Question about Dell Inspiron 700M Notebook
Cant start windows
Need to know what boot options I have to change in order to start up windows in safe mode or normally whit primary hard disk not found and no bootable devise?
  • 189 Answers
I think you cannot boot anything cause there was no hardisk and no bootable devise is available either in safe mode or normal. There must be first installed operarting system (xp, etc) with a detected hardisk.
You can use safe mode to correct that was changes made in your computer that affect the system or the computer once you re-start the computer. but still you can open the computer but with limited options.
In normal, the normal process of computer were you can access everything.
Hope that will help you.
Thanks
Posted on Nov 19, 2008
  • Dell Master
  • 1,183 Answers
The no bootable device found or the promary disk not found error can be caused because of the following reasons
1. The operating system has crashed
2. The harddrive is faulty.
Try the following steps
1. Remove any cd if there is in the optical drive
2. Disconnect the Ac adapater and remove the battery
3. Press and hold the power button on the laptop for 10 seconds
4. Reconnect the Ac adapter
5. Power on the laptop and press F12 key on the keyboard a couple of times slowly on the Dell screen
6. Select Hardrive diagnostics from the list
7. If the harddrive returns with an error code , you would need to replace the same
8. If not then, restart your computer and press F8, a couple of times on dell logo screen
9. Select safe mode from the list.
Use the following wizard
http://tinyurl.com/56ym45
Thanks
Proton
I shutdown my Asus notebook a lil while after windows 8.1 update and now the screen looks like this! I don't know what to do please help!
The following is a general troubleshooting guide that may or may not help you. It may vary some based on your operating system.
First disconnect all non-essential devices, cords, internet connection, etc. Try rebooting normal. If that works you have some type of external hardware or external software issue that must isolated. Try adding one thing at a time back to your computer, rebooting each time to test. Remove, replace, or repair the conflicting device.If the initial test fails, now indicating it is your PC, try rebooting in Safe mode.
If windows PC based, try booting to safe mode by tapping F8 as soon as the power is activated. Continue tapping until a menu appears....it should have "Start in Safe Mode" as a selection. If not, find out the proper Start in Safe Mode for your OS. Safe mode operates your computer with the basics.
If you cannot start in Safe Mode you have a PC problem but now have to try to isolate your problem. This could still be hardware of software internal to your PC.
If you can start in Safe Mode you might only have a software issue. If you loaded something prior to the failure, attempt to uninstall that software, or "Restore" your computer to a previous time.
If attempting to start in Safe Mode fails, this is preliminarily indicating a hardware issue, a problem with the Hard Drive, whether that is the drive itself, a virus, corrupted Windows OS, deleted registry files, or some other PC Hardware issue.
Attempt to start from a CD/DVD drive with a Windows Recovery disk or your original coy of the Windows OS program in your drive, (Normally your computer is set to first try downloading Windows from your Hard Drive. That is set in your "Boot Menu".You need to get into your "boot menu" to change these directions. Getting to the "boot menu" varies by the OS version, but in most cases start tapping F12 on initial power up until you get a menu that pops up rather than trying to log in. Your mouse is not usable in this menu. You must arrow up/down etc to move around. Depending on what you see concerning the "primary" drive or list of sequence of drives, you will more than likely see "Hard drive" or "SATA". Write down what you have before changing anything. Change your primary boot up drive to be your CD/DVD drive designation, and save your changes. Power off, insert your windows CD or Windows recovery disk into your CD/DVD and power on. If windows boots up from your CD you probably have a bad or corrupted hard drive, or something in the associated circuitry, wiring, connectors? REMEMBER YOU HAVE CHANGED YOU BOOT MENU TO CD/DVD. YOU MIGHT NEED TO CHANGE IT BACK TO SATA OR YOUR HD DESIGNATION DEPENDING ON WHAT YOU DECIDE TO DO NEXT.
If you still fail to boot from a Recovery Disk from you CD/DVD drive make sure you did change your start up "Primary" Drive designation to the CD/DVD drive, and that you saved that before exiting.
Take your PC cover off and with the power off check to make sure all your cable connectors, ribbon connectors, memory sticks, are connected.It is probably a good time to unplug all your memory sticks and other things, and re-plug them in. On the chance there is minor corrosion in the mother board connectors or the stick terminals themselves.Be careful and attempt this only if you are confident you will not damage anything.I would normally unplug and replug all cables, connectors, jumpers, video cards, etc, at this time to eliminate a loose connection (More common with laptops or a PC that was recently moved or bumped)Be extremely careful with connectors you are not familiar with .Many of them have some type of plastic spring tab that breaks easy. Also do not mess with the Chip on the mother board. Prior to sticking your hands inside, double check the PC is powered off and unplugged. Some of these electronic things are static sensitive, so ground yourself out first. If your PC is unplugged no ground exists there to discharge you. You need to find another source. If you don't know what I am talking about I don't advise messing around inside your PC.
Try rebooting with your Recovery Disk in your CD/DVD. If this doesn't work you have missed a step or you have a PC problem other than your Hard Drive. I won't cover more in depth troubleshooting.
If you are able to reboot with a Recovery Disk in the CD/DVD after resetting all your memory sticks, cables and connectors you have fixed the problem and need to retest the Hard drive now. Remove the Recovery Disk from your CD/DVD drive.Go back into your Boot Menu and change your Primary boot device back to your internal Hard drive, normally the SATA. Reboot your computer.
If you boot now from your Hard drive your problem has been corrected.If your computer fails to boot from the HD, you have a defective Hard drive, corrupted Windows files, etc. You are not able to reload Windows without formatting the Hard drive and losing any info of value that might still be there. In my past experience I purchase a new HD at this point and install it.
It might be as easy as going to Fry's or another electronics place and purchasing a similar hard drive. Fairly easy to unplug, unscrew and replace. Watch for a "Master" "Slave" connector on the drive itself (Not normally a concern with more recent OS's, Drives, and setup. Some of the old HD's had a little jumper. It has to be placed the same on your new drive. Your machine with a new hard drive installed is basically void of any OS. You will need to reload Windows before proceeding or being able to boot the machine. (make sure your Windows OS disks and have a key code for that) If you get Windows installed and bootable, you will then need all your other drivers, and program software. You will not have any of your old files unless you are able to retrieve them from the old drive. That recovery process is something for someone with advanced technical skills....if it is even possible. If you don't possess the skills to remove and replace the HD, pay someone to do it. They will probably also reload any software at the same time for nearly the same price.
I have installed on old corrupted HD as a secondary HD. I do that after I get Windows loaded and working on the newly purchased HD.If your old drive is still functional as will be the case if Windows on that drive was corrupted, or registry files damaged or deleted (and you haven't reformatted it or attempted to reload Windows OS)....you can often times copy your important files from the old HD to the new HD.
Mar 06, 2015 | ASUS Computers & Internet
Safe mode exit
Just reboot normally and do not select SafeMode. You need to configure the boot order in the BIOS to make Boot from CD-Drive the first option. save the changes and then exit the BIOS. Insert the installation disk and reboot.
Jan 25, 2014 | IBM Lenovo Thinkpad T43 Left And Right...
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
Feb 28, 2010 | Microsoft Windows XP Professional for PC
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
Dell xps m1530 formatted hdd now it wont boot
Sounds like you've removed your drivers for your OS try rebooting from CD!!
Aug 19, 2009 | Dell XPS M1530 Laptop
Acer Aspire 5100 Wont Boot To Start....
Try booting in safe mode. you may want to first try loading the last known good configuration.
To get into the Windows Vista Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key. Let computer boot to safe mode and then shutdown. If problem continues then Start in safe mode again.
After you boot to safe mode then go to Control Panel, System, Advanced System Settings, Advanced tab should be at the forefront. Go towards the bottom of the popup (Startup and Recovery) and select settings. Then in the settings popoup uncheck Automatically Restart. OK and apply everyithing then restart computer. Let me know what happens.
Dec 18, 2008 | Acer Aspire 5100 Notebook
Can you help? Have a Advent 7096 laptop protected by PC Angel. Have run system recovery using 4 discs. Cannot get into Windows - message reads "load needed dll's for kernel" Not my machine but...
If you having problem running system recovery in normal mode try running system recovery in Safe Mode by pressing F8 key when you turn on the laptop.. a selection pop-up, select your primary hard disk where your windows installed still pressing F8 then a Boot Selection appear select Safe Mode after starting in Safe mode do the system recovery.. still not working choice the Last Good Configuration. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
How do i reboot my windows visat without the reboot disc?
Is this a trick question? Or are you serious? You reboot by shuting it off and turning it back on. or using the ctrl,alt, and delete buttons at the same time.
You can try this too.
Using the F8 Method
  1. Restart your computer.
  2. When the computer starts you will see your computer's hardware being listed. When you see this information start to gently tap the F8 key repeatedly until you are presented with the Windows Vista Advanced Boot Options.
  3. Select the Safe Mode option using the arrow keys.
  4. Then press the enter key on your keyboard to boot into Vista Safe Mode.
  5. When Windows starts you will be at a typical logon screen. Logon to your computer and Vista will enter Safe mode.
  6. Do whatever tasks you require, and when you are done, reboot to go back into normal mode.
Nov 15, 2008 | Computers & Internet
Compaq presario 2500 does not boot
you got an OS problem try to re install your OS.
Oct 17, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Compaq v2000
Do u have installed recently, some software?
Try to boot up pressing the F8 button, when the menu appears select the option "Windows in safe mode" if u can boot to windows. View our software installed.
If it is not software try, boot whit the windows installation disk enter to the setup and select the option repair, u will go to a DOS prompted window (all black whit white letters) must appear "c:\"
used the command "chkdsk /f /r" let it run he will try to find any problem in the disk.
Nov 08, 2007 | HP Compaq Presario V2000 Notebook
Dell Inspiron 700M Notebook Logo
125 people viewed this question
Alun Cox
