Sony KV 36FS76
KV-36FS76 (AE5A chassis) sound for 15 secs then 5 blinks)
The previous owner of this TV kept it on by playing a fan on the back. I have taken the back off and it ran OK. Put back back on and it shuts down after a minute. Now hoever theres no picture at all (sound OK) and it shuts down after 10 secs. tried disconnecting panel C (on back of CRT) and then Panel 2D (Line output) but still trips after 10 secs.
Your help appreciated.
Email chris.lowdon@ntlworld.com
thanks
3 Suggested Answers
  • 7 Answers
SOURCE: Sony TV KV-36FS76U error code 5 blinks
Cristoffr, this is very, very interesting! I replaced all three ICs per the repair discussed over in Agoraquest:
http://agoraquest.com/viewtopic.php?topic=1121&forum=34&start=75&select_page_number=6
(scroll about half way down).
This did nothing. However, I had heard that a fan on the back of the TV might keep it from turning off. After the repair failed, I used a fan and for 24 hours the TV has remained on!
The Sony manual for repairing the DX-1A chassis gives testing and possible solutions for each of the blinking codes. About the five blink code it has this to say:
"Blanking - Standby light blinks five timesCircuit - The Ik signals are measured by Y/C, CRT Drive IC201 and areu sed to adjust the RGB gain to maintain color balance. As the picture tube ages, the Ik signals may fall below the threshold for automatic balance and mute/blank the picture. Testing - Increase the G2 control on the CRT’s C board. If that does not return cathode current to within operating range so the picture will appear, examine each filament to see if it is lit.
Then use your scope to examine the signal to the cathode. Go to CN9001/pins 1, 3 and 5 to see if there is a signal coming into the C board. Next check the signal at the CRT cathodes. If they are present, check the IK signal from CN9001/pin 8 of the C board. You should see three pulses and be able to change the level of the signal with the G2 control. If you get about 1Vp-p pulses at pin 8, this is the normal output from the CRT/C board so the problem is on the A board about IC201."
Note, Cristoffr that it mentions the C board in particular, the G2 control. However, it also mentions IC201 on the A board. I am going to post this finding to the Agoraquest board and see if anyone there has any ideas.
At least we have narrowed it down. We with the 5 blink shut-off are rare. Usually with the 5 blink problem the screen *blanks*, yet the TV remains on. I wish we could find a knowledgable tech who could diagnose this. Certainly this much information would lead him/her to a solution. I have heard it might be the flyback transformer, which does have a lead that goes to the C board. Possibly the flyback is not within output limits and the C board is initiating the shut down. Doesn't make sense though, because the power supplies are on the D board. Whew. Who knows? Anyway... I'll keep you posted with any info I gain, and I'd appreciate the same from you.
Cheers,
Sean
PS If you want to reach me via email you can at:
<remove>dallasdeckard<at>gmail<dot>com
But perhaps we should do most of our communication here for the benefit of anyone who has the same problem. Just a thought.
Posted on Nov 21, 2008
  • 5 Answers
SOURCE: my sony tv kv-36fs76 stanby light flashes red
power may be to low
Posted on Apr 16, 2010
Sony tv fault codes
This could be a fan error. But Good "Sony TV error codes" for more info
Sep 09, 2014 | Televison & Video
Kv-25x5u picture goes off but sound still there, red light at front flashes 4 times every 5 secs, picture comes back on after 15 mins
if you are a tech the set is having problem in the vertical and horizontal circcuit...check IC 1509 and Q1505.good luck.
Sep 13, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Cheers,
Sean
Nov 20, 2008 | Televison & Video
KV-36FS10 - No picture or sound Stand By Light blinks
5 Blinks usually means the horozontal circuit has problems and parts need to be replaced. unplug power to reset
Jun 15, 2008 | Sony KV-36FS100 36" TV
Tv wont turn back on
Hii.... first I like to know the chassis of yor KV27FS100..
sound like problem with regulated parts block.....and can more helpfull if you count the blinking of the LED....sony have selft diagnostic at the LED Blinking.....
I hope hear from you soon....
Thank's
[Vrya]
e-mail : be_cek@yahoo.com
Feb 23, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
SONY WEGA KV-32XL90E
Hiii...
what chassis your tv set ?
Thank's
[Vrya]
Jan 23, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
