Heating & Cooling Logo
Anonymous Posted on May 04, 2012
Water is leaking from the inside of whirlpool split a/c. This is a recurring problem. The engineer fixes it, but it pops up again after a few months..
Anonymous
Level 3:
Brigadier General:
  • Master 6,468 Answers
  • Posted on May 05, 2012
Anonymous
Master
Level 3:
Brigadier General:
Answers
6468
Questions
0
Helped
2131727
Points
13357
Clean out the drain
Testimonial: "thanks Mike....I blew into the drain pipe & water started coming out of it ......"
Saravanan
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 21, 2014
Saravanan
Contributor
Level 1:
Answers
Questions
0
Helped
2455
Points
0
I myself resolved this issue. I removed slowly the parts of spilit AC and found bunch of dirty was blocking the hole, where the water drains usually. Then removed it and solved. Saved a huge amount. The service men would told something else and cheated by charging it with bla bla bla spare parts failure..:)
5 Related Answers
Anonymous
  • 400 Answers
  • Posted on Mar 19, 2009
SOURCE: WATER LEAKING FROM MY SPLIT TYPE LG AIRCON
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Anonymous
  • 13 Answers
  • Posted on Feb 07, 2010
SOURCE: samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Anonymous
  • Posted on Dec 31, 2008
SOURCE: leaking water from inside samsung split sytem
if your indoor unit is leaking water down the wall,it is from one of two things.First, is possibly the insulkation on the copper lines is coming loose and the suction line is condesated,with no way to drain,it drips down the unit.The other possiblity is that the drain hose is coming loose from vibration and leaking a little.
Anonymous
  • 674 Answers
  • Posted on May 04, 2010
SOURCE: SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
Anonymous
  • 192 Answers
  • Posted on Feb 01, 2011
SOURCE: split a/c leaking from inside
You have an obstruction in your condensate drain. After a couple years of use a slime builds up in the trap and needs to be cleaned out.
2helpful
2answers
Why does the motor overheat and looses water
You have a leak somewhere is the obvious answer, the hard part is finding the leak, it could be a hole in the rad or a split in a hose somewhere, I suggest you drive the car for 15 mins, park it up, pop the hood/bonnet and see if you can see a leak, then look under the engine ( on the floor ) and see if there are any leaks on the floor. you can get solutions you put in the radiator to fix radiator leaks, but a hose, could burst and cause a massive engine failure, hoses need to be replaced.
2answers
My lg washer appears to be leaking from the soap tray area, what needs to be replaced and how?
The hose from the soap drawer to the tub may be split. These hose have flexible ridges and its common for them to split inside one of the ridges.
2002 ford taurus. Radiator overflows but, temp gauge not hot.
It could be both your thermostat and water pump, it could also be an air lock in your cooling system. One way or another, I think pressure is building up in part of the system because its not circulating properly.
When its cool, take the top off your reservoir, give the bottom hose to your radiator a good few squeezes, see if the water goes down a little, if it does, you moved something on and probably cured it.
If not, run the engine up, to get it warm and bleed off any air in the system. (Assuming there are bleed taps in the system)
If that also does nothing, I reckon its your water pump. And if your changing that, I'd suggest changing the thermostat at the same time.
2helpful
1994 Toyota Pick-up 4-cyl. overheating
I had the same problem and i replaced my fan clutch and it stayed cool at all times. that's is the problem.
2answers
Water leaking from stacker unit
No parts are replaceable within the pump. Buy a new pump.
1helpful
2answers
I have whirlpool refrigerator. it is a frost free double door model. Recently I have found water is dripping from the top of the fridge portion. It directle falls on the vegetable drawer and water is...
It is over charged with gas. but that will probably leak out again in a few months don't worry. The leaking water are most probably because the drain hole inside the refrigerator is blocked with algae growth.
Toshiba 61H70 Popped Loud & Fixed Then Popped Again & Again ;(
my guess is that that high voltage seals on tubes are leaking out high voltage from tubes if not probly sealed with silicon they will leak out high voltage.replace them and seal coorrectly this may fix your problem
Top Whirlpool Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
