Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
GE side by side fridge with Water and Ice despenser
GE Side By Side Fridge, pulsating fan in freezer. Fan runs for 3-4 seconds and stops for 3-4 seconds, in a cycle and is fairly loud. I unplugged and took most everything apart. Everything looked fine. When I put it back it ran ine for about 5 minutes then started up in the cycle again. Everything seems to be at the right temp, fridge is 2 years old
    Problem Solver:
  • 5 Answers
If you have plastic bags (vegetables, storage bags) that are close to the middle sensor, the sensor cannot determine that the food is cold (plastic bags confuse the sensor). Move the plastic bags away from the sensor. The top shelf has vents that should not be blocked with plastic bags. There is also a larger sensor at the bottom of the freezer that should not be blocked as well.
I called a repairman for mine since the fan kept cycling and making a whistling sound. Within an hour the sound went away and it's been 3 days without the sound.
Posted on Dec 21, 2009
Djones, I have the exact same problem as you. However, I do not notice mine happening all the time. Maybe once a day. It is annoying and my frige, like yours, is about two years old. How long is the warranty do you know? I bought GE because I thought they were reliable. nymustang.......
Posted on Dec 26, 2006
    President:
  • 878 Answers
Djones, The evap fan motor should not change speeds in less than 1 minute of time. The fan motor has two speeds. Usually this is a indication of a failing main board. If you have a meter you can do a voltage check at the J-2 connector on the board. Check for 13VDC between pins J2-3 and J2-8 and 8 to 13VDC between J2-3 and J2-4. If this voltage stays steady, your problem lies in the evap fan motor. If this voltage drops out or fluctuates, it's more than likley the board....Catriver...post back.
Posted on Dec 14, 2006
I have a ge refridgerator gss25k side by side. thefridge/freezer are not cooling. the bottom of the fridge freezes and the top is warm.
There is an air duct that connects the fridge to the freezer. A fan circulates air to cool the refrigerator.
The inside fan has stopped working or is blocked by ice.
Defrost the freezer. If the fridge starts to work properly then you have an auto defrost problem. If the fridge still does not work then there is a faulty fan.
A technician can help you there
Apr 03, 2011 | GE GSS25KGMBB / GSS25KGMWW / GSS25KGMCC...
Loud noise from freezer of GE model GSF25TGTB (Side by side)
Problems not related.  The first is most likely the fan, or possibly water dripping on to the fan and freezing, but usually the noise comes from the fan struggling to run.  The cube problem could be as simple as the ice dispenser being put back in wrong.  There is a metal lever under the ice tray that switches between crushed and cubed.  Make sure it is seated properly.
Dec 04, 2009 | GE GSF25XGR Side by Side Refrigerator
Temperature control
The freezer is usually cooled by the compressor, the fridge is then cooled by an evaporator fan motor ($30). If this fan seizes or slows down then the fridge warms up (it sometimes starts squealing before this happens). The fan may spin, but it if goes too slowly, then it would blow enough cool air into the fridge, especially if it is opened quite frequently.
If you think it is the evaporator fan motor:
Check to be sure you can get a replacement fan first, they last about 4 - 5 years. Can get from a parts supplier or electric motor company.
UNPLUG fridge. Located usually in top of freezer behind a vented cover plate. Remove cover, remove screws holding fan in, may have to cut wires. Replace with new motor, make sure the fan pushes air into the freezer area and doesn't spin backward drawing air from the freezer area.
Oct 31, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
GE LXS18JFBLB-2 MODEL WITH BRITA WATER DESPENSER ON DOOR
sounds like clogged water drain
in a side by side it is located in freezer section at bottom
in top freezer ref it is in freezer too but behind back cover
if either are iced over remove ice and pour sum really hot water down drain until u see it go down
Jul 09, 2008 | Refrigerators
Fridge/freezer not cold. Fan or compressor not running....
possibly main pcb faulty but may just be in defrost mode where the fan and compressor will not run . In which case the ice build up will be due to faulty defrost heater or stat
Jun 14, 2008 | GE GSS22JFMWW Side by Side Refrigerator
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
156 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
