Question about Lexmark T522 Laser Printer
My Lexmark T522 printer is showing: 954 Service, NURAM Failure
I could not figure out what this means/ Can you help with expalining it and possibly a solution?
  • 488 Answers
Info from the lexmark site:hope it helps!
Printer is Posting a 953 or 954 Service NVRAM Failure Message ID: ENUS9756
To clear an NVRAM error message:
Turn the printer off.
Leave it powered off for at least a minute to give it a chance to reset, then power it back on.
If that clears the error, continue using the printer but keep an eye on it for the next day or two to see if the error returns. If the error does not return, the printer should be fine.
If the NVRAM error does return, you can try resetting the printer's NVRAM as follows:
Now press and hold down the right Menu arrow button (>), the Select button, and the Go button at the same time.
While continuing to hold all three of these buttons down, turn on the printer.
Keep holding down the buttons until the printer displays Clearing NVRAM or Restoring Factory Defaults, indicating that the printer is performing an NVRAM clear. You can release the buttons at this point. WARNING! Do not power off the printer during this process.
When the printer has finished the NVRAM clear, it should return to the Ready mode.
If the printer has not gone back to Ready after fifteen minutes, turn off the printer and then turn it back on again as you normally would.
If these steps do not clear the NVRAM error, there may be an issue with an installed option on the printer. Electrical options (like flash memory, network cards, code SIMMS, and additional RAM memory) are the most likely causes. To see if an installed option is causing the error:
Turn off the power and remove any options that have been installed. (For information on removing memory or code SIMMs, click here.)
Turn the printer back on.
If the NVRAM error continues, the printer will probably need service.
If the NVRAM error is gone after you have removed all of the options, power off the printer again.
Reinstall the options one by one. Power on the printer each time to see if the NVRAM error returns.
If the NVRAM error returns as soon as you reinstall an option, that option may be causing the error.
Remove that option.
Turn off the printer and reinstall all remaining options (if any). If the NVRAM error appears only when that one particular option is installed, that option may be defective or incompatible with the printer.
If you can reinstall all of the options and the NVRAM error is gone, an option may have been loose and simply needed to be reseated. Again, keep an eye on the printer for the next day or two to see if the error returns. If not, the printer should be fine.
If your printer looks like it will need service and it is still covered under its factory warranty, click here for information on how to contact Lexmark Technical Support.
Posted on Nov 19, 2008
I have just received a lexmark t522, which was an ex-work printer that was attached to a network. i want to use it as a stand-alone printer now. when it was attached at work it worked fine, but now keeps...
This printer has both a USB and parallel printer connection.
I suggest you connect this printer to your computer using the USB printer cable and install the printer driver software on your computer.
You can download the Lexmark printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :- http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
Aug 03, 2011 | Lexmark T522 Laser Printer
WHAT DOES 954 SERVICE, MVRAM FAILURE MEAN?
error 954 Indicates the NVRAM experienced a CRC failure.
Usual solution is to replace the engine board. (part number 99A1923)
Dec 31, 2010 | Lexmark Optra T614 Laser Printer
Lexmark T620 954 service nurram failure
Here's an article found in the Lexmark website on how to clear an NVRAM error message. Just click on this link: http://bit.ly/a1bRbU. Follow the instructions carefully. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 26, 2010 | Lexmark T620 Laser Printer
954 service nvram failure huh
954 nvram errors are created by 2 things both located on the engine board. one of these being a eprom located in the lower right hand corner of the board at q6. the other being the nvram chip itself located at u15 middle of the board far left hand side.percentage wise 65% the eprom 35% the nvram chip. this information comes from.
this error can most times be reset by holding the right arrow go and return buttons depressed then power on the printer untill the control panel lights up. it will then go to restoring factory defaults then to ready takes about 3 or 4 minutes tops. hope this helps you out. have a great one
May 14, 2010 | Lexmark T522 Laser Printer
My computer comes up with 954 NURAM Failure. What do I do?
Here's an article in the Lexmark website to clear the NVRAM Failure. Just click on this link: http://bit.ly/bGSdYV. Hope this helps. If you need more assistance, just place a comment and I'll be more than willing to help you out. Thanks.
Apr 15, 2010 | Lexmark Optra T612n Laser Printer
This is from Lexmark's support page....sounds like a hardware issue....
NVRAM Failure 953: NVRAM Chip Failure
954: NVRAM CRC Failure
Optra T 640/642/644
953 - Replace the operator panel board or upper front cover.
954 - Replace the interconnect card.
Mar 26, 2010 | Lexmark T522 Laser Printer
My Lexmark T620 is giving me the following message: 954 Service NVRAM Failure. How do I fix this?
replace the engine board...local service center that works on Lexmarks can change in under an hour.
Jan 22, 2010 | Lexmark T620 Laser Printer
Lexmark t522
Here is what you need!!! Click on the Above Link. Download Software!!!
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 13, 2009 | Lexmark T522 Laser Printer
LEXMARK
That error indicates that you need to replace the Engine board. The part number is 11K1416, a service tech would need to replace it due to settings needing to be reset.
Jul 15, 2008 | Lexmark Optra T610 Laser Printer
Lexmark t522 black marks on leftside of pages
the top roller is the charge roller and the bottom one is the transfer roller if a foriegn substance got on either roller they could create this problem the oil from your fingers getting on them could create this. given everything youve changed the rollers are whats left. you can clean the charge roller but its better to get new ones these are consumable
Apr 22, 2008 | Lexmark T522 Laser Printer
Lexmark T522 Laser Printer Logo
1,992 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
