Question about Toshiba Satelite 5205-S505 Notebook
How do I go Wireless with my Toshiba 5205-S505 Laptop?
I would like to be able to go Wireless with my laptop but am not sure what accessories I would need to do so. Your help is greatly appreciated.
  • 488 Answers
For getting wireless u need the following: a wireless access point or a router..access points are easy to configure..good ones are from linksys(other brands are Netgear,D link,Belkin etc) Linksys WAP54G Wireless-G Access Point..and your pc/laptop needs to be wifi enabled..if they are not you can get a USB adapter again from Linksys..just follow the instructions and you are good to go!do secure your wifi network once you make it..hope it helps!
shall be glad to help further..
Posted on Nov 19, 2008
Can i use any charger on s505
The Toshiba Satellite 5205 series of Notebook PC, and the S505 series model; uses an AC adapter (Charger) that produces 15 Volts DC.
http://www.sparepartswarehouse.com/Toshiba,Satellite,5205,PS520U-31P1RV,Laptop,AC-Adapters.aspx
You will see AC adapters sold that show 15 to 24 Volts. (DC)
http://www.duracelldirect.com/toshiba_satellite-5205-s505_ac-adapters_laptop_ac-b20h.aspx
This is because the AC adapter (Charger) has PFC.
Power Factor Correction,
http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-Power-Supplies/181/2
Also I see it is just a two pin AC adapter plug, to laptop.
Center hole is Positive, outer metal cylindrical metal shell is Negative.
Go for 75 Watts or higher though, and not a 65 Watt model.
[ On the case of the AC adapter;
Input: 100 ~ 240 VAC 50-60Hz
Means it can use from 100 to 240 Volts AC, and either 50 or 60 Hertz.
Output: 15VDC 6A
Means 15 Volts DC at 6 Amp's. (Amperes)
Watch the outside dimension of the cylindrical part, and the center hole dimension. Outside cylinder may be correct, but center hole may be too small. Or vice-versa.
Regards,
joecoolvette
Dec 17, 2012 | Toshiba Satelite 5205-S505 Notebook
My toshiba laptop powers on but doesn't boot up to windows until after i open and close my dvd drive
if there is a quick release for the drive - pop it out entirely and see if works then. You are looking at replacing the drive or motherboard.
Feb 25, 2011 | Toshiba Satelite 5205-S505 Notebook
How to turn on wireless switch on a Toshiba 5205-S505?
First - Determine if your Toshiba Satellite has built-in Wi-Fi. Open the Start menu in the lower left corner of the desktop. Choose "Control Panel" and select "Performance and Maintenance." Click on the "System" icon and click on the "Hardware" tab in the System Properties window. Click on the "Device Manager" button. Click on the plus sign next to "Network adapters." Look for a device that has "Wireless" or "WLAN" in the name. If you see this device listed, then you have built-in wireless.
Next - Turn on the wireless by holding down the "Fn" key on the keyboard and then pressing "F8" at the top of the keyboard. Press this combination until the window indicates that Wi-Fi is on. Some Toshiba notebooks have a switch on the front left side of the laptop that will turn the Wi-Fi on. Many Toshiba Satellites have an LED indicator light on the right front edge of the notebook that will turn on when the Wi-Fi is on.
Finally - Click on the Start menu in the lower left corner of the desktop. Select "My Network Places" and click on "View network connections" in the menu on the left side of the window. Double click on the "Wireless Network Connection" icon. This will open a window that lists available wireless networks. Click on the name of the network you wish to connect to and click on the "Connect" button at the bottom. Type in the password if required and connect to to the network. Open a web browser to test the connection.
Apr 15, 2010 | Toshiba Satelite 5205-S505 Notebook
My laptop could not entering into the main desktop after booting, only loading.
I think your windows has corrupted . Try the following.
Boot the system and hold F8 key.
Select the Last known Good Configuration.
Rebbot the system and then check
Mar 16, 2010 | Toshiba Satelite 5205-S505 Notebook
CPU upgrade for Satellite 5205-S505
You would only get a marginal performance increase. If your laptop has 256Mb of RAM, increasing the RAM up to 1Gb (this model laptop cannot support more than 1Gb RAM) would boost the performance of the laptop.
Jun 20, 2009 | Toshiba Satelite 5205-S505 Notebook
Satellite 5205-s505 speakers aren't working, headphones OK.
Start- Control panel- Sounds and Audio Devices- In the device volume section click Advanced- Click Advanced again and check if In the other controls section 1 PC Spk mute is checked if so uncheck it If that does not work please let me know so I can help you further
Dec 09, 2008 | Toshiba Satellite 5205-S503 Notebook
Upgrade my graphics
Be warned: If the upgrade is possible at all for your laptop, it can be a time-consuming operation that involves disassembling virtually your entire notebook, so don't enter into this process unless you are willing to accept the risk of doing serious harm to your machine.
On some newer, high-end notebooks, the graphics card can be accessed simply by opening a panel on the bottom of the computer. But for most older machines, disassembly will take more steps.
The first thing you need to know is that your laptop can probably support only a handful of very specific graphics cards, if the card can be upgraded at all. Your best source for an upgrade card will likely be the manufacturer that made your portable.
Be sure to consult your laptop's service manual (which can usually be downloaded from the manufacturer's support page) before attempting to open up your machine. Also, make sure you guard your hardware against possible electrostatic discharge by wearing an antistatic wrist strap whenever you handle any internal components.
If you really want to upgrade your graphic card, let me know and post the additonal question in the thread. I will try to answer your questions.
Nov 24, 2008 | Toshiba Satelite 5205-S505 Notebook
How can I install my recovery CD's if my DVD/CD drive doesn't work
I had a similar problem with an IBM thinkpad once. My solution was to purchase a PCMCIA CDROM drive and boot from that. Go to: http://froogle.google.com/frghp?ie=UTF-8&oe=UTF-8&hl=en&tab=wf&q= and search for "PCMCIA CDROM". Your laptop should boot from one of these devices.
Feb 14, 2007 | Toshiba Satelite 5205-S505 Notebook
Toshiba Satelite 5205-S505 Notebook Logo
174 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
