Question about Dakota Car Audio & Video
Headlights will not come on
Headlights, dim or bright, will not come on unless I hold the arm that turns on the brights constantly
  • 68 Answers
The fuze is goin bad so check that and if thats not it ur spring isnt springing right to hold the on
Posted on Nov 21, 2008
Both dim headlights will not burn. brights work just fine. checked fuse and switched relays with no result. any other ideas??
Most headlights have two different bulbs: one for regular/dim and one for bright. It's time to replace your headlights.
Oct 27, 2012 | 2006 Chevrolet Trailblazer
Alternator failed and blew the headlights 2 qty. dim, 1 qty. bright. Replaced the alternator and the headlights, but the dims don't stay on when the brights are engaged.
Hi:
Normal operation of the headlight circuit is to just have one set of headlights on a time, bright or dim, but not both.
Sep 09, 2010 | 1992 Ford Thunderbird
My headlights are really dim at night. But everyone says there fine. what should i do?
The headlights on my Tahoe are dim too. It's also a 1999. I replaced my bulbs with Silverstar's but it was still dim. I used Mequiar's Headlight kit to polish off the yellowing and oxidized headlight's and it really made them look good but they are still not bright. They look bright but the light hitting the road is still weak. It's because the inside of my headlights are a little bit cloudy still. The heat damage from the bulb made the insides cloudy and the light is still weak on the road at night. That's all I can do unless I replace the headlight assemblies. Much money and not super simple to do. I have very bright bulbs just cloudy housings that still don't allow the beam to fully shine through. I don't know if that is your issue but I hope this helps.
Jan 27, 2010 | 1999 Jeep Grand Cherokee
Where is the headlight dimmer switch locate on the 1990 Sundance? Thank you
either the turn signal arm or a foot switch at the driver left foot area---pull the turn signal arm towards the driver to see if it clicks the headlights bright or dim-----if not, then look for a small floor switch that you step on to click on and off
Jun 22, 2009 | Plymouth Sundance Cars & Trucks
98 Explorer's Headlights won't work...have to hold highbeam on
Sounds like your switch is bad (i.e. turn signal / healight dimmer / winshield lever switch) inside the steering column. Replace as necessary.
Apr 07, 2009 | 1995 Ford Mustang
2001 honda civic dim headlights will not come on just brightlight
Low beams are separate bulbs and could possibly both be burnt out
Apr 04, 2009 | 2001 Honda Civic
2002 Grand Am GT Headlights seem dim , fog lights dont work
Check at the headlight sockets for a bad ground.
Mar 02, 2009 | 2002 Pontiac Grand Am
Dims don't work but brights do.
I believe that all of the Functions Listed above are on the Same Handle. There is a Half Moon Circuit and Switch that Goes around the Steering Shaft inside the Steering Column for this Handle. This is Malfunctioning and will need to be Replaced. Not an Easy Job. You will need to Pull the Sterring Wheel and go from their. Please Rate My Response! Thanks!
Feb 03, 2009 | 1995 Ford Mustang
Headlights wont come on and bright lights won't stay on hold bright light switch and blower works
I had the same problem. The solution is simple; the ignition switch needs to be replaced. This is an easy do-it-yourself project. Here are instructions:
http://forums.vwvortex.com/zerothread?id=2532481
Check for a switch on ebay, they are about $15. After 10 years they wear out.
Oct 07, 2008 | 1998 Volkswagen Jetta
Car Audio & Video Logo
Top Dakota Car Audio & Video Experts
brucem57
Level 1 Expert
Mohamed Ismail
Mohamed Ismail
AzVip
Are you a Dakota Car Audio and Video Expert? Answer questions, earn points and help others
