Question about Sansui Audio Players & Recorders
Sansui D90 cassette player No 689120609. when I press either the play button or fast button, within two seconds they cancel themselves !! Can you help please.
chie-chie
  • 98 Answers
SOURCE: Cassette Player
  • very easy.. if your motor 12 v or 6 volts...for 12 volts motor buy an ic "kia 7812 this parts is voltage regulator with 12 volts 1a output..7806 this parts is volt.reg with volts 1a output..7803 3 volts output etc. etc.
  • input 1st terminal
  • ground mid terminal
  • output 3rt terminal
same a transistor.
Posted on Feb 05, 2008
marsrover
  • 682 Answers
SOURCE: denon DR-M44HX cassette deck play
please check small rubber belt around take up reel and counter assembly and change it if it is loose or torn.
Posted on Jul 10, 2008
SOURCE: Cassette Recorder play problem
Left(Playback) deck of cassette player turns off within about 2 sec's after inserting a cassette to play. Rewind and Fast Forward stop also after about 1 to 2 seconds. When pushing button to play it turns back off right away. I suspect the end of tape/tension sensor is the culprit but do not know where it is. Have not taken any steps except finding this site first off!
Posted on Jul 24, 2008
battlesmith
  • 382 Answers
Belts are prone to harden over time,the belt will be broken so replace it.. Also as you say the unit does turn off which is the problem of Take-up reel sensor ..Try to Take to any Service person and replace it,your player will be back in condition..Thank you..
Regards!!!...
SOURCE: when i turn on the stereo the cassette player fast forwards then rewinds but when i put a tape in it wont play or do anything else
Change the belts maybe are so lossen
Posted on Apr 24, 2009
Getting my aiwa to play cds or cassettes. Bought second hand no instructions .lights up won't play can I get instructions on how to get sound?
You don't state the model, so we are running blind here. It should be fairly obvious. For the CD press the CD button. Then press the door button and put the CD on the tray. Then press play or the door button again. If the CD player works it should play the music. Same with the cassette. Drop the cassette into the holder, push it back in place then press play.
Oct 07, 2017 | Aiwa Audio Players & Recorders
It is problem in Take-up Reel section and its not sending signal to processor. How old is this unit?
Jul 24, 2008 | Onkyo TARW255 Single Dual Cassette Deck
I have the timer light alone one and cant get the cd player to go on please help me
UNset the Timer control. On Page 40 of the manual...
Cancelling the timer setting in the timer stand-by mode:
1 Press the CLOCK/TIMER button.
2 Within 10 seconds, press the '<< << or >> >>' button to select
"ONCE" or "DAILY", and press the MEMORY button.
3 Within 10 seconds, press the '<< << or >> >>' button to select
"ONCE OFF" or "DAILY OFF", and press the MEMORY button.
Timer will be cancelled (the setting will not be cancelled).
May 18, 2011 | Sharp CD-SW330 Shelf System
I have a TDK HD-01 head demagnetizer for cassette decks, but I have lost the instructions. Could you help?
Hi there.
First - Turn On The Tape Demagnatiser (should be a switch on it)
Second - Insert into cassette player
Third - Turn On cassette player
Fourth - TURN DOWN VOLUME ON AMPLIFIER TO MINIMUM (This is essential!)
Fifth - Press Play on cassette player
Sixth - After 10 seconds press stop on the cassette player
Seventh - Remove the cassette demagnetizer from the cassette player
Eighth - Turn off the demagnetizer and put back in it's usual storage place
AGAIN, MAKE SURE THE VOLUME IS TURN TO MINIUM WHEN USING THIS AS THE NOISES CAN DAMAGE SPEAKERS.
Jan 07, 2011 | Audio Players & Recorders
Unit will not come on, but timer button is blinking
Well, it thinks it's set to come on under Timer control.
Get the manual out (or go to retrevo.com, register and download it for free) and go to page 34 and cancel the timer.
Canceling the timer setting in the timer stand-by mode:
2 Within 10 seconds, press the or button to select
"ONCE" or "DAILY", and press the MEMORY/SET button.
3 Within 10 seconds, press the or button to select
"ONCE OFF" or "DAILY OFF", and press the MEMORY/SET button.
Timer will be canceled (the setting will not be canceled).
Mar 10, 2010 | Sharp XL-MP130 CD Shelf System
Sansui SC-1110 won't run at correct speed.
Check the Cassette drive motor. in the back of the motor there is a Speed adjuster. there is a Hole with a rubbler **** cover use tiny strait edge screw driver. turn clockwise and motor will speed up. easy way put in a cassette you know well and use that to adjust speed.
Aug 06, 2009 | Audio Players & Recorders
RCA cassette recorder/player keeps shutting off. argggg
fast forward, reverse the cassette and fast forward again. if the tape is too tight the current sensor will always trip out the motor.
Dec 03, 2007 | Audio Players & Recorders
Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
This is a fairly old and obsolete model and its components are now not manufactured. If you are lucky, some stockists may have replacement part, but normally at very high price.
Nov 06, 2007 | Audio Players & Recorders
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
315 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
