Question about Xerox Phaser 8500/DN Printer
The ink seems to smear or drag down the page.
This is worse at startup but continues through the print job.  Replaced the maintenance kit a month ago.  Thanks for any help.
  • comment
    comment May 11, 2010
    Did this maint kit include the fuser? Did the problem exist before you did the maint kit?
    President:
  • 2,072 Answers
What normally causes that condition is a worn or dirty wiper blade. That blade is located between the print head and the drum. Is will not clean properly between prints.
There is a possibility that the maintenance kit could be the problem depending on how it was stored.
That is a roller impregnated with silicon lubricant, if it is stored standing on end, the lubricant will seep to one side and the opposite side will be pretty dry causing smears and streaks.
Also, have you gone into the tools mode and run the cycle to remove smears and smudges? That can help resolve your problem.
With the problem getting somewhat less as you run, I would take a good look at the maintenance kit just to see how it is cleaning. Look at the large roller and see if there are any sopts.
Posted on Nov 19, 2008
Throw the P.O.S. in the trash!!!!! Buy a decent printer next time!!! ;0
Hi I am having a problem with our business HP LaserKet 424n printer; when we print anything out it seems to make a noise that it normally doesnt make, and our paper ends up looking smeared to the point ink...
Take print out of configuration page(menu-information-configuration page), chech the maintenance kit interval 2,25,000 crossed?
YES... replace maintenance kit & Swing plate assm..
NO... check fuser sleeve surface arrested with toner?...Replace fuser...
Sep 04, 2011 | HP LaserJet 4240n Printer
Phaser 8560 not printing RED correctly
Even though Media Sciences ink is not compatable and is subject to burning and clogging your printhead, the most telling symptom you listed is the red shavings. This indicates the ink is not releasing from the drum properly. This version of solid ink has a problem with the cams on the maintenance camshaft cracking and this causes the maintenance kit roller to not oil the drum properly. You will also hear an odd noise either grinding, groaning or a slight tearing sound. This requires a technician to resolve as replacing the camshaft is not an enduser job. Print quality issues are either the printhead or related to the camshaft failing, there are a few others but they wouldn't exhibit the symptoms you listed.
Jan 11, 2010 | Xerox Phaser 8560N Laser Printer
Xerox Phaser 8560, produces cyan colored streaks whenever this ink is used. No other colors produce streaks.
You are probably using "Media Sciences" ink sticks (Non-Xerox).
This means the printheads jets are clogged, and the printhead needs replacing.
Media Sciences released a defective lot of cyan ink sticks.
They are currently replacing printheads (at their cost) if you call them.
Aug 12, 2009 | Xerox Phaser 8560DN Laser Printer
Paper jams w/ all types of paper, Ink blotches...
If you're getting spots on the prints, run the Remove Ink Smears routine in the maintenance. It will clear the ink from the preheater. User packing tape to pull dust off of pick rollers. It's easy to unclip the unit and roll it on a piece of tape to remove dust.
Jul 30, 2009 | Xerox Phaser 8500/DN Printer
Blurry, Ink Smeared pages
If the media (glossy paper) is designed for an ink jet printer you should be fine.
Ink has to be able to be absorbed into the fibers of the page. If you are using paper for a laser color printer, that's your problem.
Don
Jun 19, 2009 | Ricoh Aficio CL7300 DT2 Laser Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
HP J5780 Problem-Line on printed pages
most likely you have a flat spot on the roller.
that is exactly what is going to happen, when the paper hits the flat spot or a low spot. the paper stops and skips. them the print is coming out smeared.
you can get a repair kit or replacement roller from HP.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Streaked & smeared printing on envelopes
Check area where the envelope is pulled into the unit. There may be some debris causing the ink to smear.
Sep 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Print Quality - Shadowing
What does the white roll on the maintenance kit look like?
Is it really dirty? It could be either the kit, maybe the ink.
But in partiular if the kit was stood on end and not stored laying flat, the lubricant in the kit may have saturated one side and depleted on the other.
I have never seen the non Xerox ink, and have no clue if it would cause a problem like that.
I suspect a maintenance kit, that it is dry on one end.
Mar 30, 2008 | Xerox Phaser 8550DX Laser Printer
Print jobs smeared
Hi Are you using OEM or rebuilt toners? If your using OEM and your able to smear the ink with your finger more than likely you have a fuser problem?. If your using rebuilt cartridges it could be the cartridge. Good Luck!!
Nov 28, 2007 | HP LaserJet 2550L Printer
Xerox Phaser  8500/DN Printer Logo
182 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
