Question about Emerson EWD7003 DVD Player
Dvd player freezes up
My dvd player will play a dvd for a little while and then the picture/sound will freeze. It won't let you eject the disc or turn the player off. I have to unplug it and turn it back on to get the disc out. I just bought a cleaning disc but the player keeps saying there is an error and to eject it. I dont' know what else could be wrong? Its only four years old and I'd rather not replace it already
  • aliciag Dec 01, 2008
    mine's less than a year old and it's doing the same thing! i'm going to blow it out with canned air and see if helps but it's play light doesn't turn off even when it's open and the disc isn't turning until i turn it unplug it and turn it back off, otherwise the power button wont work.
Kimi
  • 277 Answers
SOURCE: dvd does not play, firmware does not reconize disc
The laser lens in your player might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Posted on Dec 04, 2005
techman
  • 3130 Answers
SOURCE: Dvd player not reading ANY disc
If you tryed to clean it and it didnt work you could have several things that went wrong and depending on what did go wrong will tell you if you wanna spend the money or buy a new one. If the laser assy went bad you probably will buy a new one. if you find a good authorized repair shop, then it may just need cleaning and a servo alighnment. or a bad spindle motor, or your missing a switched voltage on the power supply could be missing. Im sorry to tell ya that there are no user serviceable parts inside this unit unless your a tech. The only info i have for emerson is the help # Maybe they can show you where to take the unit to be servced/ 905-940-5089 Good Luck
Posted on Jul 01, 2006
SOURCE: Play Back
Some DVD players can't read -R & -RW disks. When you finalize make sure it is in Video mode not VR mode so the recorded disk will be able to work in most other DVD players. Also some DVD players only read recorded disks rated up to 1x, 4x, 8x, 16x, or a combination of these speeds.
Posted on Nov 15, 2007
  • 239 Answers
SOURCE: DVD will not play disc
You need to find a good dvd cleaner and clean that real well run it a couple of times that should fix your problems. If not you may have to bring it in and get the optics cleaned by a professional. But I am confident if you get a good cleaning disk it should fix it, Happy Holidays
Posted on Dec 14, 2007
catnip20
  • 11 Answers
SOURCE: Will not initialize a new disk; often freezes up when trying.
Hello, I would suggest opening the unit & cleaning the lens with a cotton swab lightly soaked with rubbing alcohol. Especially if it has been used in an enviroment wich is dusty or the unit has been smoked around. Also, are you using the same type of discs, Some discs are better quality than others try using Imation they read in almost anything. Also if you do have to clean the lens you may want to lighty lubricate the rails the laser moves on using a drop or two of 3in1 oil per rail.
If it still will not work then I would say that the laser pickup is failling. Specificly the laser used for burning the disc, Since there are usually two lasers one for burning & one for playback.
Posted on Feb 17, 2008
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
Picture "freeze up" during playback
your laser lens is probly dirty ;/ just use a qtips and alcool and gently clean the lens if it not work proper ly may be your laser assembly going out...
hope that will help you....
Apr 20, 2010 | Toshiba SD-3750 DVD Player
DMR EZ47V freezes occasionally, will not play certain discs
i hope ,too.if its only months since you bought that ,avail of the warranty package that comes with it.
May 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Sharp rw 260 : we are unable to eject dvd
Got help from yahoo answers little hole by dvd drawer inserted needle and hey presto working ok again. yipee
May 01, 2009 | Sharp Televison & Video
Picture will freeze.
Either the disc is scrathed or you have to remove the cover and take a q-tip with rubbing alcohol and clean the lens.
Jan 22, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
Jan 21, 2009 | Televison & Video
Stops Playing: screen freezes
My friend suggested I clean the dvd optical reader lens inside the player with a fine brush (like a camera brush with a blower bulb). This seemed to help immensely. I'm not certain if this is just a temporary fix, but it seems to be ok so far.
Jun 06, 2008 | LG DP781 Portable DVD Player
DVR 120 Disc/Screen freezes half way through
CD does not run
Clean lens and adjust the disk level
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
This fault would only occur on c.d play back. The sound would gradually start to distort, until all that could be heard was complete distortion. This fault was intermittent and would occur whenever it felt like
Believe it or not,this fault was cured by replacing the optical unit
Nov 24, 2007 | Samsung DVDR120 DVD Recorder
Philips dvdr 3320v picture freezing
Be sure there is plenty of space around the DVD player. I place mine on top of the cabinet without anything on top if it. Being enclosed seem to affect some DVD players. Also, dust frequently...
Jan 09, 2007 | Philips DVDR3320 DVD Recorder/VCR
DVD player freezes
If it's a very cheap unit, it's possibly because the machine can't process the information quickly or efficiently enough, thusly causing the picture to freeze up while the processing catches up with it. Friend has a $30 unit, which happens to constantly.
Nov 07, 2006 | Sanyo DVW-6000 DVD Player/VCR
Emerson EWD7003 DVD Player Logo
41 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
