Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
External hard drive problem!
When you say change the casing do you mean to take off the casing and have a look inside!? there seems to be no start up noise, power noise at all! could it be a power supply problem i,e the power pack? need new one!
As the hard drive does not register at all on my computer!
    Master:
  • 568 Answers
Yes u can try checking the power supply of the casing
try other power supply of same capacity
if there is no solution for problem u can try changing the casing
if both the things are working fine then you will have to check the hard drive connecting directly to the computer internally
Posted on Nov 21, 2008
When I t urn on my laci external harddrive I get a fast pace blinking light and when I put my ear to it, it seems that the motor wants to start running then nothing Just a constant blinking blue light!
It seems that you have a problem with the disk-drive inside the case. If it still is under warranty, exercise the warranty to get it replaced.
If not, then disassemble the case, and remove the disk-drive.
Connect it as a "slave" disk-drive inside a desktop computer,
to see if it can be read. If not, then it is "dead".
You could buy an identical disk-drive, and put it inside the case,
to construct a "new" external disk-drive.
Sep 28, 2010 | LaCie (300770) 250 GB Hard Drive
My phillips external hard drive became disconnected and I can not get it to start up
Open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
If it still does not work, insert the external drive into the computer, feel the hard drive if it spins/vibrate from inside or if it makes a cracking noise.
If it spins/vibrate, it means the hard disk is still working. In that case, you have to get another external drive case/cover.
But if it makes cracking noise, then it means the hard drive is damaged and you need to get another one.
I wish you all the best.
Jan 11, 2010 | Computers & Internet
I have an HP 1TB External Hard Drive, but it won't connect to my computer. A blue light continually flashes on the drive when the USB and power source are plugged in. I don't know how to fix this problem....
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
All the best.
Jan 08, 2010 | Computers & Internet
Its not getting recognized it doesnt show up in the desktop
Take care
My mac says that it cannot detect a hard drive but it is powered up and plugged into usb port. help!
Its not getting recognized...though it used it before
Best regards
Jan 08, 2010 | Western Digital Passport 320GB External...
No response freez making funny noise
Is it an external drive?
If it is, open the external hard drive cover, remove the hard disk inside, and fix it back. Try again and let's see what happens.
Lastly, if its not an external drive, the same applies because, its still all about hard drive.
Jan 08, 2010 | LaCie F.A. Porsche (301177) Hard Drive
My hard drive doesn't start. I was on vacation for a month, before leaving I unplugged it and now I returned, plugged, but it makes noises, but no lights or info...
is it an external hard drive? If its not an external hard drive, the same solution still applies because its still about hard disk.
Jan 07, 2010 | Computers & Internet
My lacie rugged 500gb triple interface normally worked but now doesn't load anymore. It makes a strange soft sound for 2 seconds and then nothing. help!!!!
Jan 06, 2010 | LaCie Rugged All-Terrain (301175) 160 GB...
USB hard drive not recognized by Mac and by PC
Does the external drive work when connected to some _other_ computer? (Friend? Office? Home?)
It could be a failure either in the "hardware" inside the external-case (the USB adapter & interface)
or in the disk-drive "inside" the external-case.
So, a qualified technician can open the external drive, remove the disk-drive, and connect it directly to a computer, to see if the files can be "directly" read from the disk-drive.
If not, then you should search online for a "data recovery" service -- they are expensive, but they physically repair a damaged disk-drive, just long-enough to copy your data to another disk-drive.
May 29, 2009 | Western Digital 250GB MyBook External USB...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
