Question about Apple Power Mac G5 Desktop
RESET PASSWORD DIFFICULTIES
I was given a solution to my reset problem. The instruction was to use the install disc. I did that, but the feature that I was asked to avoid, the SYSTEM ADMINISTRATOR (root), that was the only feature to pop up in the process to resetting my password.
There is nothing on my Desk top but the password box.
This system was originally a Tiger and this year I install Leopard. It has worked properly until the computer was broken into last weekend.
Heeellllppppp!!!!!!
Thank you so much for your assistance.
Regards,
Everette
  • 1 more comment
  • EVERETTE NICOLLS Nov 19, 2008
    Holding down the C key is not working. I have been doing that all morning. I have also done the same with the N key.
    Under the C key, when the installer comes up, I click on Utilities. The features beneath that are START UP DISK, RESET PASSWORD, DISK UTILITY, TERMINAL, SYSTEM PROFILER, and NETWORK UTILITY.
    I click on Reset Password and that takes me to the RESET PASSWORD BOX. The first sentence there is: Select the Mac OSX disk which contains a password to reset. In the bar immediately beneath that is an image of the disk with this information: Mac OSX...1 Disc1. Outside of that box is this sentence: Select a user of this volume to reset their password. The next box is grayed lightly. That says: No available users. The boxes beneath that states: Enter a new Password for the this user, then re-enter and Enter a new password hint for this user etc
    When I click on the Disk image, the box beneath it becomes active, but it states, SYSTEM ADMINISTRATOR (root). The up and down arrows on this box has no other features. The new password is not accepted in the window below that.
    I do not know how to enter FIRMWARE because there is nothing opening on my Desk top. Only the password sign in box.
    I have hit the wall in frustration.
    If I click on the Startup Disk, that takes me to: CHOOSE STARTUP DISK. Select the system you want to use to start up your computer.
    Three is the image of the installer disk, the Network Startup, and Mac OSX 10.5.5 on Mac HD. I have tried all of these and none have worked.
    The installer disk is 10. 4.
    How do I get to FIRMWARE if the Desk top is not booting up?
    Thanks for your assistance.
    Regards,
    Everette
  • Loteck May 11, 2010
    Is there data on the hard drive that you need to retrieve? Also, what model of computer do you have and what operating system (OS9,OSX) are you using.
  • Krabby May 11, 2010
    Have you fixed this problem yet? If not I can tell you what is wrong with it.
  • 11 Answers
If you have the install disk, restart the Mac and hold down the C key after you hear the startup chime. This will start from the CD. Under the Installer menu, you will then have the option to reset the password for the admin account, which will enable you to reset any user password.
Instructions from Apple are here: http://kb.wisc.edu/helpdesk/page.php?id=3853
Posted on Nov 19, 2008
What must i do,i want to reset my password but im experiecing difficulties?
The easiest way is to click on "forgot password" at your email login screen. Follow the instructions you are given.
Aug 13, 2016 | Computers & Internet
Password reset on dell 518
Reset Your Windows Password Using the Command Prompt
1. Boot your computer using your Windows installation disc.
2. Wait for the setup files to load, and select your language. Click Next.
3. Click the Repair your computer link on the Install Windows screen.
4. Select the operating system to repair, and note the drive letter on which the OS is installed (it is probably C: or D:). Click Next.
5. Click Command Prompt at the bottom of the list of recovery tools.
Now you need to overwrite the Sticky Keys executable with the Command Prompt executable. Sticky Keys is an accessibility feature that allows a user to tap the Shift, Ctrl, Alt, or Windows key once to achieve the same effect as holding the key down. Ordinarily, tapping Shift five times activates Sticky Keys--but with this trick, you are going to make tapping Shift five times activate the Windows Command Prompt instead.
The instructions below use drive letter C: as an example. If your operating system is installed on another drive, replace C: with the appropriate drive letter.
1. In the Command Prompt window, type copy c:\windows\system32\sethc.exe c:\ and press Enter.
2. Type copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. At the login screen, tap Shift five times. The Command Prompt will pop up.
4. Type net user username password, replacing username with your username and password with a new password.
5. Exit the Command Prompt, and log in using your new password.
To prevent another user from exploiting the same trick to reset your password, you can restore Sticky Keys as follows:
1. Step through the instructions above to boot the PC using your Windows installation disc, open the recovery tools, and launch the Command Prompt.
2. Type copy /y c:\sethc.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. Pressing Shift five times will now activate Sticky Keys instead of the Command Prompt. Store your Windows installation disc in a secure location.
May 03, 2014 | Dell Inspiron 530 Desktop Computer
Forgot Sony Vaio password
I met the same difficulty for the previous period,and I know the easy an effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other unlocked computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you soon.
Jul 25, 2012 | Sony Computers & Internet
Reset windows vista
I met the same difficulty for the previous period,and I know the easy and effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other computer.
Hope it can help you reset windows vita password soon.
Jul 20, 2012 | Toshiba Computers & Internet
Password for acer aspire 5570
an effive method that you can use Windows Password Reset Deluxe to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset Deluxe from and install it on other unlocked computer.
I hope it can help you reset windows password soon.
Jun 28, 2012 | Computers & Internet
Forgot user password
Tip1:Download Windows Password Reset from windowspasswordreset.net and install it on your computer.
I hope you can reset windows password soon.
May 21, 2012 | Advent Computers & Internet
Lost windows password
To get more helpful info, u can search the method source:
Windows Password Reset Std/Windows Password Reset Pro/Windows Password Reset Deluxe,and have a try.
Follow my steps:
Step1:Download and install Windows Password Reset Deluxe.
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in your newly created CD and remove Windows Password.
Hope it can help.
May 12, 2012 | IBM ThinkPad X40 Notebook
I have apple i book g4 i forgot my password.
Changing your administrator password
To change the administrator password, you must know the current administrator password. If you're logged in as the administrator, open Account preferences and click the Change Password button.
If you don't remember the password and automatic login is turned off, you can reset the administrator password using the Mac OS X User Install disc.
IMPORTANT: Because a user with the Mac OS X install disc can gain unrestricted access to your computer, you should keep the disc in a safe place.
To reset the administrator password using the Mac OS X disc:
  1. Insert the Mac OS X Install disc and restart the computer.
  2. When you hear the startup tone, hold down the C key until you see the spinning gear.
  3. When the Installer appears, choose Utilities > Reset Password.
  4. Follow the onscreen instructions to change the password.
  5. Quit the Installer and restart your computer while holding down the mouse button to eject the disc.
Be sure to change your login password in Keychain Access to match your new password.
Aug 05, 2011 | Apple iBook G4 Mac Notebook
Forgot my password and master password and I'm locked out my mac book
Customer forgot password
If the customer forgot the password for the computer:
1. Insert the Software Install and Restore DVD.
2. Restart the computer while holding down the C key on the keyboard.
3. When the installer appears, chose Reset Password from the Installer menu
4. Follow the on-screen instructions.
Here is the link to the user manual and below that is the factory service manual...
http://manuals.info.apple.com/en_US/PowerBookG4_15inch1GHz-867MHzGettingStarted.PDF
http://tim.id.au/laptops/apple/PowerBook%20G4%20(15-inch%20FW800).pdf
Oct 05, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Hp printer wont print through print server
Share printer option needs to be turned on
Realize that the scan option only funtions on local connection
Aug 11, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Apple Power Mac G5 Desktop Logo
181 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
