Question about Lofra MXUD66GGI Gas Kitchen Range
The ignition on our cooker stopped working after flash from rear
Lofra MXUD66GGI gas cooker new 10.01.2006 ignition works by pressing in the burner knob and sparks till lit. trying to light left hand smallest burner there was a bang and flash from rear right hand of cooker and now no sparks from any of the burners or ovens.
I have noticed that since this happened the knob for this burner does not push in as far as the rest. When I use a flame all rings light and work normally .
Please can someone help me
  • Lofra Master
  • 3,897 Answers
There usually is a unit at the back that is the ignitor i don't know on this model but it should have a fuse fitted to the igniter, its usually 3amp, check and see if it has blown this fuse. check it with another fuse and see if there is still a problem the fuse will blow if it gets a back feed. this could be form the switch that you push.
Posted on Jun 21, 2017
4 Suggested Answers
SOURCE: cooker lofra
fuse in plug new one job done + wife turnd oven off ?
Posted on Sep 03, 2008
  • 4 Answers
SOURCE: Can't find parts for Lofra range cooker
hi mark have you tried this service?
http://www.elementreplacement.co.uk/made-to-measure-ovencooker-elements-144-c.asp
Posted on Nov 18, 2009
  • 3238 Answers
SOURCE: Lofra cooker turns itself off
Hi looked on the wed could not find anyone only lofra try try them, hope this helps
Posted on Jan 16, 2010
I have a rangemaster classic 90 dual fuel..we have changed the spark generator. Now it sparks on all burners but when the oven is lit the sparking continues on all burners, how do we stop this?
Hello Stephany,
this cooker has an ignition system by pressing the knob of the item that you want to ignite.
As all sparkplugs work and only the oven is the source of the problem, i think that the contact behind the knob of the oven sticks
It looks like this one and is behind the facia, between the knob and the valve.
I hope this helps, Dik
Mar 25, 2017 | Rangemaster Kitchen Ranges
Our Lofra gas stove tops ignition isnt working on all jets. Electric oven is working. What could be the issue ?
personally I would call a repair service . gas being dangerous I do not recommend DIY fixes
Sep 12, 2016 | Lofra Kitchen Ranges
When the power is turned on at the wall, the automatic spark that lights the gas top comes on on the two right burners, and wont stop even after the light is lit. What can I do about it?
Behind the knobs for the right burners are 2 electrical switches that start the spark when you turn the knobs on. One of those switches is bad and stuck in the on position. You have to pull the knobs off and remove the trim behind the knobs to get to the switches.
Mar 22, 2015 | Lofra Kitchen Ranges
I'm having problems keeping the grill lit on my BEKO dvg593-mk2 gas cooker. This has been a problem almost since new, i have to depress the gas knob, and keep it pressed for about 5-8 min's after ingn
Here is the owner's manual or try calling customer service at 0870-241-1321 for help. http://www.manualslib.com/manual/15108/Beko-Dvg593.html?page=3#manual
Feb 12, 2015 | Grilling
I CLEANED MY CANNON CARRICK COOKER TODAY AND NOW THE IGNITION WILL ONLY WORK ON THE TWO RIGHT HAND HOBS. OVEN ANG GRILL ARE FINE AND LEFT HAND HOBS CAN BE LIT WITH A MATCH.
More that likely your just got the cleaning solution you used on the igniter/in the burner. Light the burners with a match and let them burn for a little bit of time. This usually works. If not you might have to clean the igniter and make sure it is creating a spark for ignition.
Mar 07, 2011 | Ovens
Hi i have a new imperial fryer and im tring to light it and cant seem to get it to work. any idea on how to get it working?
Have a lighter handy (I use one of the elongated ones for caravaners)
in-between the burners is a pilot light (top right) keep the lighter flame where the gas comes out.
On the right hand side of the fryer at the bottom is a gas valve with a little black knob.
Press and hold the black knob in and gas will come out of the pilot light and ignite by the lighter flame. You need to hold the button in for quite a while. (until it stays lit)
When it stays lit depress the little black knob and turn it anti clockwise. Gas comes out of the burners and ignites from the pilot light. When it reaches temp. it will cut out.
To turn it off turn the little black knob clockwise. To turn the pilot light off, push and turn clockwise.
Mar 04, 2011 | Imperial IFS40 Deep Fryer
KitchenAid gas stove main burner igniter does not work when the control knob is turned to the ignite position; however when any one of the other burners control knob is turned to the ignite position, the...
Hi Cecchung,
I think I know it.
Modern cookers have semi automatic ignition. Behind every knob there is a hidden switch and the switches are wired in "parallel". That means, when one button is put in "sparkstand", all plugs will spark. At least it should be.
In the youtube movie you can see how these switches are in a string.
So I suppose that the switch behind the button for the main burner does not work.
Fortunately, you still can lit that burne r with the other buttons.
Look at the movie, may be you can fix it yourself.
Kind regards, Dik
Maytag Gas Stove Burner Won Light Spark Ignition Switch
Feb 04, 2018 | KitchenAid KGST307 Gas Kitchen Range
do you have a clue where i can grip some knobs for lofra gas cooker.
MXUD66GGI. i have tried every where can you help me.thanxs.
Jul 15, 2009 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Cooker lofra
Aug 18, 2008 | Lofra MXGC96AMF/CV Dual Fuel (Electric and...
Door came off
need more info but you got 5 years waranty in parts and 1 year in labor claim it, post back...good luck
Aug 07, 2006 | Lofra MXUD66GGI Gas Kitchen Range
Lofra MXUD66GGI Gas Kitchen Range Logo
71 people viewed this question
Top Lofra Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
ray gallant
Are you a Lofra Kitchen Range Expert? Answer questions, earn points and help others
