Question about Panasonic Lumix DMC-FZ30 Digital Camera
FZ-30 LCD flat ribbon cable broken
My FZ-30 LCD back screen became dark.
I dismantelled the cam and I saw that the flat ribbon cable that conects the lcd to the main board is broken.
Electronics repairs is my job, but I can't find the replacement part.
Could u help letting me know where this part can be ordered?
Thanks
Salvador Frigola
(Spain)
  • 1 more comment
  • diplomatico Dec 16, 2008
    My DCM FZ30PP LCD went also black - I´m not am electronic technician but have mechanical habilities.
    My question is disasembling the part will damage the camera, how dificult it is to do it.?
    JJ Alvarado
    Diplomatico@cableonda.net
  • kwamemensah Mar 14, 2009
    The LCD of my DMC-FZ30 does not come on. Anybody knows how I can solve it?
  • nuwan77 Mar 24, 2009
    I was using FZ-30 for 2 years. Last week I have accidently left it on an A/Ced room and took it outdoors, where humidity is very high (Sri Lanka) - and immediately i saw mist building-up inside the lense and the camera. My wife was operating the camera at that time and she noticed the LCD screen having a problem. It only had horizontale lines and a fuzzy picture. But, if I can still use the View finder.
    I would like to know if there is a connection between the 'Mist building' up inside the camera and this problem.
    Thanks,
    Nuwan
  • 3 Answers
Part No is VYQ3473. You can order it directly from Panasonic. It will cost you 29 USD without taxes.
Jimi
Posted on Jan 26, 2009
  • Amy G Oct 08, 2013
    WOW! I have this problem. Thanks for the solution. I can order the part, but I am NOT an electronic technician so I won't be able to fix it myself. I can't seem to find a "person" or place to talk to me about my specific problem to find out how much it will actually cost to fix it. Any advice?
    Oh, and I have a Lumix DMC-LX3. Do you know the part number for that?
I don't need anybody's help, I just need to be supplied the part I described in my first post that is broken, nothin else, I have no problem to replace it myself. Thanks anyway.
Back to the question, do u know who can supply this ribbon cable'
S.F.
Posted on Nov 20, 2008
I had an incredibly difficult time trying to find a replacement flat flex cable for my plasma tv...all service centers just wanted to push a service call on me....anyway after a long search i stumbled across digikey. they have everything you could ever need
Posted on Apr 17, 2009
I have a lcd toshiba mod 52xv545u the left side is dark it reset it self
Looks like a Tconn problem caused by
1 Main Power supply inside unit
2 Tconn board itself, or ribbon cable connections
3 panel, or ribbon cable connections from Tconn to panel(screen)
Feb 02, 2015 | Toshiba 52XV540U 52 in. HDTV LCD TV
Dark screen
May not be all of a back lighting problem. The circuit board that controls the screen may be faulty or just a bad connection on the ribbon cable that connects to the board. .
Jan 04, 2014 | Hannspree HH251HP 25 in LCD TV
LN46A530 Samsung LCD -half a screen black-stays for 30 minutes, than turn to some what normal, but not quite all.What is the problem , what is the part to replace?
is it completely dark or just very dim or dark on one side? if it's just dark on one side, you have a failing LCD panel, very common for older Samsung panels. If it is completely black on one side split down the middle, you could be dealing with a bad panel, bad t-con board, or a faulty LCD panel ribbon connection.
Sep 07, 2013 | Samsung LN46A530 46 in. LCD HDTV
My cybershot camera has no display only display white screen
I fixed the camera myself as follows:
1. Hold camera firmly in left hand
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
It worked, now the LCD is working again for free.
Jul 27, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
The screen is broken no take pitchure
Remove the battery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
Apr 01, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
Arcing sound when on then goes dark. Repeats when restarted
your ribbon cable to your LCD panel has a broken spot in it need to replace the LCD
Jan 13, 2010 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
I have a Sony DCR-HC17E. Suddenly LCD screen went blank... What can it be?? can isolve the problem without going to sony?
Most likely, you can not, ribbon cable connecting LCD assembly to main board is broken and it comes as hinge assembly. So, you will have to buy at list the part from sony.
Nov 09, 2009 | Sony Video Cameras
How do I change the LCD screen please?
Very easy.
Remove the batery. Remove the case screws and pull the case apart. Where the flat ribbon cables connect to the main board, carefully release the clamps on the board end plugs. The plugs don't come off, the ribbon just comes out of them. Carefully remove the screen. It has double stick foam in a few spots. Put the new screen in, reconnect the ribbon cables and put the case back together. 30 minutes max.
Sep 30, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Nikon D50 lcd problem
I'm sure that the auction/sale has ended for this, but I'll go ahead and answer it. Yes, it could be a simple loose/broken cable. But when it comes to cameras, is that a good thing? Something had to jar that cable. Nikon builds are strong, possibly the strongest. The guy who owns that camera was probably very rough with it, and therefore MUCH more could possibly be wrong it (fractures, scratches, etc.)
I bought my d50 used, but the guy I bought it from was smart enough to take SEVERAL pictures, including that of the glass, the mirror, display, everything. I had the option of buying a d50 for $150, and all it had wrong with it was a crack going along the outside of the analog lcd and down part of the camera. Problem was, how hard did he drop it? He might have even knocked the internals around!
Save yourself headaches, and most probably expensive future investments, and be sure what you're buying is in mint condition (body scratches and general wear on rubber grips, etc. aside). Most people who own SLRs (with exceptions to some professionals) cradle their cameras like it's their baby.
Aug 19, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
SD400 broken screen
found this guide on the net once, try it out and let us know what you think: " WARNING: this repair voids your warranty and may damage your camera. Perform at your own risk. The publisher of this site is not responsible for any damage you cause. This replacement is of medium difficulty. If you have ever ?built? a computer from parts, you are probably capable of it. If you are patient, orderly, and meticulous, you can probably do it. But you do risk breaking your camera even further, so don?t do it if you won?t accept that risk! Be carefully that you are grounded and thus do not harm the camera via static discharge. Google the terms ?grounding? and ?static discharge? if you need more info. I only performed this operation on a Canon SD300 / Ixus 40, but readers have reported that it is the same on the SD200 / Ixus 30 and on the SD400 / Ixus 50. Read all of the instructions before proceeding. Within each step, I don?t necessarily use exact chronological order. Tools: a small Phillips head screwdriver and a smaller flathead screwdriver (used for prying). Step 1. Ascertain what is broken. Symptom: your screen still glows with light, but shows crazy colors or a visible crack surrounded by crazy colors. Problem: your LCD screen is broken but your backlight still works. You need only purchase a new LCD screen. Symptom: your LCD does not glow. Problem: your backlight is probably broken. This didn?t happen to me, so I don?t give any further advice about this problem on this page. However, the information on this page will take you about 60% of the way to replacing the backlight as well, so it may be useful. Step 2. Order a replacement screen. UK: H. Lehmann's Ltd: +44 (0)1782 413 611 at a cost of 33 GBP (including shipping) US: Canon? +1 732 521 7230 / +1 800-828-4040 at a cost of around 66$ (including shipping) The part number for the SD-300 / Ixus 40 LCD screen (without backlight) is: ck9-1103 The part number is the same in the US & UK. I do not know whether the SD-200 / Ixus 30 LCD / SD-400 / Ixus 50 LCD part number is the same.. Step 3. Open the camera - Remove 6 screws in total: 2 from the left side, 2 from the right side, and 2 from the bottom. - Gently pry open the case - The plate covering the ?grommet? to which you attach the strap will fall off. So will the round grommet. Don?t worry about it. Step 4. Remove the screen & backlight assembly from the back of the camera - Remove the screw from the upper right corner of the backlight/LCD package. Note: this screw is of different size to those you have already removed. Keep it separate. - Be careful of the tongue extending from the bottom right corner of the backlight/LCD package. It?s very tiny and easy to miss. You want to be sure to slide it out, because it?s easy to just break the plastic into which the tongue slides. (I did. Not a huge crisis, but I wish I hadn?t!) - There is a tab on the left side of the backlight/LCD package. Pull it back slightly so you can lift the backlight/LCD package. (I used the flathead screwdriver to pry it off.) - You should now be able to lift up the backlight/LCD package. It will still be connected to the camera body via two ribbon cables. Step 5. Separate the LCD from the backlight - There are a number of fiddly plastic/metal tabs holding the two together. Just gently pry and poke until you have separated them. It?s a bit time consuming, but I can?t really give better instructions than these. - You should be left with the LCD totally separate from the backlight, but still connected to the camera via a ribbon cable. - The backlight should also remain connected to the camera via a ribbon cable. Step 6. Undo the LCD ribbon cable - The LCD ribbon cable extends under the bottom of the camera (actually passing under the tripod screw hole, which cannot be removed). It re-appears in the front of the camera and is connected to a socket. The socket is rather like a DIMM socket on a computer. It has a flat, black, clasp which is folded down to hold the ribbon cable in the socket. - Examine carefully the way the ribbon cable is attached to the socket. Note that it is pushed in entirely, so that the wider part of the cable (with two holes at either side of it) is flush against the socket. - GENTLY lift the clasp (I used the flathead screwdriver). It should swivel up and the ribbon cable should fall out. DO NOT YET PULL THE RIBBON OUT OF THE CAMERA. Step 7. Totally remove the LCD - Tape a long, narrow strip of paper to the end of the ribbon cable. This paper is to help you thread the ribbon cable of the new LCD back through the inside of the camera. - Note how the ribbon cable is threaded under the tripod mount to the front of the camera. Wiggle it around a bit, get a feel for it. Sliding the new one back through is a bit tough, so experiment with how this one fits and where it goes. - Gently pull the ribbon cable out from under the tripod mount, leaving the broken LCD screen now completely detached from the camera. Make sure to leave the paper threaded through the camera so that you can tape it to the new LCD?s ribbon cable and pull that one back through. - If you messed up with the paper, don?t worry. You can still push the new ribbon cable through: it just takes some wriggling and some time! Finishing. - You have now got to go through the process in reverse, installing the new LCD screen. - Threading the LCD ribbon cable back under the tripod mounting screw is tough. Just keep sliding it back and forth and exert pressure to push it through. It will go through, eventually. - As you connect the LCD ribbon cable, read the ?white screen? problem below, so that you do not suffer from it! FAQ 1. My screen just shows white or gray. (E.g. white screen, white display). What did I do wrong? A. The ribbon cable that connects the LCD to the circuit board was not inserted deeply enough. The end of the ribbon cable has a narrow portion, then a very small much wider portion with two holes at either end, then it narrows again. The very tip should be inserted into the "socket" deeply enough that the wider portion is pressed right up against the "socket." Physically, it cannot be inserted more deeply. It may help you to use two wooden or plastic toothpicks, one in each of the small holes at the end of the cable, to push the cable into the socket." If you feel like supporting the author of this thread, go to his website through this link: http://www.cl.cam.ac.uk/~jo262/broken_lcd_cracked_screen_canon_sd-300_sd-200_ixus-40_ixus-30.html Good luck
May 18, 2006 | Canon PowerShot SD400 / IXUS 50 Digital...
Panasonic Lumix DMC-FZ30 Digital Camera Logo
858 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
