Question about HP LaserJet 6L: HP 6L Monochrome Laserjet Printer 6PPM, Toner Included, Refurbished, 90 days warranty
LASERJET6L IS NOT WORKING PROPERLY
I NEED IT TO PRINT DOCUMENTS
  • comment
    comment May 11, 2010
    You want to print documents? What are the problems you are experiencing. Please provide as much detail as possible!
    Problem Solver:
  • 15 Answers
It would depend if its a problem with the paper transport, or a fuser problem.
we dont have a crystal ball, you need to tell us if it jams or doesnt print at all, or tell us the light combination at the front, press the front button and you get a second set of combination if it all 3 lights are lit.
Posted on Nov 28, 2008
When I print it prints a code description of the document rather then the document
You need the proper print drivers. Download the drivers and update or re-install your drivers
Mar 13, 2014 | Kyocera Mita KM-2550 All-In-One Laser...
Some pages offset printing
You need the paper feed tires replaced.
Feb 17, 2014 | Xerox 5500/DT Laser Printer
I dont know how to prtint
here are some steps to print document.(just make it sure that your printer is properly installed in your computer.including the printer driver.
1. 1
Open a program that allows you to insert text into a document or get on the internet.
2.
If you were to open a program, you would need to type text into the document. If you were to get on the internet, you could skip to step 7.3.
After you have typed text into the document, you need to locate the menu bar, click on file, then point to print.4.
Click on print.5.
When the print dialog box appears, select the printer you want to use (if it is not already selected) and select the number of copies to print.6.
Click OK.
7.
If you were to print a page or pages from the internet, follow steps 3, 4, 5, and 6, except you don't have to type text into a document to print.
Sep 23, 2011 | Office Equipment & Supplies
Hi, I have a laserJet6L and I have a "out of paper" message while there is actually paper.
there is a sensor in the paper tray.
May be it's blocked or the paper is not pressing it properly.
Mar 15, 2010 | HP LaserJet 6L Printer
Ran out of color ink on cnnon mx310 ... want to
If when you attempt to print only with the black cartridge installed but it won't print, then this specific printer requires that color ink also be installed. Typical with most inkjets.
Jul 07, 2009 | Canon MX310 Office All-In-One Printer
Says "document failed to print" constantly after printing half of 1st page
first u check the cable of the printer to system connected properly from both end if not then connect properly , after that problem not solved then change the cable and try if the printer is working then the old cable is faulty , if the printer not ok then uninstall the printer driver from system and restart the system then after restarting the system reinstall the printer driver properly by giving right port, after installing restsrt the system . After restarting the system check by giving a print
Jun 02, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
Document wont print
It could be a hardware issue.
Check first if the printer is working fine. Keep on holding down the paper button while you turn the printer on. Let go of the paper button when the power light starts to flash. if it printed out a color test pattern successfully, check if you are using the corrrect driver.
Tell me more if you need assistance in trashing and re-installing the proper driver for your printer. Include the full version of the operating system you are using too.
Goodluck.
sherlyn c.
May 23, 2009 | Epson Stylus C66 Photo InkJet Printer
Black and white not printing correctly, color is fine
If you are not using Epson ink, your printer will do this. Epson printers hate knock-off ink. Always use Epson ink if you want to keep your printer working properly. To solve the problem you are having, try cleaning the ink tubes. Make sure you re-install them properly. Hope this helps. Charlene
Feb 10, 2009 | Epson Stylus CX3810 All-In-One InkJet...
Printing-Supercalc 5-Spreadsheet-, Sideways
just to check if the printer and the printer driver is working properly, try printing a 2 page document.
if it prints out correctly - check the applications documentation / user guide for printing instructions.
Dec 28, 2007 | Office Equipment & Supplies
69 people viewed this question
Seeker5211
Seeker5211
