Question about HP LaserJet 4700N Printer
Needs to be switched off and on again to print
We have a networked 4700n printer. In order to get anything to print we have to switch it off and on again and then print. I f we leave it too long it fails to print. Any suggestions?
    Scholar:
  • 78 Answers
It sounds as if it is loosing it's ip address, or possible an IP conflict exists. If not already done, assign a static IP address to the printer within the local network range, and one that is different from any of the other PC's on the network.. You may have to then reset the printer ports on each of the PC's
Posted on Nov 19, 2008
  • 32 Answers
Cleach78;
This problem could be associated to many causes. I would go with a process of elimination. Here are some of the reasons why the printer might freeze;
  1. There might be something in the print que causing it to freeze?
  2. Have you tried to completely clear the print que? (I had a customer have the same problem a nd it was due to a corrupted file they kept on trying to print.)
  3. Firmware might be another issue. The firmware might be outdated and causing conflict within the printer.
  4. Low memory.
  5. Faulty I/O card.
I would check these possibilities and see if any of these are causing the problem.
Problem error 493048
The problem is usually caused by printing a file with font, size, or page formating errors on a printer with out of date firmware.Once the error has occurred, the only way to use the printer again is to cycle the power and delete the print job from the server or print queue.
Occationally a hard reset is required.
Make sure that the job is cancelled before powering the printer on again or the error will return.
You should try updating the firmware to the latest version from the HP website.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?pnameOID=473039&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=473038
Mar 12, 2014 | HP LaserJet 4700N Printer
Printer goes out of network often, then if I switch off and switch on the D-ling print server power, the printer comes in the network but for a short time period only, then again the printer goes out of...
Two possible problems. Move the printer closer to the wireless router, and if that doesn't work, it is probably a failure in the printer. Also, see if there is a setting on your printer to force it to try to reconnect automatically.
Nov 19, 2017 | D-Link DP-301P+ Fast Ethernet Print Server...
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
HP 4700n leaves marks on prints
Either the fuser or the copy drum assembly is worn,first replace the drum, if it doesn't clear the problem, it's the fuser.
Aug 20, 2009 | HP 4700N Color Q7492AABA Laser Printer
HP CLJ 4700 empty display, no answer
When the display is light and printer is ready for printing but does not pass pages:
There are still jobs in the memory buffer of the printer.
This could be solved by pushing the oval select-button.
Notice:
1. Entering the oval select-button also activates the new control panel settings (when they have been changed).
2. Printer control panel settings could have been changed over a network cable: checking the settings is a next step when problems do
disappear.
Aug 12, 2009 | HP LaserJet 4700 Printer
Keeps reseting to Tray 1
Printer Defaults button? what magical land is that found in?
Here is the real solution:
In Printers and Faxes, right-click the printer
Click Printing Preferences
In Paper Source drop down, select Tray 2.
Peace!!
d(-_-)b
May 14, 2009 | HP Office Equipment & Supplies
HP LaserJet 4700N
paper jam on tray 1. How to open the back part of the printer.
Oct 17, 2008 | HP LaserJet 4700N Printer
Can't find HpLj1300n in my workgroup
Try the "Add New hardware" wizard in Control Panel, or use the install disk.
Jan 03, 2008 | D-Link DP-300U (DHDP300U) Print Server
HP LaserJet 4700N Printer Logo
76 people viewed this question
Ben Johnson
