Question about Lexmark X1240 All-In-One InkJet Printer
Cover open continues to appear
I have tried many times to open and close the cover, including adding and removing the ink cartridges. I re-installed the program and the same problem re-occurs.
    Genius:
  • 2,035 Answers
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located
Posted on Nov 19, 2008
There's a problem with the printhead
Try this approach to fix the printhead problem:1. Open the printer cover > remove the ink tanks > open the printhead latch > remove the printhead > close the printhead latch.2. Visit the Lexmark website to download and install the Lexmark Pro700 Series Firmware Update.3. After the update is successful, open the printer cover > open the printhead latch > re-install the printhead > close the printer cover > if no error appears, continue with normal installation steps for cartridges. If error still appears, try to remove and re-insert the printhead firmly.
4. Try to print again to verify that the problem is fixed.
Should the error persist, it could be that the printhead itself is faulty. If that's the case, please contact Lexmark Technical Support for further assistance.
Feb 08, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
How do i reset ink cartridge cl511for my canon ip2700
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
Sep 20, 2011 | Canon Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
Trying to change the ink cartridge out.....but i dont know how can you plz help? it is a mp250
Click on the below link, which will direct you to Canon's site where they store the manuals -
Canon Pixma MP250
If you select the on-screen manual for your operating system (either Windows or Mac OS) it will take you to a downloads screen. About 3/4 of the way down is a tick-box Download - click to select, then a red word Download will appear. Click on this and you will download a file which when run will be the manual for the product which includes instructions on how to change the ink cartridges.
Thx, if this solution helps please rate :)
Feb 08, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
When I Turn on my Canon Pixma Mp210 the error 6 pops up. I try to restart my printer, but it didn't help. What this error means and what to do?
Issue: ERROR LED: E, 1, 6
Solution: Press and hold Stop/Reset button for at least five seconds
Clearing the Ink Error If you want to continue printing in this condition, press and hold the <Stop/Reset> button on the printer for at least five seconds, and then release it. Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Solution: Replace ink cartridge(s) MP210
Replacing An Ink Cartridge Use the following procedure to replace empty ink cartridges or when an ink cartridge error appears.
  1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
    Note: After confirming that the scanning unit support is fixed into position, release your hands.
    *MP470 shown
  2. Press down on the semi-circular tab (circled area in <1>, above) to release the cartridge and then remove it.
    Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
    *Optional cartridges PG-40 and CL-41 shown in examples
  3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
  4. Take out a new cartridge from its casing and gently remove the orange protective tape in the direction of the arrow.
    Note: - Do not attempt to reattach the protective tape once you have removed it.
    - Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
  5. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
    *One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
  6. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
  7. Confirm that the ink cartridges are installed properly.
    <1> The ink cartridge is not installed properly.
    <2> The ink cartridge is installed properly.
  8. Fold the scanning unit support and close the scanning unit (printer cover).
  9. Wait until the preparatory operation is complete; it takes about one to two minutes.
Trust this is helpful. :)
Dec 10, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
I recently replaced the magenta cartridge in my HP 3210 Photosmart printer because the light indicated it needed to be replaced. However, the printer still won't print, and the message still says that I...
If you turned the machine off and replaced the cartridge, you can get this error.
Could you try the following procedure below please to clear the error, thanks.
  1. Turn on the unit.
  2. Open the top cover to access the print cartridges.
  3. Remove the new cartridge that is causing the message.
  4. Reinsert the cartridge and close the cover. The following message will appear on the front panel: "Press 1 for new cartridge or press 2 for a used cartridge."
  5. Press the 1 on the numeric keypad of the HP product.
If the message, press 1 for new cartridge or press 2 for a used cartridge, "does not appear after removing and reinstalling the new cartridge, and the low ink warning message still displays,
follow the steps below:
  2. Open the top cover to access the ink cartridges.
  3. After the cartridges stop moving, unplug the power cord.
  4. Remove both cartridges and close the top cover.
  5. Plug the power back in. The unit will reinitialize and a message will appear to insert the cartridges.
  6. Open the top cover and reinsert the ink cartridges. Close the top cover. The message,
  7. Press 1 for new cartridge or press 2 for a used cartridge," should appear.
Hope this helps
Regards.
Apr 18, 2009 | HP Photosmart 3310 Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Say's empty
If you still need help:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.html?reg=us&c=us&lang=en&prod=dcp110c_us
Why does my machine's LCD show "NO CARTRIDGE" even though I have already installed all the ink cartridges?
Description:
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridges, then one or more of the cartridges may not be properly installed. Verify that the cartridges are installed correctly by following these steps:
Note
    Cartridges that have already been installed are no longer vacuum-sealed, so it is very important that these cartridges remain upright. If a cartridge is removed from the machine and placed on its side, air may be introduced into the ink supply tubes. As a result, repeated cleaning will likely be required before normal print quality is restored.
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    If the date and time appear on the display, the issue is resolved. If the display continues to show NO CARTRIDGE, continues to Step 2.
  2. Open the scanner cover by lifting it from the right-hand side until it locks securely into the open position.
  3. Remove the black ink cartridge by pulling the white plastic hook (locked over the edge of the ink cartridge) toward you, then lifting the cartridge out.
  4. The LCD should prompt you to install the black ink cartridge.
  5. Reinstall the black cartridge. Press down FIRMLY on the top of the cartridge until it is fully seated. Push the white plastic hook towards the cartridge to verify it is fully latched over the cartridge's top edge. Repeat STEPS 2 - 4 to verify each that of the color cartridges (magenta, cyan and yellow) is installed properly, then continue to STEP.
  6. Close the scanner cover. The unit should begin cleaning automatically.
Please remember to rate all Techs who assist you for free :) Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 01, 2008 | Brother DCP-110C All-In-One InkJet Printer
PRINTER WON'T ACCEPT NEW INK CARTRIDGE
From the Brother solutions website:
Note
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
