Question about Canon imageRUNNER 2200
Ir 3320 error code e602-0001
Code on ir 3320 e602-0001
  • Canon Expert
  • 270 Answers
I not familiar with the model of copier but the error is a Standard Canon Hard Disk Drive failure that will have to be dealt with by a technician. He will have to reformat and install new system software or go as far as having to replace the HDD.
Posted on Nov 20, 2008
John deere 3320 error code 63
You just go to the link I attached I'm sure you will get the solution of your problem.
John deere 3320
May 29, 2017 | John Deere Garden
Tip
Xerox machine ir 3320, error 602-003 and 602-004\r\n
The E 602- 003 is due to hard disk system error but you can scan it ;run check disk its can fix that problem. try this, hold on 1 and 9 (from the machine key board) then switch on the copier; then wait around 1 hour all screen will be white then the copier will display download mode. then switch off and put on the copier.
on Nov 02, 2010 | Office Equipment & Supplies
John Deere 3320 error codes
John deere 3320
How do i fix the error 000003-0000 on ir 3320?
Hi
Whilst looking through the web I found this procedure for clearing errors from ir series Canons. You might like to try it first.
  1. Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
If this doesn't work, I found a complete list of error codes here:
Error Codes Canon iR3320
There are 12 pages of them but yours appears to be on the first and related to the temperature of - or lack of - the fixing unit. From this site you can also buy a service manual which may also be helpful to you rather than the User Manual/Guide.
Cheers
Nov 14, 2014 | Canon Office Equipment & Supplies
Error code e000602
Mounting fault of the HDD.Viring faulty.The main controller PCB faulty.Wiring between connector J1025 of the main controller PCB and the connectorJ 2005 of HDD,or try reinstall the system software,or try to replace HDD and download the system software,or replace the main controller PCB...
Sep 25, 2014 | Canon gpr-6 ir 2200/2800 drum...
I have a xerox machine ir 3320 i have facing a error 602-003 and 602-004\r\n and printing are coming zigzag type
try this,
then wait arround 1 hour all sceer will be white then the copier will display download mode.
Oct 31, 2010 | Canon Office Equipment & Supplies
Error E601-0003 on cano ir 3320 plz help
Image transfer error in your machine.
check your ip board.
Oct 21, 2009 | Office Equipment & Supplies
My 3320 john deere jerks and also shuts off the
You can call a local John Deere distributer. Talk with the parts department and tell them the error code you are getting. Give them your serial number and model number and they can tell you exactly what the error code means. This will allow you to run a search for the error itself and find a part replacement or fix for the error code.
Oct 10, 2009 | Garden
Error code on screen is E602-0003
i have problem in my cannon ir 3320 it shows
E602-001 & E0315-000d
pl solve it
Aug 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Canon imageRUNNER 2200 Logo
932 people viewed this question
old marine
old marine
