Question about Rival 32 Oz. Hot Pot - White
White scale forms on the heating element of the Rival Hot Pot
What is the scale? I only use Distilled Water, which should be mostly free of impurities. I'm concerned that the scale is something harmful that I'm consuming when using the boiled water for tea or coffee.
  • 218 Answers
SOURCE: rival crock pot
Yes, it's not unusual for the outside to be too hot to touch. A slow cooker won't get as hot as a bare burner on the stove, but it still gets hot enough to cook meat. The outside has a bit of insulation, but it still may get hot enough to cause pain, melt a bread bag, etc. Be sure and place it where no one will accidentally touch it.
Posted on Jul 19, 2008
  • 15 Answers
SOURCE: crock pot doesn't heat!
www.rivalproducts.com
ask an expert!
good luck
Posted on Aug 22, 2008
SOURCE: Oval 6 Qt Ceramic Liner Needed for Rival Crock Pot model 3855
If you are still looking I may have what you need. I live in Canada so you would need to pay the shipping which could be high as the liner is heavy. If you are interested feel free to email me.
Posted on Sep 04, 2009
  • 4 Answers
SOURCE: I have a Rival smart pot given to me no instructions
You do not put water in the base. Just put your ingredients in the crock part and whatever liquid the receipe calls for. you can probably find the instruction manual on crockpot.com or call and ask them to send one.
Posted on Nov 16, 2009
SOURCE: How to clean the inside of tea pot (scale
Vinegar is very good at removing scaly deposits. Heat white/clear vinegar just as you would normally heat the water for your tea. After heating the vinegar, pour out and rinse thoroughly with water. If there are still deposits after this first attempt, use vinegar once again. Once you are satisfied that all the deposits have been removed, heat water in the tea pot 2-3 times to remove any smell or taste from the vinegar (before using for tea).
Posted on Jul 14, 2010
Why does my self cleaning gas water heater make clicking noises?
zdriscoll-
All tank water heaters make some amount noise, clicking and "snapping" sounds, particularly after much of the hot water in tank has been used (like after a long shower) and has been replaced by cold water that is being heated vigorously.
If the noises are accompanied by poor or erratic performance, or obviously if something malfunctions, you may require the services of a repair connection.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Can't remove all that scale on this v745a humidifier. thanks
Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and let it sit for 30 minutes, Then start the humidifier and let it run until almost all of the solution has been used. Turn the unit OFF, empty the remaining solution and fill the tank with Bottles Distilled Water. Turn the unit ON and run for 30 minutes. This will flush out any of the remaining solution. The remaining water should be disposed of and in the future, use Bottled Distilled Water, rather than tap water. That way you will not have to worry about calcium and mineral build up at all. Plus, the mist that's generated will be totally void of any harmful minerals.
Hope this helped you solve the cleaning issue. Please let me know. Thanks!
Apr 19, 2011 | Vicks Warm Mist V745A 1 Gallon Humidifier
My coffee maker takes 20 minutes to brew a pot of coffee- extremely slow- I've lost the manual and do not know how to correct this...please help.
The first suggestion is de-calcify as the heating element is probably coated. The following should explain what I mean.
Most likely you have calcium flake deposits clogging the orifice/jet/valve, that restricts the flow of water until heated properly. As the water starts to flow the flakes collect and block the water flow. Periodic cleaning will cure this and prevent damage to the, orifices, jets,valves and heating elements of your machine ( as calcium builds up it tends to insulate the heating element thus requiring more energy/heat to complete the task). Eventually the heating element will over heat and burn out. Periodic cleaning extends the life of the machine plus the added bonus of a better tasting " Cup of JOE".
Most any cleaning preparation designated for a "Mr. Coffee " type machine will do the job. If you want a home remedy 3-4 tablespoons of white distilled vinegar per cup of water ( calculate for the size of your water reservoir ). But please do it outside on the patio, as the vinegar tends to be in competition with the air freshener, and will win.
sincerely,
Doc Michael
Mar 08, 2011 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
Rival crock pot smart pot - low, keep warm & hot lights blink and pot will not heat. is there something i can fix or is the pot destined for the garbage truck?
Some times it can be fix wit heat element.The manufacturer may have this part available to buy.Go to the website with your model number.Find it buy it install it do it your self and save.It may need some soldering done,or it may just unplug.Good Luck!
Aug 08, 2010 | Rival 38601 Smart Pot 6-Quart
The inside bottom of my crock pot doesn't heat up, is that normal
Hi. The heating element is located on the in side / sides of your **** pot base in a circular element. That is normal.
Jan 06, 2010 | Rival 3755 5.5-Quart
My hot water from the Mountain Plumbing hot water dispenser has a lot of white pieces in it. Has the tank failed?
No attack on this scale is heating element that dissolves when it is possible to disconnect apperaat water heating and draining than doing it in vinegar and let the heat once again connect and then empty and most calcium is removed from apperaat
Nov 08, 2009 | Mountain Plumbing Mountain The "Little...
How do I clean the heating elements in my swan tea kettle. it looks like a mineral build up on the elements that comes off when the element is hot and the minerals fall into my tea water
IF THE BUILD UP OF SCALE IS BAD YOU MAY HAVE TO TREAT SEVERAL TIMES TO CLEAN. VINIGER IS A GOOD CHOICE, JUST FILL ABOVE THE COILS AND LET SIT AND DO THIS AS MANY TIMES AS IT TAKES TO CLEAN THE COILS. ANOTHER GOOD PRODUCT IS CALLED- CLR MOST HOME DEPOTS HANDLE THIS PRODUCT IT STANDS FOR C-CALSIUM / L- LIME / R- RUST
THIS IS A LITTLE STRONGER THEN VINIGER BUT DOES THE SAME THING. BOTH WILL TAKE SEVERAL CLEANINGS
Sep 05, 2009 | Swan Kitchen Appliances - Others
Overcooks
The older crocks did not seem to get as hot as the ones form the past 10 years. I have an old blue and white one that I use only to make yogurt, since it is not as hot. I do not believe you can adjust the newer ones, just use the low setting. Good luck.
Jun 21, 2017 | Rival 38601 Smart Pot 6-Quart
Won't heat up.
There may be a fault with the thermstat or the heating element.
Jerry G.
Apr 29, 2008 | Rival 32 Oz. Hot Pot - White
Rival 32 Oz. Hot Pot - White Logo
65 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Henry  Thomas
Henry Thomas
Ric Shull
Ric Shull
Level 1 Expert
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
