Question about Brother EM-530 Typewriter
Codes Some kind of command was entered into the typewriter.  When I hit the "Shift 2" to get the "@" symbol, I'm getting the " symbol instead.  When I hit the "Shift 3" to get the "#" symbol, I'm getting the "/" symbol
  • Lindsay2626 Dec 15, 2008
    I have the same exact problem. Your solution was to put it back to keyboard 1 mode. But how do you do that?
    Please help!
    Thanks,
    Lindsay
    Scholar:
  • 183 Answers
You problbly put the machine in "keyboard 2" mode, just put it back into "keybrd 1"
Posted on Nov 22, 2008
How do I type numbers 1-0? I type 9 and get parenthesis.
The shift key is depressed. Hit shift again and it will go back to using the numbers. Any symbol on the top of the key will require the shift key to get it to work.
Jul 17, 2014 | Brother GX-6750 Electronic Typewriter
Hi there. I'm using Casio FX-570ES scientific calculator. I would be glad if you could guide me as to how to obtain derivative of a polynomial expression e.g. y=12(x^2+6)^5
Here is an example. Instead of SIN(X) insert your polynomials.
The syntax of the command is
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the variable X.
May 28, 2011 | Casio FX-115ES Scientific Calculator
How to find derivatives using fx115-es
Example : Calculate
Oct 29, 2010 | Casio FX-115ES Scientific Calculator
Im not sure on how to caculate derivatives on the calculator, help would be appreciated
If you do not want to specify a tolerance just the last comma and tol.
Example : Calculate
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
When I hit shift and the number 2, instead of the @ sign I get /. I know I have apparently hit a code to change the keybrd. It does this on all the symbol keys. How do I switch the mode? Cannot find my...
You are in KBII mode There should be a key usually in the top row that is labeled KBII. Press the code and that ket it should take it out or that mode.
DickyO
Jul 20, 2010 | Brother EM-630 Typewriter
Hi i have a Brother SX-4000 electronic typewriter and for some reason when i press shift 2 i get n with a ~ over it instead of the @ symbol that i'm trying to get. Please help.
You are in KB II mode some T/Ws have a slide switch, some have a key that must be used with the code key.
Go to BROTHER.COM, click on support you will find a manual there.
DickyO
Jun 11, 2010 | Brother SX-4000 Typewriter
Is there a way to set typewriter to type numbers and uppercase?
There may be a caps key. You can get a manual @ brotherinternational.com, click on support.
DickyO
Apr 20, 2010 | Brother SX-4000 Typewriter
Instead of getting the @ symbol when I press shift +2 i get "
you need to hold down ctrl and function on the left side of your keyboard, and then hit the shift key on the right side of your keyboard. Then let go of right shift while still holding down the control and function keys, and then hit right shift again.
these blue keys are french keys. if you change your keyboard settings to english US or UK, it will get rid of the blue functions, but for some reason, they tend to turn themslves back on again after time. Most likely due to automatic updates followed by an auto restart. Also, I find that the issue only arises if I am in my hotmail account.....no issue in Word docs.
Jan 13, 2010 | HP D8597A Keyboard
Symbol prints for one letter - small c
If it is 2 vertical lines the printwheel has a bent or broken spoke.
DickyO
Nov 19, 2009 | Brother Office Equipment & Supplies
Numbers instead of symbols
Press the shift key to change it back to lower case.
Jul 16, 2008 | Brother GX-6750 Typewriter
Brother EM-530 Typewriter Logo
424 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
