Question about Toshiba TDP-T9U Multimedia Projector
White lines across the screen
My proyector (TDP-T9U) shows two white lines at the left across the screen all the time, How can I fix this, I have 2 months with it so I do not thing it is the lamp.
  • johndoenz Aug 21, 2008
    I have the same problem with my TDP-T9 model. Second time used.
This is just a guess, but it's an LCD projector, it's possible the LCD itself is going bad. It's common for LCD panels to develop vertical lines when they are failing.
Just an idea,
Ray
Posted on May 24, 2008
I have the same projector and had the same problem, the main board was replaced under warranty and the lines went away.  6 months later they are back again.  The projector can handle a high resolution so that is not the problem.  The white lines appear even when no source is connected (splash screen)
Posted on Oct 22, 2007
Sometimes if the resolution is set too high, white lines will appear.
Posted on Jul 09, 2007
The Projector will not allow me to put the screen in Color......the area that says color is greyed out and it's projecting in black and white
Reset the proyector, go to the menu and do it. otherwise you must read your owner manual section troubleshooting. download from
www.retrevo.com or www. manualslib.com
God bless you
Oct 29, 2013 | Toshiba TDP-T45U DLP Projector
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computers & Internet
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Toshiba tdp-t9u projector
It is likely your bulb is going out, or your fan is broken & it is oveheating.
Jun 23, 2008 | Toshiba TDP-T9U Multimedia Projector
Trouble with output to the projector
Hi there
Check the following on your laptop.
Right click on your desktop , go to properties and settings - check if your resolution of the PC is the same as that of your Projector. i.e. 800x600 or 1024x768
Also check that your secondary monitor is attached / activated.
If the signal stil won't pick up - hold down the Fn ( function button) left of your spacebar and press in your F-row of buttons the one with 2 screens on it. ( differs from brand and model )
Hope this helps you and good luck with your class tomorrow !
Mar 31, 2008 | Toshiba TDP-T9U Multimedia Projector
Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Jan 01, 2008 | BenQ PB6100 Multimedia Projector
White horizontal, zig-zagging lines
Sounds like the flyback transformer is bad. couple of 100 dollars if it is that
Dec 03, 2007 | Televison & Video
Toshiba TDP-T9U Multimedia Projector Logo
977 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Timothy Van Der...
Adorjani Laszlo
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
