Question about HP Color LaserJet 2600n Printer
HP 2605dn- replaced all toner cartridges now it won't print-
Printer says it is "Printing document" but will not print. All computers networked to this print have the same problem. Tried changing back to the old toner cartridges and it didn't change anything. Shut off printer for 10 minutes, still same problem. No paper jam found. Help please!
  • bygardner Nov 19, 2008
    Thanks for your suggestions. I had mentioned paper jam only as eliminating that as a problem. The network cable is plugged into the back of the printer. If there was a network problem would it still say "Printing Document" on the screen of the printer? How do you fix a network connection problem?
  • marcelkk Nov 25, 2008
    I do have the same problem. In my case, the printer is connected directly to my PC through USB cable
    The problem appeared after changing magenta tonner
  • 32 Answers
There might be a problem with the network connection. Is the cable connected to the back of the printer?
The printer could have lost the connection.
If the printer is able to print a configuration page and if the display responds to comands from the buttons in the display panel there is a very good chance the network connection was lost.
Yo mentioned "paper jam" is the printer identifying a paper jam?
Posted on Nov 19, 2008
  • longinos guereca
    longinos guereca Nov 19, 2008
    Usually the network admin. corrects problems with the network (password are required). Depending on the network settings you might be able to check the print que and see if there is a job thats causing a bottle neck and the printer to freeze.
    To acess the print que go to;
    Start, Control Panel, Printers and other hardware, view installed printers, click on the Laser jet 2600.
    There you will see a list of jobs pending for this machine. If you can, cancel all the documents. The top print job is the first and most likely to be the problem. You can also cancel it by going over to the computer that send the print job and cancelling it from there following the instructions I described earlier.
    The real problem might be the printer needs additional memory to work in an enviorment with multiple users.
I installed an original Q3971A toner into the HP 2840 laser printer, However there is still a notice to install cyan catridge. Can you help please
PDF]HP Color LaserJet 2840 and 2820 All-in-One for small and ...
h10010.www1.hp.com/wwpc/.../clj2820_clj2840_bro.p...
Hewlett?PackardColour laser printing. HP Color LaserJet ... •Convert hardcopy documents into digital format for easy ... Color LaserJet 2820 All-in-One gives you high quality, ... Oth ring. Why HP. Save time. Printing a file. Printing a paper fax. Receiving a .... Install, configure and manage multiple networked ... Replace toner cartridges easily.
HP Environment: Product Safety Information - LaserJet ...
Dec 18, 2015 | HP LaserJet 2840 All-In-One Printer
I have a HP Laserjet 2600N in my offie that is connected to the network. It is printing too much of yellow when printing any documents with colour. Please advise. Thank you
open the front where the cartridges, check if you notice runny yellow toner and toner surely you'll find under ', which replaces the yellow cartridge is probably refilat
May 25, 2011 | HP Color LaserJet 2600n Printer
I have an HP LaserJet1020 printer. When I try to print a document a 2 inch wide area the full length of the page on the right side of the page) will not print. If I change to landscape printing, the same...
Run the 1/2 print test.
Print a few pages that have failed previously and as the printer is printing open the cartridge cover(top cover).
Pull out the cartridge and look at the paper down below. If the page looks good, you probably need a new fuser. If the page is messed up you could have a bad transfer roller or another bad toner cartridge.
Dec 19, 2010 | HP Office Equipment & Supplies
Hp 2605dn Black cartridge is printing 1/8" LEFT of other colors.
That problem is frequently on HP 2600 series.
You must try to change all remanufactured toner cartridges with HP OEM with no exception, the best alignment it is when you change the black cartridge and the printer make a cleaning page process. Cartridge HP OEM should be almoust empty. It Is not necesarry to be a new one. After the alignment process, you can put the remanufacturated cartridges back on.
This was work for me. 100%
Sep 27, 2009 | HP Color LaserJet 2600n Printer
HP 2605dn Black prints 1/8" offset to left. Colors do register
Missalignment problems ae not uncommon with this series of printer.
The cause is one of the sensors (which are used for calibration and alignment) on the transfer belt, is faulty.
These sensors are NOT availale, and replacement of the transfer belt is the solution.
Transfer belt replacement on these printers requires quite a bit of dismantling, its not considered to be a user replacable consumable.
Printer is printing two smudge marks on my documents.
Two parts of the printer can affect this.
1) the toner cartridge
2) the fuser
Testing can be done to determine the problematic part.
Do a print using manual feed. Once the last bit of paper goes into the machine, open the printer door.
Remove the toner to check if smudge is there.
Replace toner cartridge if there is smudge, replace fuser it not.
May 29, 2009 | HP LaserJet 3330MFP All-In-One Printer
My HP LaserJet 2605dn is printing pictures with a bluish tone
Check the Colour management in printer driver on the computer - set this to Automatic.
On the printer or The HP ToolboxFX, check to see if Economode is turned on (under Print Quality) which reduces the print quality.
Dec 15, 2008 | HP Color LaserJet 2600n Printer
Printer says printing document but will not print. anything
I had this same problem, and after 45 minutes with HP support, eventually managed to get it to print by turning the printer of and then holding down both arrow keys (left and right) at the same time while turning the printer back on. I held down the arrow keys until it said "Language: English" and then clicked through the prompts. It then restarted, and all was well again.
Other places mention doing this with the OK and Cancel keys, but that didn't do it for me - the arrow keys did.
Jun 24, 2008 | HP LaserJet 2605dn Printer
Printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Mar 07, 2008 | HP LaserJet 4 plus Printer
HP Color LaserJet 2600n Printer Logo
214 people viewed this question
Ben Johnson
