Question about Philips Magnavox 20MT133S 20" TV
Tv showing blue screen with flyback lines sound ok
I have this philips 28 inches wide screen type that started its problem by showing poor picture with imposed flyback lines in blue colour.but afterwards the screen remain blue with flyback lines only no picture, no raster but sound ok pls help i this regard. many thanks to every one concerns
  • amos awosise Dec 27, 2006
    im still waiting for reply to solve the problem thanks
    pls pardon me for writing this late;the model no of my tv in question is 28pw6322 with chasis no md1.2e many thanks as iwait for reply.
    President:
  • 3,130 Answers
Flyback lines? Is the picture all white with no brightness control with faint horizontal faint lines? If this is what you are saying, the screen voltage could be bad, and if thats the case, the picture tube or the flyback itself could be bad. You could also have a bad connection on the crt socket
Posted on Dec 27, 2006
I have an old 36 inch widescreen Philips CRT TV which has been working fine for 7 years until yesterday when the whole screen just went blue with a series of white horizontal lines. The audio is still OK...
Hello
Since there is a blue screen atleast, I don't think that the picture tube is gone. The fault may be either to its chroma IC or video output section. In both sections fault cases, this type of horizontal lines [parellel to each other at about 1 inch or so apart the entire screen] will be seen. Just check the voltages at the three cathode, ie, red, blue and green of the piclture tube. This can be measured at the picrture tube neck card. If you have through knoledge in electronics, have patience and enough tools to do the work, inform me through Fixya. Without these, you can't work on a tv, especially in Philips.
Otherwise, get it checked by any expereinced service technician. OK.
Feb 21, 2011 | Philips Televison & Video
Picture Problems On 50 Inch Philips Plasma
You plasma still under manufacturers warranty. Most electronic devices have one year warranty.
The failure in your TV can only be corrected by repairing it.
I would suggest to call philips and ask them to find you an authorized repair center near you to get your TV fix under their warranty.
Jul 24, 2008 | Philips 50PFP5332D 50 in. Plasma...
Sony triniton 28" crt tv i have got sound but no picture
Any set can be repaired it is the question of the cost and the availability of the parts.
The fuzzy lines with static noise is probably from an arcing in the high voltage multiplier or in the flyback windinngs. I am very sure that the flyback assembly with the high voltage multiplier, and most likely the horizontal output transistor will have to be changed just to start. It is also possible that there may be some failure in the power supply as well.
The set would have to be serviced by an experienced TV tech. As for the cost, it will be a bit expensive.
Jerry G.
Apr 20, 2008 | Sony FD Trinitron KV-28FQ75 28" TV
RCA P52937SG 52" TV Made March 2002
youre having deflection problems could be related to the flyback. But this type of repair is better off with an experienced tech that has the proper equipment and knowledge to diagnose this chassis
Apr 06, 2008 | RCA P52937 52" Rear Projection Television
Poor
Hi there!
Sounds like convergence Amp to me. Refer to a repairer if you are not sure. Good luck,JUS004
Jan 11, 2008 | Mitsubishi VS-55707 TV
Picture fault
Hi.
What is picture like if you change screen size to 4-3  is this picture size ok & fault only shows in the wide screen formats.
Oct 10, 2007 | Televison & Video
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Philips 28PW6332 28" TV
Simple problem. In all likelihood, The Vertical Output IC has failed. It will be TDA 8177. Replace. Or, it could also be that the Supply to that IC has failed. Unless you are competent in Solid State repairs, do not try this by yourself. get a professional Technician to have a look.IC should not cost more than 15-20$ pluch Tecnician fees.
Aug 21, 2006 | Philips 28PW6506 28" TV
Philips Magnavox 20MT133S 20" TV Logo
315 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
