in Safe Mode.
If the computer is still rebooting in Safe Mode the issue is likely not software related but something else, skip to the next section. If the computer is not rebooting in Safe Mode it is likely you have software related issue. We would recommend you run through the basic troubleshooting section for your operating system.
Windows XP is designed to automatically reboot each time an error occurs such as a BSoD. Although this may be nice for errors that do not occur often, users who have a re-occurring error may wish to identify the error to troubleshoot it. Below are the steps on how this feature can be disabled and enabled in Windows XP.
From the desktop right-click on My Computer.
Click the Properties option.
In the System Properties window click the Advanced tab.
In Advanced click the Settings button under Startup and Recovery.
In the Startup and Recovery window uncheck the Automatically restart check box.
Click Ok.
Now if the computer generates and error it should not automatically restart and enable you to display any errors your computer may be experiencing.
Any failing hardware component in your computer could cause your computer to unexpectedly generate an error and/or reboot without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Make sure you are not encountering any hardware conflicts by viewing Device Manager for errors. Additional information about Device Manager can be found on our Device Manager page.
New drivers can also cause this issue, if you have recently performed any hardware driver updates you may wish to try an earlier version of the drivers. Additional information and help with computer drivers can be found on our drivers page.
If you have updated drivers and removed any hardware that could be causing this issue and continue to experience random reboots, it's possible that the memory is bad in the computer.
Finally, hardware devices that are not installed properly in the computer can also cause random reboots. Make sure all the cables and expansion cards are connected properly to the computer. The best way to determine this is to disconnect and reconnect all cables and expansion cards.
Computer virus
Computer viruses such as the blaster virus are written to reboot your computer without warning. Usually these viruses will make the computer reboot ever 5, 10, 15 or 30 minutes after the computer has booted.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus make sure your virus scanner definitions are up to date.
Heat related issue
Many computer today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets to hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer you will need to either open the computer and make sure the fan are working (processor fan and case fan) and/or if your BIOS monitors the RPM of the fans enter BIOS and make sure the BIOS does not report any errors.
Users may also be able to determine how hot their computer is by onboard thermal sensors, if your computer comes equipped with these sensors make sure your CPU is not running to hot.
If after following each of the above recommendations your computer still continues to reboot it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup let the computer sit.
If the computer does not reboot while letting the computer sit in CMOS it is likely that you are in fact experiencing an issue with Microsoft Windows and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
Posted on Nov 19, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 94 Answers
Check your battery port. It might be loose. since docking stations directly connects to your laptop moboard, it won't restart unless the docking station was ran out of power.
Posted on Mar 05, 2012
Can you upgrade cpu in dell 15 i5559-4682slv to i7 ?
It is almost impossible to upgrade proprietary makes like Dell and HP. The are big enough to have motherboards made for them manufactured on price point. This means that they are not built with upgrade in mind. Also the cases are made to fit their motherboard and theirs only.
Go to a computer builder and get a good case, buy a good quality motherboard and equip it with what you can afford. In two years you can upgrade as processors have moved on. Two years after that, you can swap out the motherboard, processor and memory.
Jan 12, 2017 | Dell Computers & Internet
Are 2002 Aztec computers compatible
I am assuming you are discussing the 2002 Pontiac Aztec, the early crossover with the rather distinctive look. I would assume that since they were made by the same manufacturer and they used the same parts that their computers should be compatible. I can't say so for certain as you haven't provided much information, but, unless one of the Aztec owner swapped out the original computer and replaced it with an updated device, the computers should be compatible.
If you are thinking of trying to swap computer chips, I would advise you to wait and let a professional do it at an independent shop. The reason I suggest this is simple, unless you know how to access the computer chip correctly, you risk accidentally ruining it. If you handle the replacement chip incorrectly it is entirely possible that for a stray static charge to ruin the chip by blowing out a trace. Also, if you damaged the socket from which the original chip was removed then it is possible that you will not be able to reinsert the new device without bending any leads on the bottom. If the leads are damaged, then the new computer won't work.
Even if the new computer chip and the original chip were already installed in installable cases (the way most desktop computer chips are installed), it is possible that when you removed the computer, you might have damaged the receiving socket which means that when you go to insert the new computer carrier it won't work correctly because a few or many of the pins on the bottom of the board won't sit correctly.
Jan 03, 2015 | Computers & Internet
How to hard reset a WM8880 laptop
Power the unit off (holding power buttom) and selecting Power off, then simultaneously hold the "back" button and on button for about 8 seconds. When the android icon appears, press back buttom, in the menu select wipe data/factory reset pressing the home buttom and then press the back buttom, in the next screen select "yes delete all user data" pressing back buttom, and in the next screen select "reboot system now" with the back buttom and wait.
Nov 29, 2014 | Computers & Internet
How to enable bluetooth
Your computer has to have a bluetooth radio. You can check
Control Panel > System and Security > Device Manager
Do you see a Bluetooth Radio listed?
If not, you don't have BlueTooth on your computer so you will have to add a BlueTooth device by plugging one into a USB port.
If you have a BlueTooth radio, go to Control Panel > Hardware and Sound > Device and Printers > Add a Bluetooth Device
This option is used to connect a blue tooth device (e.g. bluetooth headphons) to your laptop through your bluetooth radio.
See this Windows web page for more information.
Set up Bluetooth enabled device
I will respond to any additional questions you have.
Aug 05, 2014 | Dell Inspiron Computers & Internet
Error code 0151
hard drive failure. replace with new drive and reinstall whatever os you choose. i recommend 240-480 gb ssd.
Apr 12, 2014 | Dell Vostro 1015 Laptop Computer (Intel...
Bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Jan 28, 2014 | Dell Vostro Computers & Internet
Button keeps blinking
It sounds like it could be either the battery is going bad and not holding a charge or the adapter is. I have had really good luck with similar problems going to places like Batteries +, and large electronic retailers, and my favorite the small local mom and pop computer store; where I end up asking them If I could try one of the adapters from the floor model to eliminate if is a faulty adapter. Other then that I'd if its not out of warranty contact Acers online chat support at http://us.acer.com/ac/en/US/content/service
Jan 19, 2014 | Computers & Internet
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
Dell Dimension 9200 PC Desktop Logo
653 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
