Question about Vehicle Parts & Accessories
Wiring for MSD searter on small block chevy with MSD distributor
If you put key on run it engages starter. I need to know what wires do or don't go to the small terminal?
Ross
  • r_linder Nov 23, 2008
    Please send answer direct to r_linder@telus.net. This is for my race car (drag), I appreciate your help'
    Ross
  • Vehicle Part... Master
  • 22,306 Answers
This is simple but if i post an answer their will be every boy racer out their nicking an older car that doesnt have a key sensitive immobiliser.if you dont know call out a mobile mechanic
Posted on Nov 22, 2008
  • Colin Stickland
    Colin Stickland Nov 23, 2008
    tried to send e mail but it wouldnt go something about not available ,well on the back of ignition switch you should have 4 connections or wires ,use a light to test for which one is positive feed ,found it good now turn switch to aux position and you should find a feed ,which turn on and off with key.well as its for racing ignore this as you have no radio,turn key to run position and you should have a feed this is the feed for the ignition and somehow your starter wire is connected to this as well .now turn key and hold in start position and find the connection with the feed ,let key drop back to run position just to check light goes out .now connect your starter wire to this connection and off you go .if you win a race send me a picture
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Correct spark plug wiring diagram
Firing order for a 305 is 1-8-4-3-6-5-7-2. The distributor turns counter clockwise and #1 should be the 5 o'clock position looking down at the top of the distributor.
Jun 29, 2013 | 1986 Pontiac Firebird
1983 chevy truck turned key want start tried jumping the starter it half cranked had starter checked i was told it was good. put everthing back together. still want start
make sure all wiring is free of corrosion . Id say the solenoid is the best bet if you know the bendix is popping up in the starter and engaging the flywheel
Jan 13, 2011 | Chevrolet Silverado Cars & Trucks
Wiring for a small block 350
need to know if its a HEI cap and rotor or not. HEI caps have the coil built into them , an all in one ignition as compared to a external cylindrical coil.
you need to know that. either the distributor cap is a huge hurken thing (HEI) or it has an external coil somewhere or the cap has a ninth distributor hole in the middle of the cap to put a coil. wire.
after you figure out which one it is then you have to either go to www.autozone.com and study chevy wiring or buy a haynes manual for the similar vintage engine. for the external coil I would try a chilton manual for a chev truck before 1972. for HEI anytime thereafter. I may be off by a few years on the age of the engine. but hopefully you got an idea of what to do, or just google chev engine wiring? and study away.
good luck
jm
Jul 27, 2010 | 1980 Chevrolet Corvette
Problem with a 2000 chevy blazer not starting
Have replaced starter, alternator , ignition wiring, neutral safety starter switch, still happens ??????? Do you know how to do automotive electrical testing ? Not guessing an replacing parts . Not starting ??? How ? when you turn the key to start does the starter motor engage an spin the engine ? Or when you turn the key to start nothing happens ? A no crank no start or a cranks no start . Plus you shoud learn how the system works before trying to diagnose .
Jun 18, 2017 | 2000 Chevrolet Blazer
Need help
You can do this on a temporary basis, but you need to find the wire. Try running from the ignition switch run side to the dist. at least you can turn it off.
Apr 18, 2009 | 1984 Oldsmobile Cutlass
Small block chevy wiring
You should have a purple wire that goes to the starter,plus the red one from pos on battery. I believe you will have a red wire and a black w/red stripe or red/ w black stripe gong to the alternator.
As far as the distributor I think factory was a big pink wire. But you can also just run a wire from the fuse box that would only be hot with key in on position. If you need more help please ask.
Make sure you have your seat belt on and hang on to the steering wheel when you drop the hammer on that 383cu.
Good luck and enjoy.
Apr 07, 2009 | 1988 Chevrolet Camaro
383 SMALL BLOCK CHEVY
383 is a modified engine...since it's not stock, you need to learn to "read" spark plugs. In reality the # used in any engine is a starting point for experimentation. Begin with factory plug, If too white or too black change heat range 'till you find a # that gives mostly white porcelan with light tan tinge. That will be a good plug to run.
Mar 25, 2009 | Chevrolet Nova Cars & Trucks
Starter wiring configuration
the battery wire goes driectly on the large post of the starter along with all the wires that have fuse links on them the smaller wire goes on the small bolt on the starter..
Jan 22, 2009 | 1999 Chevrolet Cavalier
Vehicle Parts & Accessories Logo
135 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
