Question about Sharp AL-1642CS Copier
Sharp AL1642 CS Copier Grinding noise and Paper Jams
When trying to make a copy, this machine makes a loud clacking noise and the paper jams up before the toner is fused onto it. The paper seems to start jamming up once the first part of it has passed over the drum, then it bunches up accordian style and the machine stops and the paper jam light comes on. I have to pull the jammed paper out and this ends up making a mess of toner inside the machine. Is this easy to repair myself? Help please. Thanks!
  • doesntwork Nov 29, 2008
    Well, we took it apart to see what you were talking about and put it back together and the clacking sound and jammed copy problem is now gone! Maybe they were just out of alignment a bit or something? Not sure, but at least it is working because I couldn't find anywhere online where I could order parts. Thank you for your help. Hopefully it won't act up again.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Loud clacking sound, jamming in fuser ? sounds like the gear that turns the fuser are bad and not meshing together,
accordion jam is the fingers or claws that ride on the fuser roller are probably worn out ( these can be replaced usually 3-5 ).
You can buy the parts and replace them yourself if a handy person, not that difficult.
Posted on Nov 19, 2008
My sharp 2300-n notified me of a paper misfeed. After clearing all misfed paper, the copier is still telling me there is a misfeed, and is not allowing me to print or copy. Suggestions?
Make sure that all of the paper jams are removed. Check every available cavity, including your paper trays. Pull each tray out and make sure there are no jams right out of the paper trays. Sometimes a piece of paper can become lodged where you cannot see it.
If you are positive there is no paper stuck in the machine, then you have a paper-path sensor that is either dirty or faulty.
Oct 29, 2010 | Sharp MX-2300N Color Copier
Weird noise no copies
does it intake the paper at least??
in some kind of problems paper alone rolls in and out with out copying.
is that the problem.
please clarify
Aug 11, 2008 | Sharp AL-1642CS Copier
Paper jams at the fusing unit on my Sharp AR 275
Very common problem in that copier. The fuser unit has little pawls which seperate the paper from the rollers, they can become dislodged when customers remove jams. Another very common problem is the gear that turns those rollers wears down internallly, to check this make a mark on the orange fuser roller with a sharpie. See if the mark moves from it's previous spot after trying to make a copy. These rollers turn every time the machine is used or is turned on.
Sep 10, 2010 | Sharp AR-275 Copier
Copier jams after making one copy
Is the jam Physical? (Damaged lead edge where it may have caught some thing)
Is the jam Timing (paper if perfect, it just stopped.)
If it is Physical then you need to look for the obstruction, paper clip, staple, or small piece of paper. Check very carefully, remove any foreign matter and retry.
If it is a timing jam, the start by removing the paper, check inside the the paper feed area for foreign material, fan the paper and carefully reinstall it, making sure it is the right size paper for the paper cassette. if it has movable guides in the tray, be sure they are firmly against the paper on all sides.
Close up the machine and try again.
Hope this helps.
ed
Apr 28, 2009 | Kyocera Copystar CS-1820 Black and White...
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
EP4000 Back to back copying paper jams
THE INK MAY NOT BE TOTAL DRY WHEN MAKING BACK TO BACK COPIES, SOMETIME YOU NEED TO LET THE PAPER TONER DRY, LET THE PAPER COOL OFF BEFORE PUTING IT THREW THE MACHINE AGAIN, AND I KNOW ITS A PAIN IN THE BACK SIDE.
TRY IT
CANDYMANGANDY
Jan 28, 2009 | Minolta EP4000/5000 CS/PRO Copier
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Aug 22, 2008 | Canon PC-920 Black and White Copier
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
"Jammed" message
Try new paper.Damp paper causes all kinds of jamming prob.
Jul 13, 2008 | Copystar CS-2030 Copier
Jams EVERY TIME
Where is the paper jamming? Out of the paper tray or under the drum or in the fixing unit? Did you make sure you have the paper tray set up to the correct paper size and orantation for the paper in the paper tray and dose it happen at any other time and where is it jamed up at. Need more info.
Mar 14, 2008 | Sharp AL 1631 Copier
396 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
