Sounds like your wireless network is setup to require a password (it has encryption) most commenly used is WPA, WEP and WPA2, you will have to ask the person who setup the network for the password.
Here is some more information from the NETGEAR site on WEP encryption for a wireless network:
What is WEP Encryption for Wireless Networks?
Wired Equivalent Privacy (WEP) is a security protocol for wireless networks that encrypts transmitted data . It's easy to configure. Without any security your data can be intercepted without difficulty.
However, WEP was an early attempt to secure wireless networks, and better security is now available such as DES, VPN, and WPA. See the
Guide to Internet Security to learn about network security.
WEP has three settings: Off (no security), 64-bit (weak security), 128-bit (a bit better security). WEP is not difficult to crack, and using it reduces performance slightly.
If you run a network with only the default security, where WEP is turned off, any of your neighbors can immediately log on to your network and use your Internet connection.
- For wireless devices to communicate, all of them must use the same WEP setting. (40-bit and 64-bit WEP encryption are the same thing - 40-bit devices can communicate with 64-bit devices.)
While there is no extra performance cost to encrypting the longer key, there is a cost to transmitting the extra data over the network. 128-bit security is not much more difficult than 64-bit to crack, so if you are concerned about performance, consider using 64-bit. If you're very concerned about security, use WPA, which replaces WEP with a protocol that is - given current technology - impossible to crack. There's a good overview in
What's New in Security: WPA (Wi-Fi Protected Access).
The WEP concept of
passphrase is introduced so that you do not have to enter complicated strings for keys by hand. The passphrase you enter is converted into complicated keys. Choose passphrases with the same care you would important passwords.
- With 128-bit encryption, you need to enter a passphrase to generate each key.
- All four keys must be specified, because WEP switches between them to make your traffic more difficult to break.
- All devices within your LAN must use the same passphrases (i.e., the same keys).
WEP is not necessary if you have a gaming console such as PlayStation or Xbox, and there are
no other computers on the network.
Read Instructions on how to
Configure Wireless Security (WEP/WPA/Access list). Instructions are also included on the User Manuals and Reference Manuals for wireless products (available on the Product page on this site as downloads).
Doc ID: N100684.asp April 7, 2003
WPA-PSK is far superior to WEP and provides stronger protection for the home/ SOHO user for two reasons.The process used to generate the encryption key is very rigorous and the rekeying (or key changing) is done very quickly. This stops even the most determined hacker from gathering enough data to break the encryption.
